  • Total: 123,555,614
  • Today: 34,630
  • Nov 25, 2026
  • 03:26 am PST
Richlkyl000
PostPosted: Thu Feb 28, 2013 9:57 pm Reply with quote Back to top
I want to polish my engine covers to a nice shine like i always see on here but where do i start? what do i use? what kind of compound to polish with? PLEASE HELP!!!! Rolling Eyes
doubled
PostPosted: Fri Mar 01, 2013 12:40 am Reply with quote Back to top
Here's a pic of my alternator cover. I bought a package of wet/dry sandpaper that had a variety of grit - 320, 400, 600, 1000. I began with the most coarse and moved up progressively to the finest. The used my polishing wheel with brown compound and then finally white compound. Ended with a few coats of wax.
May be overkill but I got out some deep scratches and it looks good.
---David
1982 900F, 2000 VFR, 2013 FJR
PostPosted: Fri Mar 01, 2013 2:31 am Reply with quote Back to top
Ditto on David's method and if you're anal like me, go to 1500 grit before switching to the polishing wheel. I finish with Mother's aluminum and mag wheel polish and the finish ends up gorgeous. It's amazing what you can do with a piece of aluminum.
PostPosted: Fri Mar 01, 2013 4:05 am Reply with quote Back to top
Here is afunny article on Polishing. It is called "Motorcycle Polishing 101 Class Is In Sesson" and it has a lot of information to get you started and it is hilarious to read.
Here is the link on my SkyDrive:
Motorcycle Polishing 101 < Click here
1981 CB900F = Sold 2024
gtomike
PostPosted: Fri Mar 01, 2013 5:24 am Reply with quote Back to top
If you did it right, YOU should look like Al Jolson
That was funny but true the first time I used my pedestal buffer the only thing white were my eyes face shield and shop coat is a must.
sbparks
PostPosted: Fri Mar 01, 2013 1:58 pm Reply with quote Back to top
My experience with polishing is that it is a very messy operation.
I've seen the instructional videos and they never seem to address this fact.
I have a polishing station that I built that is fully enclosed. It is a small booth that contains the dust and wheel 'fly-off'. I've taken to 'suiting up' using a disposable pair of cover-alls (a paint suit) a hat, face shield and respirator.
Maybe somebody has some suggestions for minimizing the mess.
Scott
gtomike
PostPosted: Fri Mar 01, 2013 2:22 pm Reply with quote Back to top
Scott
I only do it outside now that stuff gets all over the place.
basmn
PostPosted: Fri Mar 01, 2013 4:37 pm Reply with quote Back to top
Put a cardboard box behind the wheel. Cut a hole in it for the shop vac hose....and were a dust mask. Box also does a great job of catching all the small parts that fly out of your fingers....don't ask me how I know (:
sbparks
PostPosted: Fri Mar 01, 2013 6:14 pm Reply with quote Back to top
Basmn,
Hey... I like that idea... kinda like a shroud that, along with the vacuum, would catch a lot of the airborne debris.
Thank you.
Scott
PostPosted: Fri Mar 01, 2013 8:30 pm Reply with quote Back to top
My advice would be to start with a small item first.
Save the Valve cover for when you have LOTS of time.. Shocked
Richlkyl000
PostPosted: Sat Mar 02, 2013 5:10 am Reply with quote Back to top
ill try the link later at home but thank you for letting me know how messy it is. i got he** for sand blasting my engine bay of my car in the garage **bad idea** director would i need a smaller buffing wheel for the center of the valve cover because of how narrow it is?
