  • Total: 114,882,042
  • Today: 13,373
  • Sep 20, 2026
  • 06:42 am PDT
PostPosted: Fri Feb 19, 2016 3:29 am Reply with quote Back to top
I could use a slightly longer swingarm pivot bolt, anyone familiar with a bike that uses a M16 pivot bolt that is slightly longer than the 1100f bolt?
The one I measured is M16x385 and I could use use a few extra mm to catch a few more threads and look better.
I could machine down some spacers but would have to send them out to be done, a longer bolt would be a better solution if one exists exists.
toonces
PostPosted: Fri Feb 19, 2016 11:43 am Reply with quote Back to top
You could counterbore the bracket and get that nut "down in the hole" some more.
Or c-bore brackets on both sides and split the difference.
Toonces
PostPosted: Fri Feb 19, 2016 2:09 pm Reply with quote Back to top
There are spacers behind the footpeg brackets that could be machined to get the clearance but I am looking to avoid any machining and just slip a longer bolt in.
PostPosted: Fri Feb 19, 2016 2:42 pm Reply with quote Back to top
1980-1982 CBX uses a 16mm pivot bolt. Don't know how long they are.
PostPosted: Fri Feb 19, 2016 4:12 pm Reply with quote Back to top
Thanks, I'll ask over on the CBX forum. Perhaps someone has one laying around.
Hondamax
PostPosted: Fri Feb 19, 2016 5:06 pm Reply with quote Back to top
The Yamaha MT-09 has a 16mm bolt, but can't find its length, plus being "modern" it might well be narrower ...
Regards,
Max
1984 VF1000R - Started
1979 900Fz - Stored
jt
PostPosted: Sat Feb 20, 2016 3:52 am Reply with quote Back to top
I measured what I believe to be a late model CBX swing arm pivot bolt. 15-1/4" measured from under head of bolt to end . is 16mm for sure. I have 81 CBX roller I will look at it tomorrow, it is in another location.
JT in Texas
PostPosted: Sat Feb 20, 2016 1:16 pm Reply with quote Back to top
JT in Texas
So it would be basically the same length, maybe 2mm longer than the F bolt.
PostPosted: Sat Feb 20, 2016 4:02 pm Reply with quote Back to top
Thanks guys, I don't think 2mm gets me where I need to go but to be sure I will pull the bolt in the bike and measure it in case it is shorter than the one I have on the shelf.
I have options on making a bolt or machining the spacers and will think it over.
Hondamax
PostPosted: Sat Feb 20, 2016 5:02 pm Reply with quote Back to top
Why not 16mm stainless bar cut to size and threaded both ends ...?
Regards,
Max
1979 900Fz - Stored
hogwild113
PostPosted: Sat Feb 20, 2016 11:16 pm Reply with quote Back to top
I didn't put the washer behind the pivot bolt nut and it gave me enough threads to get to the end of bolt. I've been running it this way a year and a half, no problems..
PostPosted: Sun Feb 21, 2016 6:07 pm Reply with quote Back to top
That is another option as I have the washers on both ends, your setup doesn't look bad.
We can stop looking for a longer bolt, I have someone that will make a nice SS one for me if I wish to go that route. Plus I can I can get the spacers/washers reduced if the stock bolt gets used.
