  • Total: 123,555,489
  • Today: 34,505
  • Nov 25, 2026
  • 03:24 am PST
WisconsinF
PostPosted: Wed Feb 03, 2010 12:07 am Reply with quote Back to top
I under stand this will hold 2 carbs (separated)
Link to Sonic Cleaner
bee-jay
PostPosted: Wed Feb 03, 2010 12:53 am Reply with quote Back to top
I've never used one.
how do they work on say, old skanky carbs that really need help?
What kind of fluid is recommended?
I resurrect a lot of old bikes and the carbs are always a challenge.
'83 CB1100F Red
'82 CB900F Silver
winnerc2s
PostPosted: Wed Feb 03, 2010 1:01 am Reply with quote Back to top
Member here that goes by TheFox does a lot of ultrasonic carb cleaning. Guys that have used him have said very good things. He can probably answer your questions.
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=52999&start=0
Rob
'83 CB1100F - Red
'83 CB1100F - Blue
'85 CB700SC - Black/Blue
'83 ATC200X - Red/White
'02 VRod - Silver
Tuvlo
PostPosted: Wed Feb 03, 2010 3:56 am Reply with quote Back to top
I have the same one that i used to cleaning brass for match reloading and was not all that impressed with it. If you put too much weight in it it would not work well at all.
As for what cleaning solution to use look here http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=46591&highlight=
cbxsix
PostPosted: Wed Feb 03, 2010 8:50 am Reply with quote Back to top
I made this up for about 12 bucks, has worked great for ten years. A roughneck tub, Harbor Freight sander and a rheostat from a light switch.
spike
PostPosted: Wed Feb 03, 2010 12:07 pm Reply with quote Back to top
Is the pistol for effect or are you about to kill something ?
Possibly having a bad day with the engine?
Three of a prefect pair
cojonesdeloro
PostPosted: Wed Feb 03, 2010 12:49 pm Reply with quote Back to top
This looks interesting, so is it just water you are using or a cleaner in your tub, i guess the sander is what creates the waves to clean, how long would you need to leave a part in to get as clean as those carbs? might have a go at this.
Daz. Very Happy
PostPosted: Wed Feb 03, 2010 1:50 pm Reply with quote Back to top
I have used diluted vinegar with great success..
Outback_Jon
PostPosted: Wed Feb 03, 2010 2:08 pm Reply with quote Back to top
Personally, after working on a rack of just four carbs I usually have the urge to shoot something. After six??? Shocked
Molon Labe
spike
PostPosted: Wed Feb 03, 2010 2:17 pm Reply with quote Back to top
When cleanning the carbs I would assume that the vinegar will not harm the o rings. And if you don't want to break the rack just take the bowls and caps of and all the internals out then submerg the carbs Yes?
spike
PostPosted: Wed Feb 03, 2010 2:18 pm Reply with quote Back to top
What is the ratio ?
cbxsix
PostPosted: Wed Feb 03, 2010 2:48 pm Reply with quote Back to top
I was cleaning the pistol, the reason that it was in the shop.
I strip the carbs down to the bodies then clean them in the sonic tub with a mixture of gas and Yamaha carb cleaner per the ratio on the directions(this is done outside, not inside the shop) and blow out the passages with compressed air.
Then I clean them again with a mixture of very hot water and an industrial water salable cleaner, blow out the passages again.
Then I rinse them in hot water and blow them out a final time with compressed air.
Now they are ready to be flushed with Berrymans carb cleaner in an aerosol can with the tip of the tube that comes with the can that has been ground to a bevel to fit in the passage orifices.
Then a final flush with brake cleaner because it dries quickly without leaving any residue, this also lets me check every single circuit of the carbs.
The reason I use Yamaha carb cleaner and then the hot water and degreaser is that each work on different deposits that the other won't dissolve.
The carb tops are cleaned seperate because of the clear coat on them, if the CC is hazed I strip the CC off then polish them.
The floats and any other plastic bits get cleaned with brake cleaner because its less caustic.
About it.
jeff
Scubes
PostPosted: Wed Feb 03, 2010 3:03 pm Reply with quote Back to top
I'm sure that different carbs vary, but what is the average time you run them through each cleaning cycle? And exactly how do you manage to keep that sander stuck to the side lol. I'd be afraid of it coming loose and bouncing all over the floor before I caught up to it.
spike
PostPosted: Wed Feb 03, 2010 3:35 pm Reply with quote Back to top
About it.
jeff
And through all this cleanning proccess any o rings or seals that are not removed will not get damaged ?
