  • Total: 123,204,096
  • Today: 200,512
  • 09:45 pm PST
joew7139
PostPosted: Sat Jan 08, 2011 7:51 pm Reply with quote Back to top
I need a stand to hold a CB750F motor while I take down top end. Does anyone know where I can find one reasonable or have plans to build one?
I tried to do a search but kept getting cannot display page message. I would appreciate any help I could get.
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Sat Jan 08, 2011 8:37 pm Reply with quote Back to top
I was thinking of building one. I'd like a suggestion too if anyone has one.
Tx
Bill
PostPosted: Sat Jan 08, 2011 9:39 pm Reply with quote Back to top
Do you have an auto engine stand,like one of those cheapy Chinese ones?
It takes three pieces of metal to adapt one of these to hold a bike motor.
Use two angle pieces same size say 2" on each leg and 1" wide. Bolt hole in end of each leg.
Now the harder piece to find is a much larger angle piece say 4" wide by 4" on each leg.
The large angle piece bolts in the center of the engine stand mine uses 4 bolts into the engine stand slots and the two angle pieces on each side. A motor mount bolt goes through the two and the larger piece you use a piece of wood as a shim to flip it over to do transmission.
The top rear motor mounts are where it attaches and the shim piece lays on the top of the transmission area.
PostPosted: Sat Jan 08, 2011 10:37 pm Reply with quote Back to top
I found this thread and copied the theory behind it. Mine was a whole lot simpler, but also holds the motor upright for working on the head. Both allow you to "flip" the motor for access underneath.
Basically, 2 "L" brackets attached to a flat surface with a rod that goes through the rear motor mounts. These pics are worth a million words (thread and pic courtesy of Stoutblock):
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=40343&highlight=engine+table
This was my cheapo version. I could slide the mount with motor on it off the table, onto a hand truck and move it easily around (like outside to clean and paint it):
Steve
Pointdiver
PostPosted: Sun Jan 09, 2011 6:19 am Reply with quote Back to top
I modded this $50 stand from harbor frieght.
Hondamax
PostPosted: Sun Jan 09, 2011 11:21 am Reply with quote Back to top
Something like this?
1984 VF1000R - Started
1979 900Fz - Stored
grimmace4
PostPosted: Sun Jan 09, 2011 12:32 pm Reply with quote Back to top
I like my K&L engine stand that I bought from Old Bike Barn. It is a model MC25 and can be found here:
http://www.oldbikebarn.com/K-L-MC25-Metric-Engine-Stand
1980 CB750K - Sold to San Ramon, CA
1980 CB750C - Sold to Grand Rapids, MI
1982 CB900F - Sold to Dorr, MI
1983 CB1000C - Sold to Ann Arbor, MI
1983 CB1100F Blue #1 - Sold to Honolulu, HI
1983 CB1100F Blue #2 - In Garage
roosroast
PostPosted: Sun Jan 09, 2011 2:03 pm Reply with quote Back to top
Thanks for those pics of the engine! Now I understand the whole shim business! The cam lobes actually push the valves directly!
joew7139
PostPosted: Sun Jan 09, 2011 3:50 pm Reply with quote Back to top
Thanks for all the great info!!!
txscbf1100
PostPosted: Sun Jan 09, 2011 5:43 pm Reply with quote Back to top
Heres mine. The engine is bolted down from underneath where the bolts that hold the exhaust normally go.
That cut out on the side allows a jack to roll underneath it to help get it out of the frame.
Good luck,
David
Hondamax
PostPosted: Sun Jan 09, 2011 10:34 pm Reply with quote Back to top
I like it! Anyone know whether these are available from any one in the UK or Europe?
1979 900Fz - Stored
PostPosted: Sun Jan 09, 2011 11:27 pm Reply with quote Back to top
If you have the engine stand all it takes is a couple of angle pieces and bolted to the motor stand face plate.
This mounts to only the top case so you can work on top and bottom of the engine.
Enterprising to use the all thread and spacer tubes to use all the mounts.
Hondamax
PostPosted: Sun Apr 10, 2011 8:41 pm Reply with quote Back to top
Bumping this thread because I've finally got an engine stand that works ... Very Happy
The different holes allow me to use any combination of the engine mounting holes, so that every part of the motor is accessible. Plus, I can flip it over on its side or upside down.
It was fabricated by a guy in NI who advertises them on ebay for Ducatis. He modified the Sealey faceplate (OK, drilled 3 holes) to take his mounting plate.
The mounting bracket assembly fits on a Sealey 350Kg engine stand.
1979 900Fz - Stored
Jeremyg1283
PostPosted: Sun Jul 19, 2015 4:47 pm Reply with quote Back to top
Arw those K and L Standa available still?
cbxdog
PostPosted: Sun Jul 19, 2015 6:28 pm Reply with quote Back to top
http://www.amazon.com/Supply-Metric-Engine-Stand-37-9352/dp/B000GV3DSE
1980 CBX
1982 CB1100RC - basket case
1970 HD FLH
1976 HD FX
1983 HD FXRT
1988 FX 85th anniversary
1970 AMC Javelin
1982 AMC Spirit 360 5 speed
Jeremyg1283
PostPosted: Sun Jul 19, 2015 7:45 pm Reply with quote Back to top
I bought it! That mc25 rules!
Erock
PostPosted: Mon Jul 20, 2015 12:31 pm Reply with quote Back to top
With the MC25...Did anyone have to buy the "Metric Adapter"...?
http://www.sears.com/k-l-supply-37-6336-200-mm-adaptor-for/p-SPM7643017003?hlSellerId=1363&sid=IDx20110310x00001i&kpid=SPM7643017003&kispla=SPM7643017003&kpid=SPM7643017003&mktRedirect=y
E
PostPosted: Mon Jul 20, 2015 3:30 pm Reply with quote Back to top
E
Nope.
Cary
Testr
PostPosted: Tue Jul 21, 2015 12:24 am Reply with quote Back to top
Another version
Page Generation: 0.14 Seconds
