  • Total: 118,206,955
  • Today: 78,971
  • 07:30 pm PDT
two-stroke-brit
PostPosted: Wed May 08, 2013 5:20 pm Reply with quote Back to top
I saw a uk bike that had seperate handle bars that looked to cast alluminium.(mounted straight to the fork tops)
which i like the look of more so than us chrome bars.
what would be needed to swap over to the uk spec bars .i guess the riser bar would go to.
anybody got a good pic showing the differance would be appreciated.
T I A mark
She may not be pretty but always a fun ride.
1973 suzuki GT750
1973 kawasaki H1 500.
1982 honda CB900F
PostPosted: Wed May 08, 2013 7:15 pm Reply with quote Back to top
The fork tubes are longer in the Euro bikes. If you slide up your tubes in the triple clamps to have room to clamp the handlebars, you will drop the front end and effectively shorten the trail. May make for a scary ride.
two-stroke-brit
PostPosted: Wed May 08, 2013 7:38 pm Reply with quote Back to top
not really what i am after (a scary ride) .
thanks for the info.
cheers mark
1973 suzuki GT750
1982 honda CB900F
Last edited by two-stroke-brit on Wed May 08, 2013 7:39 pm; edited 1 time in total
PostPosted: Wed May 08, 2013 7:39 pm Reply with quote Back to top
The bars were the same as the CBX.....long or short available....
You could run CBX forks as well....depending on the year.
79-80 35mm
81-82 39mm
Might make it easier to find here......although Wout may have what you need.
two-stroke-brit
PostPosted: Wed May 08, 2013 7:40 pm Reply with quote Back to top
jebby i will call tonite for a chat if thats ok.
thanks mark
1973 suzuki GT750
1982 honda CB900F
PostPosted: Wed May 08, 2013 8:22 pm Reply with quote Back to top
thanks mark
Sure.....
PM sent
PostPosted: Wed May 08, 2013 8:32 pm Reply with quote Back to top
This is correct.....I have seen a euro spec 900 on another site and the bars, and forks would work.....the cluster
is very similar too....the "Mickey Mouse" style.....but no volt gauge....
Mark....I believe the CBX sport kit bars are the equivilant to the 900 euro.....
They look nice....have a pair on Ken's bike and they were Powder Coated....different look.
cb1187
PostPosted: Wed May 08, 2013 8:36 pm Reply with quote Back to top
PM sent on fork tubes.
cheers mark
two-stroke-brit
PostPosted: Wed May 08, 2013 8:39 pm Reply with quote Back to top
hi jebby do you have a pic or link to "ken's" bike
thanks mark
1973 suzuki GT750
1982 honda CB900F
PostPosted: Wed May 08, 2013 8:46 pm Reply with quote Back to top
Not really any good ones of the bars....but here is the parts back from Tom K.....
The bars are toward the center.....
I can take some better ones later.....
PostPosted: Wed May 08, 2013 9:27 pm Reply with quote Back to top
Jebbysan wrote:
[Mark....I believe the CBX sport kit bars are the equivilant to the 900 euro.....
Darn, Jebby, here we disagree once again. And I thought we were on a path to agreement. Rolling Eyes Razz
The 900F Euro bars are different from the CBX Euro or Sport Kit bars. The locator pin is in a slightly different position and the bar angle is different.
They will work but you will have to accept a different angle.
The 900F bars have a -438- part number and the CBX ones a -422- or -MA2-.
FalldownPhil
PostPosted: Wed May 08, 2013 10:25 pm Reply with quote Back to top
I believe that Rob is correct here. I personally like the feel of the 900F Euro bars.
Best,
Phil
Phil
Many CBX's
PostPosted: Wed May 08, 2013 10:49 pm Reply with quote Back to top
DOHCRob wrote:
Makes sense....but they would work eh'?
But I will stand on the Pro Link CBX forks...the triples are different due to the vented brakes but the actual
forks will work fine....Dan (kcdaniels) set this up for twin piston calipers and had to use a 900 tree.....
two-stroke-brit
PostPosted: Tue May 14, 2013 1:21 am Reply with quote Back to top
cheers mark
i got the pm but i am unable to open it at the moment.
debug something , hopping its like wind and will pass if i wait.
cheers mark
1973 suzuki GT750
1982 honda CB900F
mikerobpen
PostPosted: Tue May 14, 2013 10:39 am Reply with quote Back to top
If anyone would like to try the euro handlebars, I can supply them. I have a number of sets in 39mm, 37mm and 35mm.
They should work with the existing top yoke. They do have locating pins, but as and when needed I have removed the locating pin to give more options on position.
Mike Smile
My 900f Special
