  • Total: 118,176,268
  • Today: 48,284
  • 11:50 am PDT
TCS1100F
PostPosted: Fri May 27, 2016 4:11 pm Reply with quote Back to top
Thinking about a TL1000S back in Utah when I head back there next week. Supposed to be i great shape and low miles.
Anybody had any experience or know any that had experience?
Wayne750F
PostPosted: Fri May 27, 2016 4:55 pm Reply with quote Back to top
Yep....a buddy had a 99' very fast bike at 125 HP but the suspension was sloppy...change the shocks out and it's a nice bike...
1983 Red CB1100F
1991 Suzuki GSXR1100
1993 Yamaha FZR1000
PostPosted: Fri May 27, 2016 6:52 pm Reply with quote Back to top
Very cool skoot! Love the sound!
toonces
PostPosted: Fri May 27, 2016 11:49 pm Reply with quote Back to top
They're cool and fast, but definitely from the "lower tier" in terms of build quality. Nowhere near as nice fit/finish as say a GSXR.
The rotary damper rear suspension is the achilles heel, but they can be blueprinted for much improved performance. I took a long look
at these back in '98, ended up buying a SuperHawk instead.
If you like it and the price is right, go for it!
Toonces
paultls
PostPosted: Fri May 27, 2016 11:55 pm Reply with quote Back to top
I have a 1997 tls, have replaced everything had to be replaced , rotary dampner with R1 rear shock,K4 front end , I have 3 ecu's to plug in for different performances ,air box mod ,it has 145000 k's I love it ..
1997 TLS..
2007 R1..
1984 CB1100f..
PostPosted: Sat May 28, 2016 12:25 am Reply with quote Back to top
Some have been known to crack frames. Have a good look around.
http://www.tlzone.net/forums/suzuki-tl1000r-tl1000s-forum/92044-ultimate-cracked-frame-thread-tl-only.html
jagboy1
PostPosted: Wed Jun 01, 2016 9:06 am Reply with quote Back to top
I've had mine from new in 98 . . fantastic bike . will never sell her. .as mentioned ,the rear rotary damper is not that good . plenty of other options out there . .the front forks and brakes work well if looked after . plenty of easy upgrades if you feel the need . .the frame can crack around the rotary damper . . have a good look for missing heads on the mounting bolts . . if it is cracked a different damper set up will get round the problem. ..general condition is the key . . if it looks like its been looked after you should be OK . they need regular oil changes . .nearly all Tl engines make a ticking noise . is normal . but listen out for knocking under load . . this will be a big end bearing . . more common on 97 model. . the 98 got revised oiling .
coombehouse
PostPosted: Wed Jun 01, 2016 10:41 pm Reply with quote Back to top
It all depends on if you like 2 cylinder bikes.
I have owned 3 TL1000S as I was convinced the more I modded them the more I would like them. I was hoping that they would be the beast that everyone said but unfortunately they all left me wanting more. They sound great though but I sold them all.
I guess I just like 4 cylinder bikes but I do have an RC51 too which is fantastic & revs like a 4 so I guess it suits me.
Perky1
PostPosted: Sat Oct 22, 2016 6:14 pm Reply with quote Back to top
I have a 1997 TLS very modified ill try and upload a pic, love it and am keeping it but now building a Freddie Spencer Rep .
