  • Total: 123,555,559
  • Today: 34,575
  • Nov 25, 2026
  • 03:25 am PST
gtomike
PostPosted: Sun Mar 03, 2013 2:03 am Reply with quote Back to top
http://www.youtube.com/watch?v=GMWurGORq_8
PostPosted: Sun Mar 03, 2013 3:48 am Reply with quote Back to top
He sucks. I hate him.
Yes, I'm jealous as hell.
BobW
PostPosted: Sun Mar 03, 2013 6:41 am Reply with quote Back to top
Do you really have to pull the motor to check the valves?
1981 CB750F
2003 Ducati 800SS
2006 VFR800
PostPosted: Sun Mar 03, 2013 7:07 am Reply with quote Back to top
No but you need to pull the engine mounting plates.
As strange as this sounds you need to pull the motor to get the carbs out. Well not really but you take out all but the lower rear motor mount bolts and use the chain adjusters as a winch to lower the front of the motor.
At this point if you have a convienient engine stand maybe easier.
The first CBX I worked on I used the parts I had and made one. The flip over part strikes on top the clutch housing of the crankcase. Two L shaped brackets. I had made them too short for a 4 and the engine did not set level but were just right for a CBX.
bobcat7
PostPosted: Sun Mar 03, 2013 10:13 am Reply with quote Back to top
on the X I just use a scissor jack behind the oil filter
housing . the CBX is really not very hard to work on at all ! I love them and will own one as soon as I find the right deal !
redstedman
PostPosted: Sun Mar 03, 2013 12:53 pm Reply with quote Back to top
You don't pull the motor, you just tilt it forward. The engine is a main structure of the chassis. No frame tubes up front. I can do it in 10 min.
Very nice accurate piece by Jay. It truely is the best sounding motor in all motorcycles.
This may sound freeky but I dreamed of my CBX last night!
79 CBX
82 CB 900F
82 GS 1100E
83 CB 1123F
83 SP 100
Yamaha Razz
cbxsix
PostPosted: Sun Mar 03, 2013 2:00 pm Reply with quote Back to top
Yes, just tilt the motor forward. It's okay to use sonics method but now that these bikes are going on 35 yrs old you don't want to leave them tilted without a jack under the front of the motor, all that torque on the primary shaft seal isn't a good idea for prolong periods.
PostPosted: Sun Mar 03, 2013 8:39 pm Reply with quote Back to top
Seems I am lacking some of the basic understandings of the CBX motor. How does tilting the motor put torque on the primary shaft seal? Can you elaborate here?
PostPosted: Sun Mar 03, 2013 8:45 pm Reply with quote Back to top
Take out all the motor mounts and bolts except the lower rear ones. Now the only thing keeping the motor from falling out is the drive chain.
So by loosing the axel and unscrewing the chain adjusters you can lower it right down. The drive chain and with it the seal on the output shaft is under load. So it would be better to lower the engine down on to something. A floor jack still strikes but not flat due to the angle change.
PostPosted: Mon Mar 04, 2013 1:05 pm Reply with quote Back to top
sonicrete wrote:
The drive chain and with it the seal on the output shaft is under load. .
So he meant output shaft, not primary shaft. Got it.
PostPosted: Mon Mar 04, 2013 3:26 pm Reply with quote Back to top
To R&R the carbs on a stock CBX is about 3 hours with all the right equipment. The exhaust needs to removed since the mufflers aren't removable by themselves. Every control cable and adjustment needs to be touched.
We talked about Leno's video on the CBX site and he's off on several points.
The DOHC fours are much easier to work on in many respects.
CBX-tras LLC
PostPosted: Mon Mar 04, 2013 5:23 pm Reply with quote Back to top
On the early CBXes, the engine will tilt without the exhaust being removed, just detach the rear muffler mountings. On the Prolinks it will not work unless you have replaced the original exhaust and yours doesn't have a crossover.
redstedman
PostPosted: Mon Mar 04, 2013 8:14 pm Reply with quote Back to top
Sure it will, about 1 1/2" till the crossover hits the oil pan. Pipes got to come off.
79 CBX
82 CB 900F
82 GS 1100E
83 CB 1123F
83 SP 100
Yamaha Razz
cbxsix
PostPosted: Mon Mar 04, 2013 8:30 pm Reply with quote Back to top
Wow, you needed that explained to you or are you just an Ahole?
PostPosted: Mon Mar 04, 2013 8:44 pm Reply with quote Back to top
What is your problem?
Why are you calling people names when they point out something that you obviously screwed up?
You have done that before. You sem to have some unresolved childhood issues.
Do you know what a primary shaft is?
Or is it the same on your bikes as the output shaft?
How should I know that you weren't talking about the primary shaft.
You seem to know quite a lot.
Instead of saying: "Sorry, I misspoke, I meant to say outputshaft, not primary shaft", you prefer to call me an A...hole.
Learn some forum manners.
Oh, and one other thing: The load on the seal is not "torque". It is a radial force. Unles you run the engine while it is tilted.
PostPosted: Mon Mar 04, 2013 8:45 pm Reply with quote Back to top
Did you read my post?
PostPosted: Mon Mar 04, 2013 8:47 pm Reply with quote Back to top
You know..when I read your post, I too was sratching my head as to what you meant...
So, tell me, what exactly is wrong with getting clarification?
PostPosted: Mon Mar 04, 2013 9:08 pm Reply with quote Back to top
This thread tilted about 1 1/2 inches before the shit hit the fan....
PostPosted: Wed Mar 06, 2013 10:47 am Reply with quote Back to top
Laughing
BTDT Wink
MinnesotaF
PostPosted: Wed Mar 06, 2013 1:16 pm Reply with quote Back to top
Was there torque on the fans ouput shaft when the shit hit it?
PostPosted: Wed Mar 06, 2013 11:12 pm Reply with quote Back to top
Just for future reference, make sure you don't mix up your oil filter and air filter. Those dam air filters get stuck in that little round oil filter holder. Laughing
