  • Total: 123,070,000
  • Today: 66,416
  • 09:27 am PST
motomoon
PostPosted: Thu Aug 28, 2008 9:02 pm Reply with quote Back to top
Next week I'm moving to Colorado!
Anybody got any tips, tricks, or suggestions about moving motorcycles?
We are going to be using a 16' rental truck like this:
It might have a lift gate, it might not.
I'm going to build a platform something like this but add some sides and top:
Most shipping companies want the fluids drained, I imagine for liability reasons but is it a good idea? I have four tie downs and will be utilizing them all give it the most
stability but should I put it up on the center stand? My center stand has been reworked to be quickly removable and is slight bent to one side not too extreme but still would it make more sense to just strap it down without the centerstand in?
Anybody else have experiences with moving?
NV900F
PostPosted: Thu Aug 28, 2008 9:22 pm Reply with quote Back to top
when i bought my 1100 from cali, i rented a small uhaul trailer. rode it into, tie downed to walls and floor (front and back), gas off, bike upright and centered (not on center stand), in gear. no problems all the way home around 400 miles. then fired it up and backed down out of trailer, and went for a short 10 mile ride.
do yourself a favor though, go to lowes or the depot and get a pack of ratcheting straps, as you travel, pull over and give the straps another click or two when needed. also do front of trailer to back of bike first to get up tight to front wall, then front of bike to back somewhere, bike won't move at all.
PostPosted: Fri Aug 29, 2008 12:00 am Reply with quote Back to top
Good Luck with your move . I used a half piece of 3/4 inch plywood w/ harbor freight motorcycle chocks bolted to the plywood w/ large load distributing washers. I also bought D rings from home depot and mounted them to the plywood. Use ratcheting straps (short as possible) to secure the load. Total cost for 2 bikes under $100. Used several times works great. Moving vans also have mounting systems on the box walls you can strap to. A stand allows the bikes suspension to soak up road shock and bumps on the way.
vowelsound
PostPosted: Fri Aug 29, 2008 2:17 am Reply with quote Back to top
Don't do this:
http://www.youtube.com/watch?v=UkQYYBOrRNk
Weekend_Junkie
PostPosted: Fri Aug 29, 2008 2:24 am Reply with quote Back to top
I rented an enclosed uhaul trailer before and stopped once the tie down rails ripped off the inside and my 900F fell into my VFR. Very upsetting day. Since that point in time, uhaul added D rings to those trailers, which would make it OK to use. I think that platform idea is GREAT, but i'm not sure how you'd push it around once loaded without a pallet jack.
Anyway, I started using one of these for moving motorcycles. I attach the rack to my K5 Blazer and drive happy.
http://www.gc-carriers.com/sport_bike_carrier.htm
'81 CB900F Bol d'Or
'12 Triumph Tiger Explorer
'13 CB1100 + sidecar
motomoon
PostPosted: Fri Aug 29, 2008 3:07 am Reply with quote Back to top
I like that carrier!
The plan, in my mind anyway, is to first load the platform in the truck. Back the truck up to a loading dock then using the ramp, which would be almost level at that point carefully (avoid repeating vowelsound's video Wow ) load the bike, strap it to the platform and box it in. Then load the rest of the stuff.
Sounds too easy. Very Happy
rcmoto
PostPosted: Fri Aug 29, 2008 5:35 am Reply with quote Back to top
Load it like this! Its fast, easy and impresses the ladies.
http://www.youtube.com/watch?v=nZo33y7w0Wk
Outback_Jon
PostPosted: Fri Aug 29, 2008 5:50 am Reply with quote Back to top
If the truck has D-rings to mount to, I'd use those, both wheels on the floor. Let the bike's suspension take up any bouncing that will happen as you drive.
I would suggest NOT tying it to the (usually) wooden rails that they put on the sides of most trucks, as they really aren't made for that.
Molon Labe
PostPosted: Fri Aug 29, 2008 2:12 pm Reply with quote Back to top
You don't have to move a platform. You do need a ramp or a hill to park at the bottom of. Takes 15 min to roll bike into stand and then do straps. You get there, disconnect and roll it out. Lift the wood out (one man op) and you're done.
