  • Total: 123,208,398
  • Today: 204,814
  • 09:58 pm PST
EofA
PostPosted: Sun Aug 23, 2015 10:34 pm Reply with quote Back to top
I'll go first:
To get the valve head off, you have to pull the whole friggin' engine! GRRRR!!!!! There's like 1/2 of an inch on the studs more, so when you pull the head up all the way, it hits the frame and can't clear the studs? I hate you Honda.
I know we all love our bikes, but curious to know what you other fellas hate about our bikes. What the "F!"
GO!
nugget
PostPosted: Sun Aug 23, 2015 11:06 pm Reply with quote Back to top
I hate that my F is not together yet. Been doing my own version of a spencer look alike and I thought I would have had the bike done by now. Fitting 2000 Kawasaki zx600r rear sets to my bike at the moment. Then I'll do the cal fab swing arm and then the front end. That's going to be probably the hardest part of the build.
damage
PostPosted: Sun Aug 23, 2015 11:14 pm Reply with quote Back to top
I reckon it's the TWO cam chains and the bloody primary chain,yeah it makes it different to a Suzuki or Kawasaki but different isn't always better.They also could have made the head work a bit better.
Chris.
1999 Triumph Sprint St 955
1979 CB900f
1992 Suzuki GSX1100G sidecar
1996 Suzuki 1200 Bandit
1970 Honda CB350 P4 race bike
1985 Kawasaki GPZ900 P6 race bike
2012 MV Brutale 1090RR
If you're not living on the edge,you're taking up too much space
RobHondaCB
PostPosted: Mon Aug 24, 2015 8:30 am Reply with quote Back to top
I have a cb750 SOHC; I flip open my seat and can remove my tank with one bold and work on the engine. At the 900 I have to remove 2 side covers and 4 bolds to remove the seat, than remove the bold from the tank and only then the engine top is accesable.
Just a small thing but everytime I do this I think why didn't they keep the SOHC method.
Honda CB750F2 '79
Honda CB900Fd '84
Suzuki GSX600F (katana) '94
AMC49
PostPosted: Tue Aug 25, 2015 7:04 pm Reply with quote Back to top
Where do you get 4 bolts from? I thought it was only 2?
Actually the worst thing about it is that as the side cover rubber grommets get older the extra force needed to override them is what cracks the covers.
I too like the flip up seats.
sfhess
PostPosted: Tue Aug 25, 2015 7:46 pm Reply with quote Back to top
I haven't cracked a side cover in 34 years. Only changed the grommets once. I lubed them with silicone spray once or twice.
PostPosted: Tue Aug 25, 2015 8:42 pm Reply with quote Back to top
Removing the battery from my DOHC bikes is a pain in the ass compared to my SOHC. Access to the positive battery terminal isn't that great.
cbxdog
PostPosted: Tue Aug 25, 2015 9:22 pm Reply with quote Back to top
I take the + cable off the solenoid and leave the + cable attached to the battery,,much, much easier way to remove the F battery IMHO Same with the CBX.
1980 CBX
1982 CB1100RC - basket case
1970 HD FLH
1976 HD FX
1983 HD FXRT
1988 FX 85th anniversary
1970 AMC Javelin
1982 AMC Spirit 360 5 speed
PostPosted: Tue Aug 25, 2015 9:26 pm Reply with quote Back to top
Disconnect the negative cable first!
cbxdog
PostPosted: Tue Aug 25, 2015 9:36 pm Reply with quote Back to top
Very good point Rick,, I forget when posting what is habit to me may not be to others beerchug
1980 CBX
1970 HD FLH
1976 HD FX
1983 HD FXRT
1970 AMC Javelin
sfhess
PostPosted: Tue Aug 25, 2015 9:38 pm Reply with quote Back to top
Too bad they couldn't move the threaded hole where the negative cable attaches to the frame so it can be removed without lifting the gas tank.
PostPosted: Tue Aug 25, 2015 9:46 pm Reply with quote Back to top
Cool
Wayne750F
PostPosted: Tue Aug 25, 2015 9:51 pm Reply with quote Back to top
Shawn_Mc wrote:
Cool
I use Petroleum jelly on the side cover grommets...it makes the side covers easy to take on/off and helps keep the rubber plyable....
1983 Red CB1100F
1991 Suzuki GSXR1100
1993 Yamaha FZR1000
PostPosted: Tue Aug 25, 2015 10:58 pm Reply with quote Back to top
I've spent years nailing down and eliminating many and with considerable success. However IMO and overall they are better than what else was around at that time.
But it is interesting to see what people will post up on this question.
PostPosted: Tue Aug 25, 2015 11:00 pm Reply with quote Back to top
Wayne750F wrote:
Shawn_Mc wrote:
Cool
Added to this is a tip I learned from Wamkap and Chico: attach the two sidecovers together with one of those tiny bungee cords. When you make it easier to remove the sidecovers, they might depart the fix at an inopportune moment. This will at least keep them attached to the bike. On stock covers there's a space to insert a tie wrap which can then be used to hook the cover. The new covers on the beast feature solid tabs which will require a bit of engineering to attach a bungee to...
deandeib
PostPosted: Tue Aug 25, 2015 11:25 pm Reply with quote Back to top
cliffiec wrote:
Wayne750F wrote:
Shawn_Mc wrote:
Cool
Rick,
I like the idea but having trouble visualizing the exact method you're describing.
deandeib
PostPosted: Wed Aug 26, 2015 12:46 am Reply with quote Back to top
deandeib wrote:
cliffiec wrote:
Wayne750F wrote:
Shawn_Mc wrote:
Cool
Rick,
Here are a couple of pics to illustrate the method.
