  • Total: 110,216,786
  • Today: 93,144
  • Jun 23, 2026
  • 04:47 pm PDT
Richlkyl000
PostPosted: Thu Jan 15, 2015 6:00 am Reply with quote Back to top
I figure I have the stock 70mm bore. Like title says I need rings. Tried total seal, npr, wiseco, summit etc. Will any 70mm rings works on these bikes or do I need to find a company that has them for my bike?
PostPosted: Thu Jan 15, 2015 7:22 am Reply with quote Back to top
Cms has them.
PostPosted: Thu Jan 15, 2015 2:23 pm Reply with quote Back to top
Cruzinimage, Ebay..
http://www.ebay.com/itm/83-Honda-CB1100F-Standard-Piston-Rings-Set-4-rings-Set-Include-CB1100FPR-/141438889196?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item20ee6a2cec
1979 Modified CBX
1982 Modified CB-750/1100F
1980 Modified GS1000GT
PostPosted: Thu Jan 15, 2015 8:40 pm Reply with quote Back to top
Just because it is 70mm bore does not mean the rings will fit. Hardest thing is the oil ring but the rings are a certain thickness also.
On 1100 the oil ring is .098 thick and that has not been made for 20 years. All the piston companies make them .108 now. Plus all the rings are a variety of thickness as well.
Big clue is bore the engine to 1123.
Richlkyl000
PostPosted: Thu Jan 15, 2015 9:43 pm Reply with quote Back to top
Yes i was worried about the oil ring size. i think i would use the wiseco kit. If i run the 1123 kit what jetting should i do with the carbs? or do i even run the same carbs?
PostPosted: Thu Jan 15, 2015 10:08 pm Reply with quote Back to top
Again CMS has them. NOS.
http://www.cmsnl.com/honda-cb1100f-super-sport-1983-usa_model1026/partslist/E++14.html#results
