  • Total: 110,299,981
  • Today: 51,893
  • Jun 24, 2026
  • 09:49 am PDT
SuperSportCB750F
PostPosted: Sat Jul 23, 2005 3:49 am Reply with quote Back to top
I realized some of you talk of the exhoaut blueing. mine has done that. Its a wierd blue, purple, psychadellic look to it. Why does that happen and is it bad?
razor02097
PostPosted: Sat Jul 23, 2005 4:04 am Reply with quote Back to top
well from the exhaust valve on is subject to very high temps and the chrome can't take it... its like putting a tourch on a piece of metal it will discolor.
usually by proper jetting and polishing forever you can keep this from happening.... and no its not bad.
SuperSportCB750F
PostPosted: Sat Jul 23, 2005 4:05 am Reply with quote Back to top
so good or bad?
razor02097
PostPosted: Sat Jul 23, 2005 4:06 am Reply with quote Back to top
Ratfink
PostPosted: Sat Jul 23, 2005 5:08 am Reply with quote Back to top
See what happens is you have a high LSD content on your chrome.
Could be acid too. Or was it extasy?
Man. all this pot is making me forget things.
INTIMIDA2OR
PostPosted: Sat Jul 23, 2005 5:54 am Reply with quote Back to top
In other words a High luster of colors can be totally groovy!
But proceed with caution too many heavy colors can be catastrophic sending your chrome on a bad trip Man Laughing
<Lee> Cool
bristle
PostPosted: Sat Jul 23, 2005 7:14 am Reply with quote Back to top
here's one for Ripley's....beleive it or not,
the pipes on my old 76 cb750 were going a bit shabby with the usual pitting & surface rust - so i got the old steel wool out and gave them a clean up,
then for insurance i rust treated them head to toe..... cleaned all that off with steel wool and polished them again,
a month later and after a couple of rides i have noticed that the trippy colours have not come back, instead they now have a slight yellowish tinge that is only noticeable to the discerning eye.
Believe it or not.......
warpspeed
PostPosted: Sat Jul 23, 2005 9:22 am Reply with quote Back to top
You don't say if your pipes are stock or aftermarket, and are you running stock carbs and airbox or pods? Blueing is from exhaust heat. It COULD be a sign of lean running. Stock CBF's with stock pipes do not seem to blue much, if at all, from what I have seen. Some aftermarket pipes will blue tho, since they are cheaper, thinner, etc. If you have made mods that make your bike run leaner, that also could be causing it.
The blueing itself is harmless, but if you are running too lean, you might have some problems. If your bikes runs fine, no stumbles, etc, you are probably ok.
900Supersport
PostPosted: Sat Jul 23, 2005 10:15 am Reply with quote Back to top
My 750F just yellowed ..... I don't remember if my first 900F turned blue or not, but my current one is discolored with at blue and yellow tint at near the head Surprised ..... it doesn't bother me much, it is just what happens Laughing
Pete83
PostPosted: Sat Jul 23, 2005 9:50 pm Reply with quote Back to top
This is just one more reason I prefer black pipes.
2005 Honda ST1300
2007 BMW R1200 GS Adventure
Ratfink
PostPosted: Sun Jul 24, 2005 1:07 am Reply with quote Back to top
The stock pipes had two layers. This made them heavy, but they did not blue as much.
chris900f
PostPosted: Sun Jul 24, 2005 7:17 am Reply with quote Back to top
Correct. The stock pipes will generally only show blueing at the end of their lifespan when the inner wall of the pipe begins to break up from heat and corrosion. My first set was nice for a while, then showed blueing, then major discolouration, and then tiny pin-holes began to appear in the first bend from the cylinder head.
