  • Total: 112,426,038
  • Today: 13,226
  • Jul 26, 2026
  • 07:22 am PDT
PostPosted: Thu May 12, 2011 12:30 am Reply with quote Back to top
I found a guy that is open to making custom headers for me at a reasonable price. I'll be working with him to try to duplicate a certain couple of racing headers built BITD. One will be called the KY and the other will be called the MV. This could take some time, but if successful, we should have the weld jigs ready to duplicate them fairly easily, just in case anyone else is interested. Probably won't be cheap, but the guy does great work.
If I'm successful I will certainly post a few pictures.
PostPosted: Thu May 12, 2011 12:57 am Reply with quote Back to top
I'd be interested in an OMT replica.
Dimensions are important. Remember the results of those test's from back in the day that were recently posted.
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=61190
Look at the numbers.
70rsss
PostPosted: Thu May 12, 2011 1:14 am Reply with quote Back to top
Do you have a Velasco street pipe? I do if not.
1980 Factory Honda Superbike
1982 Honda Superbike - 5X Nat'l Champ
1983 CB1123 Super F - Pit Bike
1970 RSSS 396 Camaro
PostPosted: Thu May 12, 2011 3:06 am Reply with quote Back to top
No, just good pictures. Is your's for dry sump or wet sump?
70rsss
PostPosted: Thu May 12, 2011 3:13 am Reply with quote Back to top
It's a wet sump street pipe. I plan to use it on the Pit Bike but I won't need it for a couple of more months. I have pics of it at work and will post tomorrow.
70rsss
PostPosted: Thu May 12, 2011 3:19 am Reply with quote Back to top
Heres the pipe mocked up on my bike.
PostPosted: Thu May 12, 2011 10:01 am Reply with quote Back to top
Did someone say "Velasco Street pipe?"
Martin,
Are these going to be in stainless?
Tony
PostPosted: Fri May 13, 2011 2:11 am Reply with quote Back to top
I've never seen the MV street pipe installed before. Looks like it could use a slight modification for clearance? I like what the kerker K2 did by rolling over the collector so it was slightly trapizoid rather than square. This gave a good 1/2" more clearance. Maybe a slight modification to the MV similar to what Kerker did would be better. I think that would require a custom collector.
The KY pipe is going to be first. It has no cornering clearance problems at all, just speed bump problems!
PostPosted: Fri May 13, 2011 2:48 am Reply with quote Back to top
What is the goal here? You want a particular pipe for "looks",oil filter access,cornering clearance,what?
I can send you my "spare" RPO Denco front section you wish. It will make the others look like crap since it was made for power. Bike would be sliding on the side to touch but must come off to change the oil filter. This is a diamond rotating collector full pyramid. The pyramid inside the collector is to minimze the collector volume.
Send me E-mail and I can send photo of mounted on my 1100F.
PostPosted: Fri May 13, 2011 4:29 am Reply with quote Back to top
Stout One,
Keep in mind,..the pictured pipe above is on a bike that has the front forks pulled down due to trailering tie downs. And not only that, the tires are in a track that is counter sunk to the trailers check-plate deck. No doubt there is a clearance issue,as is the case with most CB-F aftermarket exhaust systems, but the pictures do not tell the real story. I may be able to roll it out and take a better picture this week if time permits (there's never enough time lately).
Tony
70rsss
PostPosted: Fri May 13, 2011 1:46 pm Reply with quote Back to top
Check this place out.
http://www.spdexhaust.com/CollectorsB.html
Fastball
PostPosted: Fri May 13, 2011 9:53 pm Reply with quote Back to top
Sounds cool! But I'm still lovin' my Schule!!
You still haven't tried yours yet, have you Martin??
'04 White Wing w/Full Traxxion Suspension
'81 CB900F w/1125cc OMT motor
'81 CB900F
'83 CB1100F "Big Blue"
'84 VF1000F Interceptor "Museum Piece"
PostPosted: Sat May 14, 2011 1:53 am Reply with quote Back to top
Would he be iterested in a set of CBX pipes to replicate?
cbxdog
PostPosted: Sun Jun 12, 2011 12:24 pm Reply with quote Back to top
How is this going,, if needed, I have an OMT race pipe in poor condition which can be used as a pattern
1980 CBX
1982 CB1100RC - basket case
1970 HD FLH
1976 HD FX
1983 HD FXRT
1988 FX 85th anniversary
1970 AMC Javelin
1982 AMC Spirit 360 5 speed
surfernick
PostPosted: Sun Jun 12, 2011 2:07 pm Reply with quote Back to top
I'm interested. Keep us posted on progress.
