  • Total: 104,235,739
  • Today: 50,003
  • Apr 16, 2026
  • 02:46 pm PDT
sportsmun
PostPosted: Sun May 01, 2011 12:10 am Reply with quote Back to top
Has anyone tried the valve cover bolt seals from georgefix? I purchased a set for 900f from him and they appear to be different than the old ones.They put an awful lot of squeeze on the VC gasket. This is what they look like:
http://cgi.ebay.com/ebaymotors/VF500-CB750SC-CB900F-CB1000-Valve-Cover-BOLT-SEALS-_W0QQcmdZViewItemQQhashZitem2a1001d3e3QQitemZ180657181667QQptZMotorcyclesQ5fPartsQ5fAccessories
PostPosted: Sun May 01, 2011 12:31 am Reply with quote Back to top
Those are the ones that I've used (2 sets, need to get 1 more set), they work nicely so far for me.
TAS also makes a nice Valve Cover Gasket, as well.
smoked21
PostPosted: Sun May 01, 2011 2:39 am Reply with quote Back to top
I have used those seals from that seller and had no problems.
bought several aftermarket items from him and all worked well
Please do not feed the Idiots,They wont go away
PostPosted: Mon May 02, 2011 3:50 am Reply with quote Back to top
Yup, on my CBX.. No leaks. I even saved Georgefix as a favorite seller.
1979 Modified CBX
1982 Modified CB-750/1100F
1980 GS1000GT Project
1972 CB500 Four K1 Project
pipedope
PostPosted: Mon May 02, 2011 2:15 pm Reply with quote Back to top
I have those and the VC gasket from georgefix on my bike. VC gasket started leaking at 5000 miles, about 1000 after the second valve check. But, considering the price, I'm not complaining. I'm going to replace the VC gasket with the stock Honda gasket from my spare engine and install new bolt seals from georgefix to see if it lasts any longer. Honda bolt seals are too expensive
swiftnick
PostPosted: Mon May 02, 2011 4:19 pm Reply with quote Back to top
You dont have to tighten them down all the way to the stops. With new bolt seals I tend to just tighten as far as necessary to put in enough squeeze to make the gasket work. Then if they compress over time you have a little more squeeze left to use.
1975 CB400 four
2012 ST1300
1982 CX500 Turbo
1976 CB750 Super Sport
1987 VFR700F
1985 VF1000R
1984 GPZ900R
1978 BMW R100RS
1991 FJ1200
sportsmun
PostPosted: Sat May 07, 2011 1:26 am Reply with quote Back to top
I went with the Georgefix seals and they worked just fine no problems at all. Thanks for the input gents.
Desyboy
PostPosted: Mon May 09, 2011 4:54 am Reply with quote Back to top
I have found, that a good supply for those seals, is off the early v6 buick, off the rocker covers, just a matter of removing the GM stud and using your own.Smile
norm
PostPosted: Mon May 09, 2011 8:57 am Reply with quote Back to top
VN Commodore? that was a Buick wasn't it?
Desyboy
PostPosted: Mon May 09, 2011 9:07 am Reply with quote Back to top
yeah sure is, all the commodores' up until the alloytech engine I believe
