  • Total: 112,486,504
  • Today: 29,391
  • Jul 27, 2026
  • 01:43 pm PDT
tbone13
PostPosted: Sat May 29, 2010 3:29 pm Reply with quote Back to top
I need to find a local guy to look at my carbs on my 79 750F. One of the carbs is eaking fuel out the over flow and I dont know why.... Can someone offer some advise? THanks
PostPosted: Sat May 29, 2010 4:14 pm Reply with quote Back to top
Probably a stuck float needle or a split overflow tube. Where is central Ohio ? Columbus, Dayton ?? Put your location in under your profile and welcome to the site
Lucasmer50
PostPosted: Sun May 30, 2010 11:37 am Reply with quote Back to top
Could be a cracked overflow tube. Take that bowl off and fill it up with water. Put you thumb over the top of the tube, loosen the drain screw and use your compressor to blow air up the tube. Watch for bubbles in the water. I had two bowls like this on my 79.
1979 CB 750F
1982 CB 900F Hondaline Fairing
1983 CB1000C
2007 Yamaha V Star 1300
spartan8ball
PostPosted: Sun May 30, 2010 12:45 pm Reply with quote Back to top
Your float needle is not cutting of the fuel flow. Very common. Solution is to remove the bowl, clean the brass hole that the needle goes in to with a qtip, and re install. If its an outside float bowl, you can do this wth the carbs on the bike.
tbone13
PostPosted: Thu Jun 03, 2010 7:02 pm Reply with quote Back to top
I am located in Southeast Columbus. I will try these and see what happens. I know that as soon as the bowls fill with fuel the #4 carb has fuel running out the overflow tube. I'll let you know.
Is there a reason why I see most guys running stock airboxes. I running K&N pods....
Tedly
PostPosted: Thu Jun 03, 2010 7:55 pm Reply with quote Back to top
Laughing Here it goes Laughing
winnerc2s
PostPosted: Thu Jun 03, 2010 8:49 pm Reply with quote Back to top
Before the carbs started to pee out the overflows did you like the way the bike ran? Any sputters? Flat spots?
If it ran to your liking then the question is moot.
If it did not run to your liking that is why a lot of people leave the airbox on. The pods can sometimes be hard to tune.
Rob
'83 CB1100F - Red
'83 CB1100F - Blue
'85 CB700SC - Black/Blue
'83 ATC200X - Red/White
'02 VRod - Silver
tbone13
PostPosted: Fri Jun 04, 2010 10:46 am Reply with quote Back to top
Actually the bike ran great, I had the igniters go bad and the bike sat for a few years. I had the carbs gone through while I had it at a shop and that is when I found out the problem with them. Before the shop went through them they were fine. It was winter time and thought it would be a great opprotunity to clean things up alittle. Man do I wish I wouldnt have taken it there. They specialize in "newer" sportbikes.
james99
PostPosted: Sat Jun 05, 2010 1:15 pm Reply with quote Back to top
I am too searching for a good mechanic for a long time but didnt get till now.i think its hard to find.
Cheap Car Accessories
tbone13
PostPosted: Thu Jun 17, 2010 2:42 pm Reply with quote Back to top
Ok turns out it is the overflow tube. Put the water in blew are through it and presto, bubbles.
Next question is where do i get one and how hard are they to install?
WisconsinF
PostPosted: Thu Jun 17, 2010 3:54 pm Reply with quote Back to top
You can solder them or some guys have repaired with JB Weld
Lucasmer50
PostPosted: Thu Jun 17, 2010 4:22 pm Reply with quote Back to top
I am sure someone around has a spare bowl they will sell you or give you.
1979 CB 750F
1983 CB1000C
CBXtras
PostPosted: Thu Jun 17, 2010 4:41 pm Reply with quote Back to top
See, you didn't need a mechanic after all. You just needed to ask the question here and folks are happy to help out.
