  • Total: 123,238,688
  • Today: 235,104
  • 11:13 pm PST
Mrnagrom
PostPosted: Thu Sep 03, 2015 11:50 pm Reply with quote Back to top
The bike just roared to life. it's no longer backfiring and it idles evenly. it's nuts. . i had no idea this would make so much difference. thanks guys.
Wayne750F
PostPosted: Fri Sep 04, 2015 12:07 am Reply with quote Back to top
Wait till you get it out and really run it good!!!!
1983 Red CB1100F
1991 Suzuki GSXR1100
1993 Yamaha FZR1000
youn6372
PostPosted: Fri Sep 04, 2015 1:44 pm Reply with quote Back to top
I totally agree. Adding up to on volt on a 12 volt system is a lot. Great mod!
PostPosted: Fri Sep 04, 2015 7:50 pm Reply with quote Back to top
It's really pretty simple. The coils have to have enough power available to charge adequately. For starting, it means getting enough power when the battery voltage drops from the sag caused from the starter motor sucking lots of current. At high revs, the coils have less time to adequately charge, so having more power available allows them to charge to an acceptable level more quickly.
Better coils makes it all even better. The stock coils that came on the bikes always were marginal. I prefer the green Dyna coils for stock ignitions. The Procom Engineering ignitions are also a significant improvement over the old tech stock igniters.
Doing all the changes, relay, coils, and ignition boxes, along with better spark plug wires and caps and Iridium plugs, should allow running with a wider spark gap, maybe up to .032" or more, it would take some experimenting to optimize it. This will also improve the burn in the cylinder, analogous to lighting a fire with a bigger flame.
PostPosted: Fri Sep 04, 2015 7:57 pm Reply with quote Back to top
Doing all the changes, relay, coils, and ignition boxes, along with better spark plug wires and caps and Iridium plugs, should allow running with a wider spark gap, maybe up to .028" to .030". This will also improve the burn in the cylinder by lighting the fire with a bigger match, basically.
I went up to .034" on the spark plug gap after doing the coil mod. One or the other or both cured the rich condition I was experiencing on my bike. No more fouled plugs or missing going on this whole riding season.
I did also change from Iridium (DR8EIX) to DR8ES.
1981 CB900F = Sold 2024
PostPosted: Fri Sep 04, 2015 7:59 pm Reply with quote Back to top
Yeah, the marginal ignition system is responsible for the increased tendency for these bikes to foul plugs so easily. Once I changed to the MSD MC-1, I never fouled another plug again ever.
When running smoothbores like CRs or VMs, the stock ignition system really falls down. Changing to the Viton valve stem seals and reducing all that oil contamination getting into the intake also helps.
Mrnagrom
PostPosted: Mon Sep 07, 2015 1:43 am Reply with quote Back to top
Hey gene. I've decided to buy a new set of coils to replace my very cracked up ones. I was looking at the greens Dc1-1 and was wondering if you knew of any difference in those and the dc1-2 as they look a little smaller.
PostPosted: Mon Sep 07, 2015 1:56 am Reply with quote Back to top
The DC1-2 are the Dyna mini coils. I don't think they are optimal for using with the stock ignition. Dyna has a note - "These coils can only be used with an ignition that incorporates a means of controlling the coils dwell/charge time such as the Dyna 2000". I think the mini coils would be more difficult to figure out a clean mount, but I never tried them. It was always recommended to just get the DC1-1s for these bikes.
The DC1-1 coils fit fine where the stock coils are on the DOHC bikes. I think you just leave part of the mounting bracket out from the stock coils and the Dynas mount right up.... but it's been about 30 years since I converted my bike to them, so I forget exactly. I remember it was pretty easy, no hammer or saw necessary.
dannycoolbeans
PostPosted: Mon Sep 07, 2015 3:54 am Reply with quote Back to top
I just did the cbr coils, new wires, new plug caps, iridium plugs & procom ignitors. HUGE freaken improvment. It actually fixed up the break up I was having.
The plugs came gapped at .030 and I lowered them down to spec .025. My question is: Should I open the gaps back up to .30-.032?
thx
1983 cb1100f
PostPosted: Mon Sep 07, 2015 6:59 am Reply with quote Back to top
You might get away with more. Start at .030" (stock spec is .024" - .028", page 1-3 of the Honda manual) and see if it still starts easy when cold, runs well to redline when warm or hot, and check for your breakup issue. If it's good, try .002" more and check all conditions again. When you find you start getting issues, drop back two settings from where it goes bad and run it there, but stay tuned for issues.
Be very careful when gapping Iridium plugs. Don't touch the center electrode, it's very brittle and is damaged very easily.
