  • Total: 113,762,800
  • Today: 9,467
  • Aug 25, 2026
  • 07:20 am PDT
bikeboy
PostPosted: Sat Jan 16, 2016 8:18 am Reply with quote Back to top
I can see how the "open" 4 studs at the centre would collect any rubbish it's exposed to, but what about the 8 outside studs that are completely enclosed? The only way in I can see is from the top, which is sealed by a copper washer, under a dome-nut, under the valve cover??
I know it gets in, but I'll be buggered if I can work out how? Am I missing something?
I plan to drill some drain holes before I reassemble everything, but that's not a cure is it?
Ian
CB1100RD
CB985F
VF1000RE
VF1000F
VF750F
CB400F
lunterenholland
PostPosted: Sat Jan 16, 2016 10:05 am Reply with quote Back to top
Hello Ian,
The crap comes in at the cilinder head, between the exhaust ports.
You can drill a hole without problems, i have done it many times now.
Wout.
bikeboy
PostPosted: Sat Jan 16, 2016 10:15 am Reply with quote Back to top
lunterenholland wrote:
Hello Ian,
Wout.
Well that's the bit I don't get Wout, because at least the 4 outside studs on each side are fully enclosed? The head gasket should seal that surface so how the heck does it get in?
CB1100RD
CB985F
VF1000RE
VF1000F
VF750F
CB400F
