  • Total: 123,125,333
  • Today: 121,749
  • 04:23 pm PST
Kevoz
PostPosted: Sun Oct 07, 2007 6:54 pm Reply with quote Back to top
Hello again, what is the current mindset of the middle class chain to buy, I do not want the most expensive nor the junker....I need a good quality 530- "O" or "X" ring chain that wont cost what my ride is worth and dont want to replace it before spring either.....btw, sprockets will be new as well. Thanks for any replies and maybe your preferred supplier's name, I hope to purchase all this ASAP and will buy a chain press/riveter also from www.motorcycleproshop.com.
Kevo Rolling Eyes
"Knowledge is Power"
ShamusMcFeeley
PostPosted: Mon Oct 08, 2007 6:50 am Reply with quote Back to top
You can't underestimate the power of a cheap chain to fail on you at the worst moment. This has happened to my when I rode dirt. I wanted to save a little money by buying a cheap chain for my 350x and I paid for it with a broken chain in the middle of a ride. A few years later the same thing happened to me when I didn't quite have enough money for the good Tag metals sprocket I wanted for my 450R. I ended up buying a no-name brand aluminum one, and the bike ate that thing up in a few months. I like D.I.D chains, but thats just personal preference. RK chains are good too. I hate anything Renthal, and that is mostly from my dirt days. I have a Sunstar rear sprocket on my 750F now that looks to have worn well. I always search for the best deals I can get, but I'll always vote to spend a little more for the sake of quality.
Here's a link for a good RK chain (There's a few sprockets here as well)
http://www.z1enterprises.com/detail.aspx?ID=1870
Old Bike Barn has a few inexpensive chains, but sprockets are a lil pricy:
http://www.oldbikebarn.com/motorcycle_parts.php?subcategory=Chains%20-%20Drive&bike=CB750
Here's a EK chain from Motorcycle-Superstore.com:
http://www.motorcycle-superstore.com/2/9/185/5467/ITEM/EK-530-SRO-O-Ring-Chain.aspx
Here's a D.I.D chain on ebay:
http://cgi.ebay.com/ebaymotors/Honda-Yamaha-Suzuki-Kaw-D-I-D-530-X-106-O-Ring-Chain_W0QQitemZ230163835906QQcmdZViewItem
Those are a few good links to start you off. The prices on www.motorcycleproshop.com are a little high for their chain tools. Z1enterprises has some that are cheaper. I'm sure that if you do a google search you can find them somewhere else for even less.
Good hunting...
zman
PostPosted: Mon Oct 08, 2007 6:55 am Reply with quote Back to top
I`m not a chain guy I know I should be better at it.
I used to use only DID`s back in the 80`s .
My bike now has a regina chain that seems to not stretch and is strong as heck on my 1100.
So can I recomend it?
Blainethemono
PostPosted: Mon Oct 08, 2007 11:40 am Reply with quote Back to top
I usually follow the rule of 100.... Anything you ever want for your bike is going to be $100 or a derivative thereof.... DID, RK, Tsubaki... ALL good chains....
burned
PostPosted: Mon Oct 08, 2007 12:49 pm Reply with quote Back to top
you get what you pay for with chains.get the best one you can afford.
i have had thebest life from regina chains.
larryg
PostPosted: Mon Oct 08, 2007 1:55 pm Reply with quote Back to top
I only buy X ring or O ring chains. You only have to oil them enough to keep them from rusting and thats it. The lube, grease, really is on the inside. Just dont go crazy with degreaser on you bike or the power washer either. I hate the mess chain lube leaves behind. Expensive? Sure, but they should last a good long time. Cool
urhere
PostPosted: Mon Oct 08, 2007 2:54 pm Reply with quote Back to top
Absolutely. When I bought my 900F the chain that was on it had a kink. I got a cheap roller chain to get it up and running but I was constantly readjusting it for slack. Once I got an O ring on it was a different story entirely. What Larry says about the amount of lube is relevant too--roller chains require a lot and most of it seems to spray off on the frame. Go O (or X)!
CoolCat
PostPosted: Mon Oct 08, 2007 6:18 pm Reply with quote Back to top
I just put a Parts Unlimited X-ring chain on my 900F. Haven't even put 100 miles on it yet though, so I can speak to its longevity. It was only about $80 though.
Kevoz
PostPosted: Tue Jan 29, 2008 6:59 pm Reply with quote Back to top
I wish to thank all posters for your input, I ended up with an RK "X" ring chain and am totally happy with it, smooth as silk. Kudos to you all.
Kevo
CB900SS
PostPosted: Tue Jan 29, 2008 7:14 pm Reply with quote Back to top
"Now you know, and knowing is half the battle." Laughing
PostPosted: Tue Jan 29, 2008 8:50 pm Reply with quote Back to top
My personnal favorite sprockets are the CT brand Hardenend Blackalloy. Yes I know these are aluminum but they live longer than the regular soft steel. Now no contest regular aluminum are soft and steel is better,but these hardened aluminum jobs are neat.
The $100 chain line is a good test,but I will say probably MORE than $100 to get the high tensil "O" ring type. Check the chain specs for ultimate tensil strength to make the decision,should be near 10,000 lb breaking strength.
TonyCR
PostPosted: Wed Jan 30, 2008 5:22 pm Reply with quote Back to top
found this old threads, i love to hear how do you lubricate your chains, or if you have found new products or procedures
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=1048&highlight=lubrication
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=784&highlight=lubrication
