  • Total: 122,977,852
  • Today: 110,881
  • 08:42 pm PST
Batan
PostPosted: Tue Mar 31, 2009 6:03 pm Reply with quote Back to top
I started the separate thread because I want people to be able to find this thread in the future, hence the search-friendly title.
I have just gotten off the phone with the representative of Deka batteries in Canada and - Big Crank is a DEKA battery with a different sticker on it. So, it does not matter which one you buy out of the two, IT IS THE SAME BATTERY!
This is especially important for us Canucks as we can't get Big Cranks here.
cheers!
TnT
PostPosted: Tue Mar 31, 2009 6:44 pm Reply with quote Back to top
cheers!
Nice Job! Good to know!!
PostPosted: Tue Mar 31, 2009 9:00 pm Reply with quote Back to top
Correct,the code tells the tale. It is ETX15L.
bracemaker
PostPosted: Tue Mar 31, 2009 9:08 pm Reply with quote Back to top
Says deka right on the box!
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=49730&highlight=
Batan
PostPosted: Tue Mar 31, 2009 9:16 pm Reply with quote Back to top
Perhaps, but if you ask "can I get a Deka ETX15L instead of Big Crank" on this forum, some people will tell you "stop fucking around and get a Big Crank!". LOL
PostPosted: Tue Mar 31, 2009 10:31 pm Reply with quote Back to top
More retailers for DEKA too. The limited Big Crank Dealers wanted $40 - $50 to ship to Alaska and would not budge when I called. Got it from a DEKA dealer for $12 shipping today. This thread saved me $28! Very Happy
I think we may need a new emoticon now.
"THIS THREAD IS NOT WORTHLESS!" Wink Laughing
1981 CB900F = Sold 2024
PostPosted: Tue Mar 31, 2009 10:33 pm Reply with quote Back to top
My Extreme Powersports brand same deal.
Everyone here discovered this,I came late.
I just happened to be at the Anderson's General Store and saw one on a shelf so decided to try one to see if it worked. Funny deal was inside the book of size codes right on the first page as an "example" was the CB1100F.
It says voltage controlled charger needed so I looked around for the correct one to be sure not to fry it and bought a Schumacher automatic with float feature. So I hook it up and it was full charge right from the box.
During the winter I hooked it up to see if it was down any after say 2-3 months,still full up.
As a test and to understand the full importance I tried to start it with no jump. For 25 yrs this bike would not start without jumping it to help the first start after winter. Bike fired up after the typical extended crank needed to fill the carbs,but cranked at the same speed maybe gaining speed. Usually a couple good revolutions then a YB14L-A2 would slow down cranking.
The cold crank listing of the best Yuasa YB14L-A2 was 205 CCA,normal is 190. The ETX15L lists as 190. So they must calculate the CCA by plate count not by performance. It is probably the improved connection inside that results in less resistance that discharges a regular battery.
All I know is these things are the best thing since sliced bread,powerful and live so what more do you want?
Rat
PostPosted: Wed Apr 01, 2009 12:33 am Reply with quote Back to top
Got one 6 years old, been through 3 bikes, still going strong.
I'm sold.
Gord Razz
PostPosted: Wed Apr 01, 2009 12:35 am Reply with quote Back to top
Just starting year #4 on mine..battery charger went to idle after about 15 seconds...
PostPosted: Wed Apr 01, 2009 6:12 am Reply with quote Back to top
This is so strange and I congratulate you guys.
I tried the Yuasa gelbattery that now is "suppose" to be AGM. The code is/was not something easy like YB14L-A2 "G" or something and it took a bit of doing the get the correct size/terminal location/code.
This was all the rage on all the drag bikes. Kawasaki used remote starters so the battery was only ignition and drag bikes run total loss.
So I bought them for ones I built but my old bike still had a stock battery box and I used fresh water batteries. The gel ones never had the omfuf to easily spin the motor,then the one bike out of two died. So disassemble the bike to install fresh gels and then the order got reversed,I took out a maybe working one to install one that died,still 50% failures. So I was skeptical about how good the Big Crank and others were.
Now I have these ETX15L batteries,they all work and the life is years,they spin just like new. Regular YB14L-A2 would get "weak" in the second year,maybe sooner.
There is no comparison what ever.
Blainethemono
PostPosted: Wed Apr 01, 2009 11:51 pm Reply with quote Back to top
Quote:
some people will tell you "stop f#cking around and get a Big Crank!". LOL
Well Batan, I am the one who turned this site onto the Big Crank five + years ago. I told Stoutblock, he bought one, and so on and so on... I do not believe DEKA was marketing one under thier name @ the time I bought mine.
P.S. This is a FAMILY FRIENDLY SITE, so please keep your swearing to yourself....
PostPosted: Thu Apr 02, 2009 1:41 am Reply with quote Back to top
They sure weren't when I bought mine, I have family in the battery biz..
DEKA didn't have one available back then...
Batan
PostPosted: Thu Apr 02, 2009 4:12 am Reply with quote Back to top
Oh geez...
My DEKA is in, picking it up tomorrow, whoohoo! Smile I can't wait to have a proper AGM battery.
winnerc2s
PostPosted: Thu Apr 02, 2009 12:29 pm Reply with quote Back to top
I just bought a new Big Crank from BatteryMart.