I know this sounds silly but I have heard that the carb cleaner will hurt the o rings, but I guess if it is diluted enough this won't happen
gorilla_biker
PostPosted: Wed Feb 03, 2010 3:40 pm Reply with quote Back to top
Heath Robinson is alive and well and living in Ohio Laughing
elcman
PostPosted: Wed Feb 03, 2010 4:29 pm Reply with quote Back to top
Spike,
Not sure why they are ignoring you. I use Canadian tire brand carb cleaner. Supposedly no damage to the o-rings. The clear coat, however, turns into sticky goo.
Grant.
spike
PostPosted: Wed Feb 03, 2010 4:39 pm Reply with quote Back to top
elcman wrote:
Spike,
Grant.
I get ignored at home all the time Laughing
maybe a stupid question I asked (Yoda) Wink
Scubes
PostPosted: Wed Feb 03, 2010 4:53 pm Reply with quote Back to top
I've read that the Yamaha carb cleaner that you dilute doesn't hurt the rubber parts. But don't quote me on it as I have never tried it.
still_bluenoser
PostPosted: Wed Feb 03, 2010 5:35 pm Reply with quote Back to top
before I knew better I soaked my carbs in straight carb cleaner for two days with the seals still in them and it didn't do anything. That was 2 seasons ago.
cbxsix
PostPosted: Wed Feb 03, 2010 6:11 pm Reply with quote Back to top
The Yamaha carb cleaner is the strongest of the chemicals used on the carb bodies and won't hurt the rubber bits if used per the ratio to gas on the directions.
The straight Berrymans is used in the carb body circuits and is flushed by the the brake cleaner, no problems in all the years using this process.
PostPosted: Thu Feb 04, 2010 12:34 am Reply with quote Back to top
Spike I wasn't ignoring you just wasnt online is all Very Happy
I have tried a whole variety of dilutions, 50/50 seems to work pretty good.
And yes, the whole bank, less the bowls and floats can go into mine.
Crank the timer and let the dogs howl for a few hours...
Afterward a day or so hanging upside down seems to clear them out fine.
Then some low pressure air just to be sure.
spike
PostPosted: Thu Feb 04, 2010 1:13 am Reply with quote Back to top
Randy I did not think you were ignoring me. An the nerve of you not being on line all the time Shocked what do you think you have a life Wink
PostPosted: Thu Feb 04, 2010 1:17 am Reply with quote Back to top
lol no...Very Happy
spike
PostPosted: Thu Feb 04, 2010 1:22 am Reply with quote Back to top
I am going to give this a try on Peggy's carbs. I don't know when the ,last time these carbs were cleqaned up or dialed in so as I am rebuilding the whole bike I will give it a shot
Thanks for the info guys
Grumpy32
PostPosted: Thu Feb 04, 2010 1:33 am Reply with quote Back to top
So how DO you glue the sander to the tub? I think it's a great idea Cool and I've got a sander already Laughing just need a tub.
Terry
cbxsix
PostPosted: Thu Feb 04, 2010 1:47 am Reply with quote Back to top
The pad on the sander has two screws holding it to a steel plate of the sander, I just used a 3/4 inch thick piece of wood a bit lager than the size of the pad on the inside of the tub and used two longer screws to secure it through the tub into the pad where the original screws threaded into the sander.
elcman
PostPosted: Thu Feb 04, 2010 2:03 am Reply with quote Back to top
Hey,
That is a really cool idea on the home made sander.
Randy,
I was not implying you. It seemed like we were all on line at the same time. Thanks for the info. Homemade is always cool.
Grant.
mhewitt
PostPosted: Thu Feb 04, 2010 5:56 am Reply with quote Back to top
that is a magnificent idea...
i love home-made
bikerdave
PostPosted: Fri Feb 05, 2010 8:08 am Reply with quote Back to top
Please, forgive the new guy.
It seems to me that this is not only a sonic carb cleaner
but a parts cleaner as well? Embarassed
PostPosted: Fri Feb 05, 2010 1:18 pm Reply with quote Back to top
Yes and a jewelry cleaner and a denture cleaner..
Just don't use flammable cleaning agents..BOOM!
