  • Total: 118,185,984
  • Today: 58,000
  • 02:15 pm PDT
VIPERTECH
PostPosted: Thu Mar 10, 2016 4:22 pm Reply with quote Back to top
HEY GUY'S ANYONE HAVE ANY SPECS ON FORK BRACES I HAVE LOTS OF PEOPLE INTERESTED IN THE ONE I POSTED ON LIST #7 I DO NOT HAVE ANY EXPERIENCE WITH FORK BRACES I BELIEVE THAT THEY MOUNT TO THE FORK LOWER NOT THE SLIDE OR FORK TUBE IF ANYONE KNOWS WHAT THE DIAMETER OF THE CLAMP PORTION AND THE CENTER TO CENTER DISTANCE PLEASE SEND ME A PM SOME GUY'S WANT THEM FOR 39 MM FORKS AND 35 MM THE CLAMP AREA ON SOME MEASURE 50MM AND OTHERS 47.3 MM 6-13/16 CENTER TO CENTER THANKS MATT
super
PostPosted: Thu Mar 10, 2016 4:36 pm Reply with quote Back to top
hit capslock if you type in a normal type of voice, it's easier to read
VIPERTECH
PostPosted: Thu Mar 10, 2016 4:50 pm Reply with quote Back to top
That was helpful
PostPosted: Thu Mar 10, 2016 5:12 pm Reply with quote Back to top
I can measure the legs/sliders for both of them tonight. Thanks!
Steve
PostPosted: Thu Mar 10, 2016 5:48 pm Reply with quote Back to top
CB900F-39mm forks-62mm diameter fork slider
CBX-35mm forks-56mm diameter fork slider
sfhess
PostPosted: Thu Mar 10, 2016 6:17 pm Reply with quote Back to top
Fork braces clamp to the tops of the moving part of the forks.
PostPosted: Thu Mar 10, 2016 6:37 pm Reply with quote Back to top
Early model CBX Twin Shock ('79 and '80) are 35mm/56mm
Late model CBX Pro Link ('81 and '82) are the same as the CB900F 39mm/62mm. This should open up potential sales on this size.
And as most everyone knows, the CB1100F won't need an aftermarket part as Honda made the forks with one.
hogwild113
PostPosted: Thu Mar 10, 2016 6:48 pm Reply with quote Back to top
When I had my fork brace made, they only needed two measurements. 1) diameter of the fork leg at the top (where the fork brace goes) 2) center to center of fork tubes.
I used two small adjustable squares to get center to center. Measure across and subtract one fork tube diameter(same as subtracting half twice..)
Center to center on my 1994 CBR600F2 forks is the same center to center on CB900F forks, if I remember correctly...
Once you get the diameter of the holes and the center-to-center measurement, people can measure their forks and see if one will work for them..
super
PostPosted: Thu Mar 10, 2016 7:10 pm Reply with quote Back to top
VIPERTECH wrote:
That was helpful
yeah, no problem. CAPSLOCK is in many ways a fat chick, slim it down and you get alot more help
PostPosted: Thu Mar 10, 2016 8:19 pm Reply with quote Back to top
CBX 79 and 80 fork sliders are different.
PostPosted: Fri Mar 11, 2016 12:28 am Reply with quote Back to top
I just measured my 79 750F (35mm tubes) and my 81 900F (39mm tubes).
79 750 sliders were 56mm (2.2") diameter, and 126.5mm (4.98") from inner edge to inner edge of sliders (top edge above fender).
81 900 sliders were 60.8-61mm (2.4"+/-) diameter (depending on which rib I measured), and 130.1mm (5.1") from inner edge to inner edge of sliders.
Not sure why there is 1 mm difference between what CBXtras reports and what I measure for the 900F slider diameter, but I remeasured after seeing his post. IDK.
Steve