Battery is still labeled Big Crank.
The box that it came in was Deka branded.
Rob
'83 CB1100F - Red
'83 CB1100F - Blue
'85 CB700SC - Black/Blue
'83 ATC200X - Red/White
'02 VRod - Silver
bamaf
PostPosted: Thu Apr 02, 2009 5:34 pm Reply with quote Back to top
Same here,mine came yesterday from BatteryMart.All I know is that it spins the engine like crazy! Very Happy
Batan
PostPosted: Fri Apr 03, 2009 4:44 am Reply with quote Back to top
Well, here's the Deka. Came with 12.82V. According to the sheet in the last image, it's charged 100%. For fellow Canucks, it came to CAD$115 before tax. Not bad.
robbo
PostPosted: Fri Apr 03, 2009 10:51 am Reply with quote Back to top
Man, we're paying through the nose here in Australia. Just picked up the Deka AGM from Battery World here in Sydney on Taren Point road. They had one charged ready to go and it cranks man!
But, it cost me Aus $219 including tax. I think that would be about 153 U.S. bucks at a .7 conversion rate, or whatever it's at these days.
Very happy with it though. Fits perfectly and has the guts when you need it.
P.S. If some of you guys excuse the foul language then the rest of us can excuse your "clean" language (whatever that is). Who has the "correct" point of view? And how many 7-year olds are reading this? Not many young'uns would be riding their F in the paddock!
No offense to anyone intended. Unless you really want to take offense for whatever reason. It's your journey and who am I to deprive you of that?
I would hope nobody feels they need to tiptoe around any of the adults on this forum.
Cheers.
PostPosted: Fri Apr 03, 2009 12:28 pm Reply with quote Back to top
Did they supply KY with that? I paid $160 for one then $165 the next from the local battery place.
PostPosted: Fri Apr 03, 2009 9:51 pm Reply with quote Back to top
I think all these are alike even down to the red thing holding the bolts/washers in the box.
Looks just like the batteies I bought at The Anderson's. Mine cost $60 plus tax.
Sure sounds like more "profiteering" than just exchange rate.
Batan
PostPosted: Sat Apr 04, 2009 3:26 am Reply with quote Back to top
Might be a dumb question but where do those washers go?
PostPosted: Sat Apr 04, 2009 3:35 am Reply with quote Back to top
Just the size of the market I think (and a bit of profiteering thrown in. Even when the USD was worth 1.4AUD for a long period of time, the same parts over here were worth double at least compared to the US.
PostPosted: Sat Apr 04, 2009 3:44 am Reply with quote Back to top
Made right here in PA;
http://www.eastpenn-deka.com/default.aspx?pageid=4
PostPosted: Sat Apr 04, 2009 4:00 am Reply with quote Back to top
I think they act as a "shim" if you use the side entering threaded holes vs the ones on top.
Batan
PostPosted: Sat Apr 04, 2009 6:30 am Reply with quote Back to top
That's what I figured as I couldn't see the point of them when using this battery in a CB-F.
winnerc2s
PostPosted: Sat Apr 04, 2009 1:38 pm Reply with quote Back to top
Yes, they are for side mount applications.
Read the paperwork that came in the box. It's noted there.
Rob
'83 CB1100F - Red
'83 CB1100F - Blue
'02 VRod - Silver
bamaf
PostPosted: Sat Apr 04, 2009 3:27 pm Reply with quote Back to top
But, it cost me Aus $219 including tax. I think that would be about 153 U.S. bucks at a .7 conversion rate, or whatever it's at these days. cheers.
WOW Shocked I don't know what shipping to Australia would be but I do know that it cost about $45 to send a package less than 15lbs to Thailand.Over the years my wife has found the cheapest ways Very Happy
calgaryss
PostPosted: Sat Apr 04, 2009 3:50 pm Reply with quote Back to top
So where did you get it?
Thanks.
PostPosted: Sat Apr 04, 2009 4:56 pm Reply with quote Back to top
I bought this last week through Advance Auto parts for $ 64.99 (US) & New York State required me take an old battery or I had to pay $ 5.00 core fee. (I was able to take an old car battery though so that was ok.) When I was looking at the Deka above the case looked identical and the instructions were exact and both say "EPM" on the bottom although my battery & box say EPM Manfacturing Baltimore MD? Doc
Batan
PostPosted: Sun Apr 05, 2009 12:32 am Reply with quote Back to top
Thanks.
I didn't find a shop that carries the ETX15L in stock. What I did was I phoned the Eastpenn rep here in Vancover and he sent one to a local marine shop that carries Dekas. Let me know if you want his number.
Update
Today I put about 150km on the bike. After coming home I shut the bike off and measured the battery after few minutes, the voltage is 12.84V. Unlike the old battery that started with 12.6 and was 12.1 after a two hour ride. LOL
calgaryss
PostPosted: Sun Apr 05, 2009 3:17 am Reply with quote Back to top
Thanks and good news.
I did some searching and found a local rep as well.
My battery hasn't given me any issues so far so maybe I'll keep it until is does.
