  • Total: 123,208,968
  • Today: 205,384
  • 09:59 pm PST
MatBirch
PostPosted: Mon Jun 15, 2015 3:35 am Reply with quote Back to top
Ok- so I've been around here several years, read A LOT!, and learned a ton of stuff.
I'm having some starter troubles and wondering if I could get some facts as opposed to generalized opinions. Sorry, but I think people often just repost what they read without having any facts or first hand experience. I know I've been guilty...
I read that the 750 starter, apart from not having the bearing in the back, is..."not as robust", "Weaker", "not as much torque".
How much? How different? Real world- What kind of results would I get from using a 750 starter in my fresh 985? Is it mostly just a lifespan/ serviceability issue with the bearing and such? What makes the 900/1100 starter "stronger"? They are the the same size, shape, etc. share the same brushes... No further gear reduction
Unfortunately, the 900 motor that was purchased to be built into the 985 came to me with a 750 starter, so I have two of those. Back in the day, when I first got my bike, I was having the standard hot start issues, so I cleaned and rebuilt it. It had been perfect ever since. When I first tried to crank the 985, I began suffering huge voltage drop issues, charging problems, etc. I built some new cables for the starter leads and battery leads from really high quality #6 SRML stranded copper. Crimped lugs, heat shrink ends, etc. high quality stuff!! I replaced the solenoid, and serviced/inspected every point in the system. Repaired an issue in the stator cover causing brushes to bind resulting in no charge. All is good.
My remaining symptom is that the starter will crank over perfectly...once. If it doesn't fire, future attempts are limited to a series of quick taps of the button, hoping that one of the attempts will catch the right point on the motor's stroke, that it wil continue to crank over, and hopefully... Fire. With each attempt, the battery drops further and further until it won't crank. Hasn't left me stranded, but I have had to push start it a time or two.
It feels just like the old hot start problem, so I ordered another set of new brushes. I checked everything out tonight, and three sets of brushes all test exactly the same on the meter. Size is not a problem on either used set. Now I hesitate to put new brushes in this motor if it won't help.
Oh- dumb old me took both starters completely apart to test. Which post does the insulated brush go on?? Rolling Eyes
MatBirch
PostPosted: Sun Jun 21, 2015 5:27 am Reply with quote Back to top
Well, did I piss everybody off with my comment?
Anyway- I now have my empirical evidence. I went ahead and bought a 900 starter, and cleaned it up and put my new set of brushes in.
I have no way of measuring torque or horsepower here at home, so I just installed it and pushed the button. It indeed cranks and cranks and cranks! Far harder and faster than the 750 starter.
There you have it!
mhewitt
PostPosted: Sun Jun 21, 2015 7:28 am Reply with quote Back to top
There you have it!
I didn't see the original post, but can tell you that the same overall envelope size electric motor can have wildly differing torque characteristics depending upon wire gauge and number of turns. As to specifically 750/900/1100 starter motors - I have no idea.
cbxdog
PostPosted: Sun Jun 21, 2015 7:53 am Reply with quote Back to top
The 750 is rated at .7KW,, the 1100 is .8 KW
1980 CBX
1982 CB1100RC - basket case
1970 HD FLH
1976 HD FX
1983 HD FXRT
1988 FX 85th anniversary
1970 AMC Javelin
1982 AMC Spirit 360 5 speed
PostPosted: Sun Jun 21, 2015 3:41 pm Reply with quote Back to top
The numbers are written on the outside. Not to mention the ball bearing which turns with less load.
MatBirch
PostPosted: Sun Jun 21, 2015 4:14 pm Reply with quote Back to top
Where is this info available? Just curiosity at this point, as the problem is solved. In my digging before, in an attempt to be a tightwad and not pony up for another starter, I could not find anything.
Thanks!
MatBirch
PostPosted: Sun Jun 21, 2015 4:38 pm Reply with quote Back to top
You mean the numbers were written on the outside Very Happy Other than the "438" the only thing on the outside of any of my three starters is 30 year old crust!
I understand the bearings, but the world has built millions of things with bronze bushings and they work very,very well. While bearing are more efficient, longer lasting, run cooler, etc., etc., there is no way that I'd believe the bearings in this case would make up the difference in getting this engine to crank over. That's why I brought this up. I couldn't any info like cbxdog posted above with actual specs or even anyone who said- "I had a 750 starter in a 900/1100 and it would not work, put a 900/1100 starter in and it did work". All I could find were lots of comments that seemed very much like here say. Forums also being what they are, folks are pretty bad at times to return and post the answer when they find a fix. When I'd find those "here say" comments, nobody came back to to say that it solved the problem, or even say thank you.
So...
It solved the problem, and-
Thank you, guys!
Cool Cool
And Happy Fathers Day to all of you!
Stueecat
PostPosted: Sun Jun 21, 2015 5:10 pm Reply with quote Back to top
Hi MatBirch.
When I had starter problems with my 1100 I investigated the starter, I stripped it down and found I had a 750 starter, I rebuilt it but was still a bit slow and it would still stall occasionally when trying to start the bike. I sourced a proper 900 starter (438) and gave it a quick strip and clean, but didn't replace any parts as the bearings and bushes were all good. I can confirm I've had no starter issues since, it spins a lot more strongly than the 750 unit and never stalls.
438 is Honda's code for 900 specific and is the easy way to identify parts such as the starter easily.
MG5 identifies 1100F specific parts.
I'm not sure of the code for 750 specific parts I'm afraid.
Cheers Stu
1983 Red CB1100F2D (CDN)
PostPosted: Sun Jun 21, 2015 5:27 pm Reply with quote Back to top
Stueecat wrote:
Hi MatBirch.
Cheers Stu
425 is the 750 code.
Cary
PostPosted: Sun Jun 21, 2015 11:18 pm Reply with quote Back to top
MatBirch
PostPosted: Mon Jun 22, 2015 12:12 pm Reply with quote Back to top
Ok, got it. Thank you!
I was looking for some kind of foil(?) label on the side of the body. The end cap just sat upside down on the bench or in my hand being cleaned.
