  • Total: 114,967,668
  • Today: 5,323
  • Sep 22, 2026
  • 02:40 am PDT
PostPosted: Wed Oct 08, 2014 12:46 am Reply with quote Back to top
New custom made 20mm rear axle long enough to span the TL's width, new pivot bolt spacer's/bushings, modified axle adjuster blocks with axle reducer bushings, shock mount shouldered bushings, and a new axle nut but it's not here yet.
PostPosted: Wed Oct 08, 2014 12:58 am Reply with quote Back to top
Awesome!! Shocked Shocked
zealous
PostPosted: Wed Oct 08, 2014 1:20 am Reply with quote Back to top
Beauty what is it Smile
PostPosted: Wed Oct 08, 2014 2:09 am Reply with quote Back to top
Looks like a cable stirrup for a damn bridge!
Stout....
hogwild113
PostPosted: Wed Oct 08, 2014 2:30 am Reply with quote Back to top
Are you making axles now? I'd like to have one made for my Metamachex. I have the original but threads on it and nut are not trustworthy. If someone else is making them, can you share the contact?
Also curious in the price..
The swing arm looks great!
Thx
PostPosted: Wed Oct 08, 2014 3:39 am Reply with quote Back to top
Galen. How long and what's the head look like?
erock419
PostPosted: Wed Oct 08, 2014 3:40 am Reply with quote Back to top
Stout....
LMFAO! No kidding!
Awesome work Jim! Looking forward to some pics of these beefy swingarms on an F
hogwild113
PostPosted: Wed Oct 15, 2014 12:24 am Reply with quote Back to top
I've misplaced the axle. I think it's in one of my boxes of stuff. I'll have to dig it out to get the length. It has a hex head. Here's a pic of it next to a 1100F axle. Thanks..
Andylarkin
PostPosted: Wed Oct 15, 2014 10:54 am Reply with quote Back to top
Hey Jim, do you fancy making 2 of those as I need exactly the same thing? As long as Hog doesn't mind me piggybacking his order?
Very Happy Very Happy Very Happy
hogwild113
PostPosted: Thu Oct 16, 2014 2:37 am Reply with quote Back to top
Andy, no prob. The more, the merrier. I know mine is in the shop somewhere. I haven't thrown anything away in years. Maybe that's why I'm having an extension built onto my shop....
PostPosted: Thu Oct 16, 2014 4:23 pm Reply with quote Back to top
I worked on the same arm a couple months ago.
The head used an Allen head if I remember right?
I will need the length from the head to the start of the threads and the length of the threads. Also the OD of the head. I don't want to guess and make a paper weight. I already have a bin full of whoops start over and one is a GSXR steering stem that I still don't know how I will correct. I think it's time to start making steering stems and they will be made from aluminum. I hate steel.
hogwild113
PostPosted: Thu Nov 06, 2014 11:50 pm Reply with quote Back to top
Well, I looked through all my boxes of parts in the shop and couldn't find the axle. I came in the house and mysteriously, my brain started working. I moved two bags of shop rags here in my back office and the axle was under them... I took pics and will email to you..
WileCyot
PostPosted: Fri Nov 07, 2014 4:41 am Reply with quote Back to top
What does something like this run by chance?
Andylarkin
PostPosted: Fri Nov 07, 2014 10:48 am Reply with quote Back to top
Hog, did your axle have some form of pin in there, before each alloy 'spinner'. I can't think of the best way to describe it?!
If so, how did you get it out?
Confused
hogwild113
PostPosted: Sat Nov 08, 2014 6:10 am Reply with quote Back to top
I'm wondering if you mean 'keyed'? Both sides were keyed. I'm not sure why, it's the only axle I have seen that was keyed either on one or both sides.. I can take/post more pictures if you have more questions/concerns.. The outside 'spinner' on both sides were keyed too..
hogwild113
PostPosted: Sat Nov 08, 2014 6:53 am Reply with quote Back to top
Keyed spinners...?
PostPosted: Sat Nov 08, 2014 6:44 pm Reply with quote Back to top
Galen the arm I worked on just like yours did not have the keys but I can do that for you if needed?
I go pick up a bunch of axles this week and think that my TL axles will work for you?
Time will tell.
hogwild113
PostPosted: Sat Nov 08, 2014 9:53 pm Reply with quote Back to top
I don't see any reason for them being keyed. I think it'll be fine with out it.
PostPosted: Sat Nov 08, 2014 10:23 pm Reply with quote Back to top
With it keyed can't you use the bolt head to turn for chain adjustment ?
PostPosted: Sun Nov 09, 2014 5:14 am Reply with quote Back to top
This makes sense. If I remember correctly? The one I did for Erock was a bitch to adjust evenly. I would say the key is key.
Andylarkin
PostPosted: Sun Nov 09, 2014 11:38 am Reply with quote Back to top
Thats what I meant mate, just couldn't for the life of me think how to explain it.
I'm thinking they are there for a reason though… as Luckysox said, it allows you to adjust by loosening off the clamp bolts that hold the spinners secure and simply turning the axle doesn't it? Orr have I got that wrong?
PostPosted: Sun Nov 09, 2014 8:45 pm Reply with quote Back to top
You are correct Andy. Plus it adjusts both side at the same time. I should have something for this very soon.
PostPosted: Sun Nov 09, 2014 9:22 pm Reply with quote Back to top
Yes my friend had one on his Z1000R I rebuilt for him a few years back, does make adjustment easy, just loosen the 2 allen screws and turn the nut
hogwild113
PostPosted: Mon Nov 10, 2014 12:58 am Reply with quote Back to top
My Cal Fab axle isn't keyed and it's really easy to adjust the chain. I stick the largest allen wrench in the hole directly across from the axle, stick a screw driver in between them and rotate it around. It went around and adjusted the chain easier than I thought it would. I was thinking I would just use the allen head and axle head and do the same thing on this swing arm.
But, I do understand your explanation and see how it would work that way..
PostPosted: Thu Nov 20, 2014 12:31 am Reply with quote Back to top
Hi Galen,
I went and got my axles and unfortunately they are 13.25" long. So they won't work for your arm. When I ordered 20 of the front axles It was half the price of the 6 rears that I just ordered. A one of would be close around 100.00 I bet. If your game? I'll see about getting you one done.
Or you may get lucky. I just got a brand new lathe chuck that isn't sprung like my old one. So I may be able to make axles now without getting cutter chatter? I will give it a try asap and see if I can help you out?
hogwild113
PostPosted: Fri Nov 21, 2014 6:27 am Reply with quote Back to top
Email sent...
Goodfoodcrew
PostPosted: Mon Dec 08, 2014 6:25 am Reply with quote Back to top
Whoa was directed here in getting a new swing arm for my bike. This is super awesome man!
Page Generation: 0.24 Seconds