The first picture shows the tie wrap attached to the hollow pin of the side cover. (Note here that these tie wraps get brittle with age, and should be changed out periodically, to prevent the tie wrap failing).
The second photo shows the two sidecovers tied together with the small bungee. Obviously, the bungee goes through the frame, just forward of the rear tire, to connect the covers one to the other.
When removing the sidecovers I just let them hang from the bungee cord, being careful not to let the wind make them flap.
Another tip when placing a sidecover on the bike: DO NOT "slap" the cover with the heel of your hand to seat the pins into the grommets! We all know where the pins are located on the back of the cover, push gently in these areas to seat the pins one at a time.
zealous
PostPosted: Wed Aug 26, 2015 1:05 am Reply with quote Back to top
Frusting hard starting in the early days with OEM batteries Today now all the cranking power needed
Very reliable other than 1 stator melt down
PostPosted: Wed Aug 26, 2015 1:20 am Reply with quote Back to top
This is almost like a sport, almost like what is there to not develop a hate for on these bikes? OK, that's a bit much, but here's a few of my peeves.
Charging rotors fail far too frequently and take out the crappy regulator that has no short circuit protection. DUH!
The stock ignition systems suck and will barely run on battery voltage without a working charging system. The sucky ignition is also the main reason so many guys foul so many plugs, as they barely produce any spark at all during cold start cranking when the battery voltage gets sucked down. So they get flooded, then fouled.
To specify further
    Pulse Generators in the oil??? That's a good idea? Really?
    Ignition modules that puke the potting compound?
    Coils that pretty much sucked brand new
    Way too much wire and connections in the ignition and coil power feed
Carburetors are a royal pain in the ass to install and remove. In all fairness, when these bikes were designed and built, the pump fuel used to last much longer without turning to shit. But the carbs are still a PITA. It's one of the reasons I went ahead and changed to Mikuni Smoothbores in the 80s.
Not being able to get the head off without removing the motor is really pretty lame, as is the removable frame piece in order to remove the motor. Jeeberz!
And the center cylinder stud channels between the cylinders on each side through the cylinder blocks on the '83 1000 and 1100 bikes that are open at the top but have no drain is really a good one. It causes the cylinder head studs to rust and rot until they are so fused to the cylinders you can't get them off without heroic measures! A few holes drilled in the bottom would have saved them a lot of real engineering embarrassment, they should be humiliated for designing such a failure.
I'm sure there are more, but those are some of my favorite peeves. Really Mad
Wayne750F
PostPosted: Wed Aug 26, 2015 1:35 am Reply with quote Back to top
No Gene, I think you about covered all the bases pretty well there....but we still love our bikes....
1983 Red CB1100F
1993 Yamaha FZR1000
PostPosted: Wed Aug 26, 2015 1:50 am Reply with quote Back to top
Well yeah, better the devil you know. Wink
PostPosted: Wed Aug 26, 2015 3:27 am Reply with quote Back to top
Honda designs by committee. The lack of holes are ridiculous,make the solid aluminum around ALL the bolts to the top.
The head wont come off in the frame because the cam chain tensioner is taller than the rest and hits the frame tube.
PostPosted: Wed Aug 26, 2015 4:07 am Reply with quote Back to top
+1
My method is to remove the igniters first (which lessens the pain a little).
PostPosted: Wed Aug 26, 2015 4:11 am Reply with quote Back to top
Wayne750F wrote:
Shawn_Mc wrote:
Cool
Agree. In addition, my theory is that if the grommets are lubed, it's easier to get a 'positive' fit with the cover so less chance the cover will fly off accidentally, even though it will pull of easier.
PostPosted: Wed Aug 26, 2015 6:28 am Reply with quote Back to top
they didn't make a CB1100R in volume for the mass's - never did work out Honda marketing strategy, gorgeous bike that performed in a different class, that scooped up dam't near every production race series - that you could then go an tour on - and what did they do ? - built a V4 - mad
RobHondaCB
PostPosted: Wed Aug 26, 2015 6:29 am Reply with quote Back to top
Two at the rear end at the signallights and two behind the site covers Smile
Honda CB750F2 '79
Honda CB900Fd '84
Stueecat
PostPosted: Wed Aug 26, 2015 7:32 am Reply with quote Back to top
1983 euro 1100's and 900's have a rear passenger grab rail that that's attached to the rear cowl and bolts to the frame.
bobcat7
PostPosted: Wed Aug 26, 2015 7:33 am Reply with quote Back to top
piss and moan. these bikes are easy to work on.
my 900 (since built) is 21 years old now. no problems
with any of this.
PostPosted: Wed Aug 26, 2015 12:40 pm Reply with quote Back to top
The CB1100R in volume for the masses was the CB1100F. The decision to go V4 for the large street bike program was made in 1980, before the R was successful in racing.
PostPosted: Wed Aug 26, 2015 12:42 pm Reply with quote Back to top
Really Mad
I would agree with this. Almost every hobby mechanic will take the carbs off at one time or the other. And squeezing these things in between the airbox and the cylinder head is a nightmare.