Same set up works if bike breaks some where or if you find a deal on a bike thats not road ready. I used three D-rings mounted to the platform to give me versatility mounting different bikes.
The only downside for me has been finding short enough ratcheting straps (under 10 ft) to secure the bike. My rope and knot skills leave much to be desired and ratchets give you the ability to slightly pre-load the suspension.
I forgot that I did also buy aluminum ramps at Costco for $99 so the deal cost around two bills w/the straps (Evil Empire/Walmart)
Many times those rental trucks have a pull out solid floor aluminum ramp so you can wheel handtrucks up it. That would work too.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96349
These were $29 a couple of months ago.
**EDIT** For the record My side stand is up while transporting...I took off two straps prior to the photo, loosened the others, and put it down.
PostPosted: Fri Aug 29, 2008 2:23 pm Reply with quote Back to top
Don't use either the side or main stand,leave the bike on the wheels. Tie it down "part way" on the suspension,but do not fully compress the forks. The remaining movement allows the bike to float over bumps. A side stand is already "falling over" to start and the main stand concentrates the tie down load or bends it.
If there are tie down hooks on the floor that is great. Another version is simple 2X4's nailed to the floor or to a separate plywood to act as "chocks" to keep the bike from scooting to the side.
I assume you will be packing more than just the bike,so sides are a good idea to prevent the other stuff from making contact with it.
gorilla_biker
PostPosted: Fri Aug 29, 2008 11:58 pm Reply with quote Back to top
yup, what everyone else said. Plus...
I've taken bikes on ferries a few times....
Side stand...
Pad anything the straps are in touch with (including seat)
Strap it down so a bit of suspension travel is taken up
Be sure if it moved an inch or two it's not going to contact anything
Go to bar
BluesMan
PostPosted: Mon Sep 01, 2008 5:22 am Reply with quote Back to top
vowelsound wrote:
Don't do this:
He shouldn't have stopped.....I hate to see good bikes wrecked for no reason. Twisted Evil
Lowblues
PostPosted: Mon Sep 01, 2008 4:32 pm Reply with quote Back to top
I kind of like this idea.
Wink
Tuvlo
PostPosted: Mon Sep 01, 2008 6:22 pm Reply with quote Back to top
Wink
I saw something a lot like that the other day but they had it flipped upside down so the handle bars were on the trunk and the seat was on the roof, i did a double take as it passed me going down the highway.
Where in Colorado are you moving to Motomoon?
motomoon
PostPosted: Mon Sep 01, 2008 7:13 pm Reply with quote Back to top
The Denver area, going back to school. I lived most my life in Fort Collins and after being away for six years I really missed Colorado.
Tuvlo
PostPosted: Tue Sep 02, 2008 4:44 pm Reply with quote Back to top
I can understand why you would miss it. Maybe we can go for a ride sometime when you get here.
zionvier
PostPosted: Tue Sep 02, 2008 5:03 pm Reply with quote Back to top
Count me in on the ride when you get out here. As long as your Fs don't mind being seen with a K.
View user's profile Send private message Visit poster's website AIM Address ICQ Number
motomoon
PostPosted: Tue Sep 02, 2008 9:23 pm Reply with quote Back to top
Sounds good to me!
mango
PostPosted: Wed Sep 03, 2008 10:14 pm Reply with quote Back to top
GO by a Baxley bike stand .
83 CB 1100F blue/white vin #26
02 ZRX 1200
motomoon
PostPosted: Fri Sep 05, 2008 5:24 am Reply with quote Back to top
Going to get on the road tomorrow early AM, 1046 miles. Here's how the bike is going, hope it all goes well.
The side wall is actually a workbench, and the top is the workbench supports, recycling is good. Wink
Made some room for all the parts that did not sell. viva eBay!
Nice thing about clip-ons, the bike can be made thinner.
burned
PostPosted: Mon Sep 08, 2008 11:24 pm Reply with quote Back to top
see ya when you get here!
id be down for a F ride/get together.
Page Generation: 0.09 Seconds