Mrnagrom
PostPosted: Mon Sep 07, 2015 12:34 pm Reply with quote Back to top
I thought the stock ignition controlled dwell?
CBX1260cc
PostPosted: Mon Sep 07, 2015 1:57 pm Reply with quote Back to top
I'm coming into this thread a bit late I know--BUT--could someone be kind enough to post a link--for the uninformed-- that has more detail?
Thank you
cbxdog
PostPosted: Mon Sep 07, 2015 2:07 pm Reply with quote Back to top
Thank you
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=75332&highlight=coil+mod+relay
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=50593&postdays=0&postorder=asc&start=90
1980 CBX
1982 CB1100RC - basket case
1970 HD FLH
1976 HD FX
1983 HD FXRT
1988 FX 85th anniversary
1970 AMC Javelin
1982 AMC Spirit 360 5 speed
jonmon6691
PostPosted: Wed Sep 09, 2015 7:20 am Reply with quote Back to top
Saw this post and decided to give it a try. I've been having that breaking-up-at-high-rpms issue and this mod has popped up several times in the few weeks I've been on the forum. Before the mod, the voltage at the coils was 11.5 vs 13 at the battery, after the mod it was 12.6. I was actually really surprised with this because you don't usually expect there to be a voltage drop across a harness without any load. Anyway, it took a few hours, it could have gone a lot faster, but I played around with where to mount the relay and I made sure the wiring was routed well and the crimps were solid. Ended up putting the relay right on top of the coils, between the tank and the frame. This way I was able to use the female blade terminal directly from the coil to power the relay. I had to make ZERO changes to the stock harness, I could switch back at any time.
Bottom line is that it seems to have increased the throttle threshold that causes the breaking up, and I am getting much less burbling and popping on deceleration. The problem isn't solved, but as others have said, it's best to get the low hanging fruit and eliminate as many possibilities as you can before trying harder/more expensive fixes.
Bone
PostPosted: Wed Sep 09, 2015 2:21 pm Reply with quote Back to top
I am in the process of doing a major restoration on my bike. I am not sure what loss I was getting before the mod, but I measured today and the drop was 0.002 volts from positive battery terminal to the coil terminal. Have yet to see if it improves performance, the bike is not running yet! Wink
1982 CB900FC
1981 CB900F2B
Wayne750F
PostPosted: Wed Sep 09, 2015 2:42 pm Reply with quote Back to top
Just wait Mate!!!! With that new motor and the coil mod you are going to need to tie yourself down to the bike.....
1983 Red CB1100F
1993 Yamaha FZR1000
CROOKY
PostPosted: Sun Sep 13, 2015 7:38 pm Reply with quote Back to top
Just done the relay mod today on my cb900 engined three wheeler.Never known an engine have so much trouble on the ignition side.I had already changed the igniters after one of the std ones melted,still had misfires and a taste for NGK's at a rapid rate.Changed the coils to the Dyna green ones and then the HT leads to Dyna ones.One of the pick ups then failed so lost cyls 1 and 4.,The CR carbs really seem to give the plugs a hard time and even with everything new it was still fouling plugs when you got stuck in traffic.I put a relay on each coil as the way way the wiring is spliced into the Classic mini wiring loom behind the dash it was easier.It started the instant i hit the button and ran so sweetly i could not quite believe the difference.Looks like rain for me the next few days so road test will have to wait.I will try and post some pics of the install tomorrow.
norm
PostPosted: Sun Sep 13, 2015 9:20 pm Reply with quote Back to top
I did the relay mod on mine a long time ago when it first started popping up in here and I think it made a difference but not huge, so my original wiring must have been reasonable. At least now I have peace of mind that I have good fresh power going into my coils
PostPosted: Fri Sep 18, 2015 7:11 am Reply with quote Back to top
I measure a 0.2vdc drop from battery to coil probably because everything got a good clean up when I rebuilt the bike, plus the RH switch block was fairly new. Therefore I don't think I'll bother with this mod. I'll keep an eye on it though in case it deteriorates.
deandeib
PostPosted: Fri Sep 18, 2015 10:05 am Reply with quote Back to top
I did my relay mod a couple weeks ago and voltage drop from battery to coils went from 1.43V to 0.01V and made a big difference in the performance. I had been getting top end break-up before but haven't tested it since the mod. Maybe this weekend.
deandeib
PostPosted: Fri Sep 18, 2015 2:41 pm Reply with quote Back to top
Good luck. I am envisioning the smile you will have coming up. I sure did. Very Happy
Cool
PostPosted: Fri Sep 18, 2015 6:34 pm Reply with quote Back to top
Yes, that should make quite a bit of difference. Easier cold starting too.
