  • Total: 118,134,745
  • Today: 6,761
  • 01:41 am PDT
jonathan
PostPosted: Mon Oct 21, 2013 6:31 pm Reply with quote Back to top
Hi
Will the early 'naked' bodywork fit on the later pro link bike? Apparently later bikes are much 'better' to ride but I prefer the early look. Just ridden a CBX for the first time; what an engine!
CB 900fz 1979
CB 900fd 1983
CB 1100fd 1983(sold)
CBX 1000z 1979(sold)
CX 500z 1979
CX500c bobber!
CB900/1100 project
Moto Guzzi 850 Le Mans
XR400R
cbxdog
PostPosted: Mon Oct 21, 2013 9:22 pm Reply with quote Back to top
jonathan wrote:
Hi
I don't think so,, the 81 / 82 pro link is a different animal than the 79-80.. The 1981 / 82 fuel tank, seat and side covers and frame are very different than the Z / A models.
More knowledgeable X'ers will likely chime in and conclusively clarify.. Good thoughts though, I always preferred the dual shock 79/80 X
1980 CBX
1982 CB1100RC - basket case
1970 HD FLH
1976 HD FX
1983 HD FXRT
1988 FX 85th anniversary
1970 AMC Javelin
1982 AMC Spirit 360 5 speed
cbxsix
PostPosted: Mon Oct 21, 2013 10:36 pm Reply with quote Back to top
Like cbxdog said no, nothing mounts the same but naked 81/82's are becoming more popular because of their availability and prices.
You can get CB750/900/1100 body work to fit on a 79/80 CBX though.
PostPosted: Tue Oct 22, 2013 1:08 am Reply with quote Back to top
Hopefully, Phil will be along today.
Pretty sure he has a friend who has done the swap.
Jonathan you could always just go with a naked Prolink.
jonathan
PostPosted: Tue Oct 22, 2013 8:00 am Reply with quote Back to top
Many thanks for the replies. It seems not then. I must admit I guessed it was going to be a straight swap. If I remember correctly the pro link was a way of carrying the 6 on with an update to keep it interesting. Budgets being what they were I assumed that they had kept the basic frame the same to save money. If Phil knows better I'd be interested even if there is some work to alter the frame. I'm afraid I just don't like the pro link body at all, sorry to fans!
Thanks again
Jonathan
CB 900fz 1979
CB 900fd 1983
CX 500z 1979
CX500c bobber!
CB900/1100 project
XR400R
cbxsix
PostPosted: Tue Oct 22, 2013 1:53 pm Reply with quote Back to top
jonathan, I don't think anyone is telling you it can't be done, it just isn't a popular swap but I'm sure it's possible with a little time and money invested.
PostPosted: Tue Oct 22, 2013 6:17 pm Reply with quote Back to top
The early tank will go on fairly easy. The sidecovers and the seat will require some work, not too bad, though. The rear "subframe" of the later Prolink models is quite different.
Another issue will be the wiring harness if you eliminate the fairing. The connections that sit in a box behind the headlight need a new space. The early CBXes have a lot of the connections in the headlight.
The whole conversion is not that difficult, considering the modifications people do to their bikes.
cbxsix
PostPosted: Tue Oct 22, 2013 6:50 pm Reply with quote Back to top
Jonathan it's like any other build, it's probably a good idea to take a step back and do the build on paper first. Figure in the coast of the late model CBX, the cost of the early model body work (not cheap for nice stuff) the early model seat, and most likely the cost of a replacement late model shock because if the late model CBX doner is still running the OEM shock it's most likely toast, then add in the cost of the modding.
It adds up quick!
jonathan
PostPosted: Wed Oct 23, 2013 8:08 am Reply with quote Back to top
Good points, well made. Basically do-able but possibly expensive?
Let me ask a follow on question then...... Is the pro link/later ride so much better that it is worth doing? Especially bearing in mind that the end result is probably not going to be worth as much as either original model.
Jonathan
CB 900fz 1979
CB 900fd 1983
CX 500z 1979
CX500c bobber!
CB900/1100 project
XR400R
PostPosted: Wed Oct 23, 2013 11:30 am Reply with quote Back to top
jonathan wrote:
Let me ask a follow on question then...... Is the pro link/later ride so much better that it is worth doing? Jonathan
In my opinion: Different but not that much better. Bear in mind that the basic concept of the bike changed. It morphed from a "Superbike" to a "Sport Tourer".
Yes, the fork is beefier and has air assist (something that is controversial regarding the advantage) and the rear suspension is much improved. But the unsprung masses are bigger and the steering is a little heavier.
PostPosted: Wed Oct 23, 2013 12:27 pm Reply with quote Back to top
Here's a photo of my latest ground-up build of a late model CBX with a early model paint scheme (with liberties).
I'm in the process of doing another one, send me your color choice with a deposit check and it'll be your's in the Spring.
BTW, I'd be remiss if I didn't invite you to come over to CBXWorld[dot]com
to join in on all the fun there.
CBX-tras LLC
jonathan
PostPosted: Thu Oct 24, 2013 5:07 am Reply with quote Back to top
If you can do it with the early bodywork I might just do that!
Nice job on the one in the picture by the way
Cheers Jonathan
CB 900fz 1979
CB 900fd 1983
CX 500z 1979
CX500c bobber!
CB900/1100 project
XR400R
PostPosted: Thu Oct 24, 2013 5:15 am Reply with quote Back to top
If per chance you do decide to do it....pick up a twin shock frame and use it as a guide for what to do.....
I have seen some nice phantom Pro-Links out there and they are cool.....
