  • Total: 112,534,025
  • Today: 28,442
  • Jul 28, 2026
  • 04:01 pm PDT
letershake
PostPosted: Fri Sep 20, 2013 1:14 am Reply with quote Back to top
Looking for someone who isn't afraid of phone calls instead of emails. I need some information on what kind of inverted front forks as well as mag rims I can use off of another bike. I also want to run a wider rear rim and tire, I know i will have to get the wide race style counter sprocket to do this. I have absolutely NO idea of just where to start. I need some help. Thanks, Steve in Houston, Tx. 713-504-8414
PostPosted: Tue Sep 24, 2013 6:36 pm Reply with quote Back to top
Do a search on here. There are several bikes you can scavenge from, but nothing is really a "bolt on". Youre going to need to convert a stem and a top clamp at a minimum.
PostPosted: Tue Sep 24, 2013 7:38 pm Reply with quote Back to top
Check out member ctluba's "Punisher" and the build thread from MikeG......
MikeG
PostPosted: Wed Sep 25, 2013 2:14 am Reply with quote Back to top
I didn't do inverted forks.Check ctluba for that. He is a fearless fabricator! His name is Steve too.
spike
PostPosted: Mon Sep 30, 2013 12:10 pm Reply with quote Back to top
A set of 93 GXSR forks work well. Almost a bolt on press out GXSR stem and press in the 9 stem 9 bearings and bolt it on. The fabrication comes in with the steering stop headlight bucket and the gauge cluster. Providing you use a complete front end clip ons,wheel and all. One day job, that's providing you have everything.
Three of a prefect pair
