  • Total: 110,584,461
  • Today: 62,923
  • Jun 27, 2026
  • 01:27 pm PDT
PostPosted: Fri Feb 14, 2014 10:34 am Reply with quote Back to top
Talk about a "Franken-bike" !!!
Cheers!
http://www.motorcyclemojo.com/2014/03/cb750feature
metalganz
PostPosted: Fri Feb 14, 2014 12:00 pm Reply with quote Back to top
I don`t like it,seems that it was important to use parts from different bike`s as much as possible.
Have no doubt about the technical skills of the builder.Gracias but No gracias
PostPosted: Fri Feb 14, 2014 12:39 pm Reply with quote Back to top
I agree, a build gone bad!!!
Cheers!
PostPosted: Fri Feb 14, 2014 12:46 pm Reply with quote Back to top
Yep, no consistent theme there - looks like something ctluba might build if he had an unlimited budget Razz
kenc42
PostPosted: Fri Feb 14, 2014 1:40 pm Reply with quote Back to top
But it has a turbo! Controlled by a hot water valve?
MinnesotaF
PostPosted: Fri Feb 14, 2014 1:51 pm Reply with quote Back to top
Good one! I do like the front end though.
PostPosted: Fri Feb 14, 2014 2:01 pm Reply with quote Back to top
I agree with the assessment of the "theme" of the build. It's all over the place.
However, the lines of the bike aren't horrible for what it is..Many guys do way worse these days, and seem proud of what they've done.
IMO, the vast majority of bobber bikes go horrible wrong. Cafe bikes can be sharp but many go Horribly wrong as well....
Seems that many don't understand that the DOHC "F" taillight is part of the look of the bike..Removing that signature tailight and keeping the F tail is where many go wrong right off the bat...
PostPosted: Fri Feb 14, 2014 4:41 pm Reply with quote Back to top
All that work...and he leaves the front end just hanging.....it ruins what could be a hell of a machine.....
Nice circa 1987 Lee Iaccoca TURBO emblem too..... Rolling Eyes
I bet it would be a hell of a ride!!!!
PostPosted: Fri Feb 14, 2014 6:20 pm Reply with quote Back to top
Quote:
After outfitting the head with stainless steel valves, high-performance valve springs and a modified cam, he moved on to install 8:1 high-compression MTC pistons. With that much compression, heavy-duty barrel studs and copper gaskets helped to keep the head attached tightly to the block.
Unless he's running 50 pounds of boost, that isn't high compression. The other stuff is standard forced induction practice. Journalists are funny Laughing
A modified cam can just be wider lobe centers for the turbo. 112-114 is common. There's so much weirdness there, I don't even have an opinion on the styling.
rapidfire1
PostPosted: Fri Feb 14, 2014 11:57 pm Reply with quote Back to top
Put a stock length tail and a different headlight, add a front fender and I think its sweet.
