  • Total: 110,216,806
  • Today: 93,164
  • Jun 23, 2026
  • 04:48 pm PDT
Richlkyl000
PostPosted: Wed Sep 17, 2014 3:57 am Reply with quote Back to top
Has anyone ever drilled the return hole on the master cylinder larger? I dont think it would change much except the fluid could return faster to the reservoir. Question
PostPosted: Wed Sep 17, 2014 4:30 am Reply with quote Back to top
The main is large enough. The "release hole" is small for a reason. Someone tried it and it made the master cylinder have a dead travel to work.
Richlkyl000
PostPosted: Wed Sep 17, 2014 4:37 am Reply with quote Back to top
sonicrete by dead travel to work do you mean that basically if you start to apply pressure to pedel it will have no travel or real feel to the pedal because there is no back pressure? Sorry if that confusing.
PostPosted: Wed Sep 17, 2014 8:41 am Reply with quote Back to top
It was designed to work correctly with the small hole, so best to leave it as is, just keep it clear.
PostPosted: Wed Sep 17, 2014 6:29 pm Reply with quote Back to top
I travels "dead" as in no pressure and travels to give more lever play.
PostPosted: Wed Sep 17, 2014 10:18 pm Reply with quote Back to top
When you first push on the pedal or pull the lever, the small hole is still exposed. If it's too large it lets too much fluid rush through the hole as you move the piston the first bit until you're past it. Keeping the hole small, it tends to not flow too much, and so once the piston is past it you haven't lost a bunch of lever and fluid to just emptying the line, so you can build pressure sooner on the piston travel, and have a "higher" pedal or lever action.
Richlkyl000
PostPosted: Thu Sep 18, 2014 12:47 am Reply with quote Back to top
Okay thank you guys. Well that settles that.
