  • Total: 123,555,707
  • Today: 34,723
  • Nov 25, 2026
  • 03:26 am PST
indison
PostPosted: Wed Mar 06, 2013 10:13 am Reply with quote Back to top
any good places to get shims from in Australia?
and what type of car did these same sized shim come out of again?
norm
PostPosted: Wed Mar 06, 2013 8:35 pm Reply with quote Back to top
bugger all chance in Aust I did find a bloke in Preston Vic who makes them but they cost about $10 each Ended up grinding my own. You may be able to get somebody to grind them for you up there but the problem is you can only remove one at a time.
PostPosted: Wed Mar 06, 2013 9:17 pm Reply with quote Back to top
http://www.precisionshims.com.au/a/Precision-Shims-Australia
norm
PostPosted: Thu Mar 07, 2013 6:30 am Reply with quote Back to top
Thats the mob Don but $10 a shim and that was a few years ago
indison
PostPosted: Thu Mar 07, 2013 9:31 am Reply with quote Back to top
Damn it! Evil or Very Mad
gtomike
PostPosted: Thu Mar 07, 2013 2:35 pm Reply with quote Back to top
Check with John he had some for $3.00 each plus shipping from Canada
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=70020
norm
PostPosted: Thu Mar 07, 2013 9:25 pm Reply with quote Back to top
Indy Firstly you need some spare shims to mix and match with then measure all your clearances and write them down on your chart, work out if you can swap some to get a few correct, remember don't rotate the motor with any shim missing and in the end you might only need 10/12 shims, it is tedious this is why I ground my own, few hours and it was done
PostPosted: Fri Mar 08, 2013 12:05 am Reply with quote Back to top
They came in the old 1.6 DOHC Toyota 4 cylinder.....Corrola's and MR2's had this engine....
Circa 85-91
Dobbo
PostPosted: Fri Mar 08, 2013 3:00 am Reply with quote Back to top
I've got a 900 motor in pieces and have a couple of egg cartons with"SHIMS" written on them, I v'e not opened them up to have a look but if thats what you're after I'll have a look this arvo and let you know what I've got.
Dobbo.
indison
PostPosted: Fri Mar 08, 2013 9:27 am Reply with quote Back to top
Thanks guys, I dropped the motor off at my mechanics and he is stuffing around a bit and doesnt seem to keen on the time consuming shim opperation and didnt inspect the curved top guide like i asked.
so Im thinking of buying a stand and tackling the head myself... how hard can it be? at least ill save on labour, ive got my measuring tools will i need to break the cam chain to get at the curved top tensioner? and does anyone have threads on top end rebuilds?
Grumpy32
PostPosted: Fri Mar 08, 2013 1:25 pm Reply with quote Back to top
What method did you use to grind your shims? Any pictires? I am interested in doing that myselh, or @ least giving it a try...
norm
PostPosted: Sat Mar 09, 2013 1:49 am Reply with quote Back to top
Grumpy,
I explained how I did it some time ago but Sonic wasn't impressed, but it workes for me and that is all that matters to me. I don't rev my motors above 6000 so don't have any problems, I'll pm you the way I do it
PostPosted: Sat Mar 09, 2013 3:31 am Reply with quote Back to top
Well you can have a blacksmith do it which is a bench snag grinder on the side of the wheel. A big no no is grinding on the side of a wheel not made for it,never mind no way to keep them true.
Now doing it in a tool room with a Brown and Sharpe grinder magnetic chuck and all,no problem.
Now as to me no idea why you cannot find a basket load of shims on an engine 30 yrs old that are already same as a Toyota auto,Yamaha FJ,or late model Triumph motorcycle.
Now making one under what size can be easily bought is another thing.
I guess I do not understand because besides a regular machine shop I have a friend with tool room grinder in his garage. I also find it easier to just order them new from K&L,Procycle and other places. Besides I have a basket full of the normal sizes and you see collections on EBay all the time.
