  • Total: 110,485,650
  • Today: 43,351
  • Jun 26, 2026
  • 01:48 pm PDT
WisconsinF
PostPosted: Sat May 22, 2010 1:22 am Reply with quote Back to top
Hmmm. Got to doing some work on the 79 750 I bought for 500 bucks last weekend (Look what 500 buys you in Milwaukee link) and discovered this
So, what is this engine? A 750 with a 900 top end? What else could be lurking inside?
Any ideas or thoughts?
Vin number does not match the block number.below..not even close Vin #RC04-2007086
dhoff
Location: 40 Square Miles Surrounded By Reality (Madison, WI)
PostPosted: Sun May 23, 2010 1:22 pm Reply with quote Back to top
Interesting. Looks like nobody else knows what you have either. Definitely 900 cylinders, I don't know how to tell a 900 head or carbs from a 750. Someone should know the case numbers, I don't either. I see some gasket goop at some of the joints, looks like a motor question mark.
PostPosted: Sun May 23, 2010 3:13 pm Reply with quote Back to top
Looks like you have a 1981 CB900C engine ....... according to this (taken from here http://www.z1enterprises.com/bike-list-honda.aspx) >>>
1980 CB900C
- Frame: SC04-2000046
- Engine: SC04E-2000035 [more]
1981 CB900C
Japan:
- Frame: JH2SC040XBC100004
- Engine: SC04E-2100004
USA:
- Frame: 1HFSC0406BA100004
- Engine: SC04E-2100004 [more]
1981 CB900F
- Frame: JH2SC0101BM000011
- Engine: SC01E-2200950 [more]
1982 CB900C
- Frame: 1HFSC0409CA200101
- Engine: SC04E-2200001 [more]
1982 CB900F
- Frame: JH2SC0107CM100003
- Engine: SC01E-2300001 [more]
WisconsinF
PostPosted: Sun May 23, 2010 10:03 pm Reply with quote Back to top
Petrat,
I do believe you have made the identification.
Thanks very much,
A 900 engine all around!!
Barry
still_bluenoser
PostPosted: Mon May 24, 2010 1:46 pm Reply with quote Back to top
How do ya like the shaft drive? Laughing
djhurayt
PostPosted: Mon May 24, 2010 2:35 pm Reply with quote Back to top
I don't think the 9C was a shafty, only the 1000
sfhess
PostPosted: Mon May 24, 2010 3:57 pm Reply with quote Back to top
Nope. 900C was a shaftie. It had the two-speed transfer case to get the drive over to the right side of the bike.
WisconsinF
PostPosted: Mon May 24, 2010 4:39 pm Reply with quote Back to top
Maybe someone did a shaft to chain conversion on it?
PostPosted: Mon May 24, 2010 4:52 pm Reply with quote Back to top
Can you post some pics of the output shaft?
Cary
dhoff
PostPosted: Tue May 25, 2010 11:25 pm Reply with quote Back to top
Only in CTDY.
Smile
rtabish
PostPosted: Fri May 28, 2010 3:44 am Reply with quote Back to top
not likely. unless someone in this engine's past was a frustrated machinist with LOTS of time. that is a lot more work than you might think.
Weekend_Junkie
PostPosted: Fri May 28, 2010 6:24 am Reply with quote Back to top
I thought it was a matter of swapping the output shaft?
Please show more pictures of the front sprocket area.
'81 CB900F Bol d'Or
'12 Triumph Tiger Explorer
'13 CB1100 + sidecar
PostPosted: Fri May 28, 2010 8:31 am Reply with quote Back to top
Probably did the conversion. I don't recommend it, the cases have different strengthening bosses in them for the different loads they need to manage. But there is plenty of metal on the shaft drive output shaft to machine a sprocket holder.
Might just work OK for an other than full on balls out bike.
rtabish
PostPosted: Fri May 28, 2010 9:16 am Reply with quote Back to top
i have never actually seen anyone do this conversion. finding a 900 F engine is usually a lot less work. interesting if it is one. Wink
WisconsinF
PostPosted: Sun May 30, 2010 5:41 pm Reply with quote Back to top
Looks to be a shaft to chain conversion.
only 1 of the 4 cover bolts line up.
rtabish
PostPosted: Sun May 30, 2010 6:40 pm Reply with quote Back to top
and everything lined up properly...chain, wheel, sprockets...? hmmmm.
PostPosted: Sun May 30, 2010 7:45 pm Reply with quote Back to top
That 461 on the case is the code for cb900c like 438 is the code for cb900f.
PostPosted: Sun May 30, 2010 11:48 pm Reply with quote Back to top
Flamer
Who likes the shaft drive now huh?! Razz