Ryan
PostPosted: Sun Jun 12, 2011 3:37 pm Reply with quote Back to top
+1
PostPosted: Sun Jun 12, 2011 4:36 pm Reply with quote Back to top
Man, that would be perfect! How can I arrange to use it?
Stan2
PostPosted: Mon Jun 13, 2011 12:00 am Reply with quote Back to top
Stout, Interesting, It's about time someone picked up on this. Bills input has some validity.
Stan
DeltaHotel
PostPosted: Mon Jun 13, 2011 4:41 am Reply with quote Back to top
I have the same pipe as CBXdog. Better cosmetics, but collector is flat spotted at bottom.
(bumps on banked tracks)
I bought it in '84 from OMT for a superbike build.
We need to get these re-made, so yeah, I am in....
DH
De Oppresso Liber
Pamwe Chete !
http://www.woundedwarriorproject.org/
http://www.specialops.org/
PostPosted: Sat Jun 18, 2011 8:24 pm Reply with quote Back to top
CBX dog, If you could loan this pattern pipe, I'm sure we could work on a deal when I get a pipe made from it.
cbxdog
PostPosted: Sun Jun 19, 2011 12:34 pm Reply with quote Back to top
Ill be glad to let you use this as a donor pattern for remakes,, Ill send a PM and we can work out the details,, thanks for undertaking this project!! beerchug
1980 CBX
1970 HD FLH
1976 HD FX
1983 HD FXRT
1970 AMC Javelin
djhurayt
PostPosted: Tue Jun 21, 2011 12:30 am Reply with quote Back to top
and I have an OMT street pipe that may be available if interested.
PostPosted: Tue Jun 21, 2011 6:45 am Reply with quote Back to top
I'd like to see that Denco pipe and the fancy pyramid collector, that just sounds like the bees knees to me. Do you think a spin on oil filter would clear that pipe Bill?
PostPosted: Tue Jun 21, 2011 6:49 am Reply with quote Back to top
I'd love one for the track bike. I love the looks & it will work great with my OMT head.
I will be watching this thread from now on.
Cya, Jim
Stan2
PostPosted: Fri Jun 24, 2011 2:29 am Reply with quote Back to top
Bump.......
PostPosted: Fri Jun 24, 2011 2:35 am Reply with quote Back to top
me and Da Dog are trying to work something out.
PostPosted: Fri Jun 24, 2011 8:59 am Reply with quote Back to top
That would mean that a guy that is a mechanical genius would have to figure out how to post a picture.........It's been 8 years........
cb1234
PostPosted: Fri Jun 24, 2011 10:10 pm Reply with quote Back to top
I know plenty of extremely smart guys who don't know which end of the mouse to hold. I also know one or two guys whom are computer savvy but suffer a big mouth.
CB450
CB750
CB955
CB750SC
CB750SC
CB750SC
CB900
CB1100
PostPosted: Fri Jun 24, 2011 10:43 pm Reply with quote Back to top
Knowledge is knowing that tomatoes are a fruit, wisdom is not putting them in a fruit salad. Wink
PostPosted: Fri Jun 24, 2011 11:27 pm Reply with quote Back to top
That "smart" guy I was referring to was one of the early members of the site, which shows an early aptitude for the medium. Now consider his age, he was pretty much well ahead of the learning curve for PC forum use.
I had no idea how to do anything on a computer when I started here. A guy at a gas station told me there was a website that had bikes like mine on it. My kids showed me how to access this site. Everything I know about online activities including E-bay, came from the love of things "F" on the site.
Eight years later you can't figure out a digital camera, photobucket and [img] works?
If I can figure it out, so can he.
How about posting a clear picture of that "Denco pipe and the fancy pyramid collector"?
My "ball breaking" was intended to be a gentle shove toward posting some pictures that many here would appreciate. You have the audience here that would appreciate seeing some pictures of things that that same guy spent significant time and effort developing.
Where I come from, that what men do, break each others balls.
