  • Total: 122,976,002
  • Today: 109,031
  • 08:22 pm PST
Andy
PostPosted: Mon Mar 14, 2005 3:07 pm Reply with quote Back to top
I’m going to start this thread as my way of sharing the “build up process that’s happening in my shed at the moment. As some of you will know I’ve had this idea in my head to convert my 1100F into some thing alittle special, kinda like a Hot Rodded version of a CBF, with some classic bits – like retaining the twin shock setup – and some more modern bits – like big rims / brakes / USD front end.
So this will be the first instalment of the saga, one which I’m sure will drag out over many months as time and money put progress on hold here and there, but what the hell, you gotta start somewhere right?
GSXR USD Front end install
For anyone thinking about a change of front end to something more modern for the sake of better suspension, easily upgraded brakes and modern rim sizes, and just plain cool looks - I have just completed bolting up a GSXR1100 front end to my bike and it went alittle something like this
1/ get your Honda stem pressed out of the Honda clamps
2/ press the Honda stem into the GSXR lower clamp with a spacer that’s 10mm thick as the GSXR bottom clamp is thinner where the stem goes through it.*NB; This is if you are using a CB1100F Frame (See photo)
3/ have your original Honda bearing pressed onto the stem
4/ get the hole in the top GSXR clamp milled out by 2mm from 22mm to 24mm to let it get over the top of your Honda stem
5/ bolt it all up
6/ modify the lock stops on the frame to work with the GSXR bottom clamps (for me this comes later under the chapter of “frame bracing and general mods”)
How easy is that? Optional stuff for me was removing all the casting marks from the clamps and clipons. The clipons are actually from a TL1000 Suzuki as they mount under the bars but still come up enough to give what I hope will be a comfortable (but still head/down bum up) riding position. Also, I milled a small rectangle into the top clamp so that I could insert a small Honda badge as seen on most of Honda’s offerings from the past 10 years or so …
Here are some shots to help explain the storey
A comparison of the GSXR clamps with the Honda stem in them next to the original clamps
The top clamp after polishing and with the Honda badge in it
A close up of the Honda badge
The complete stem assembly waiting to get the bearing press back on
The spacer under the Bottom clamp to give the right “spacing” for the stem when it’s sitting in the headstock of the frame.
The view from the top
The view from the front
View from the side
Overall shot
I realise there’s along way to go, but it’s good to get a start and to be honest, I was surprised how easy this was to do once I had worked out the correct spacing for everything and that the GSXR front end was the one to go with for maximum length and bearing / stem compatibility.
BluesMan
PostPosted: Mon Mar 14, 2005 4:13 pm Reply with quote Back to top
I may have asked this before, but what is the length of the forks from axle center to the top???
BTW it looks great!!!!!!!!!!! Wow Cool
fasterspider
It is looking real good Andy, I can hardly wait to see the finished product.
jons
PostPosted: Mon Mar 14, 2005 5:16 pm Reply with quote Back to top
Its obvious from the way you are doing things that this is going to be an incredible bike. Thank you for recording the steps you are taking and I look forward to the next installment. Smile Smile
Andy
PostPosted: Tue Mar 15, 2005 8:29 am Reply with quote Back to top
Thanks for the support guys!
The forks measure 775mm from centre of axle to the top of the fork leg, I know that doesn’t seem like a long leg, but it turns out that it’s the same length I was running on my stock front end when I had the tubes dropped through the top clamp – as can be seen in this shot
The forks themselves can be from any 1991 to 1998 model GSXR as the length is the same on all of ‘em, with the proviso that the bars mount under the top clamp, or you put some mounts on the top clamp to run “normal” handle bars
BluesMan
PostPosted: Tue Mar 15, 2005 2:08 pm Reply with quote Back to top
Thanks Andy.....love that Honda symbol insert too. Cool Mr. Green
Andy
PostPosted: Sat May 14, 2005 5:09 pm Reply with quote Back to top
In this next instalment, we find Andy trying to get a GSXR750L swing arm onto his bike ….. lets cut to the shed –
I thought the easy answer for the question of the GSXR needing a 17mm pivot axle and the CBF having only a 16mm axle would be to just change the bearings in the swing arm to some with a smaller internal diameter than the original, this was not to be. The local bearing shop told me there was nothing made that came in the internal and external size I needed. So off to a hard chroming shop I went. I gave them a CBF “crush tube” (the thing that sits over the pivot bolt and has the bearing surfaces on it) and a sample of the spacer/bearing from the GSXR arm (the short thing in the photo). They gave me back a built up crush tube and now the whole lot fits in perfectly (with new, standard GSXR bearings in the arm of course).
Modified crush tube
I also started on mounting the 1100R tail piece as I need this little bugger on the bike to help sort where some of the frame mods happen. The R tail mounts very differently to the regular CBF side covers and seat, so I needed it on there to work out how / where to put the brackets for the mounts. I also wanted it on there so I could have the bracing for the “rear triangle” matching up with the bodywork as far as the angle of the brace goes; I want to get everything matching …..
This is the reason you can see my frame being hacked into to remove the mounts the rear of the standard seat sits on, coz the 1100R is a different shape underneath the seat and the “platform” that’s ordinarily supporting the CBF seat just gets in the way.
CBF seat “platform”, support, pokie outie thing ….
Cutting it off
While the angle grinder was out, it seemed like as good a time as any to remove the lock stops from the frame as well coz they don’t match up with the stops on the GSXR clamps – I’ll be welding some new ones on …
Cutting off the lock stops
So now I have the tail piece half mounted and my swing arm in waiting to be spaced up along the centre line of the bike (a job for the frame straightener, I don’t want to stuff that one up with my "hamfistedness")
Andy
PostPosted: Wed Jun 22, 2005 7:29 pm Reply with quote Back to top
So now it’s time for another update. After a bit of “dicking around” (that’s a technical term of course) I think I’ve finished getting the bracing of the frame ready for installation. Given that I don’t even know if the frame is straight or not, I’m dropping the bike off at my local “frame Guru’s” work shop where it’ll be placed into a jig, set straight and have all of the bits it needs welded onto the frame – this way the heat from adding the bracing won’t distort the frame and the “centering” of the swing arm / wheels can be done by an expert.
So here are some shots of the bracing I’ve made up
I’m using some different pegs too, as you can see here
The pillion pegs are going to be mounted straight onto the frame near where the original shock mounts are but the rider’s pegs will be mounted using a small “stand off” mount that is basically a piece of 19mm tube cut to fit with a nut welded into it. This will be welded to the frame so that the front pegs have something to mount on, and here’s the combination before the nut has been attached
And another view
There’s a bunch of other stuff I’ve fabricated up as well, like new lock stops, mounts for the tail piece, brackets to lower the oil cooler (coz the fatter fork legs now hit the cooler), new mounts for the fuel tank etc. And not forgetting the upper shock mounts.
These have 3 different holes in them to allow for adjusting the ride height of the rear of the bike – I know it’s a crude way of doing it but I just can’t extend the budget to include some trick shocks, so I’m making do with these
They still have adjustable compression and rebound dampening, as well as a hydraulic adjuster for the spring preload so they’ll do – and best of all they were the right price (about $350.00 AUD)
With the original peg hangers not being used, I’ve also had to shorten the swing arm pivot bolt and the lower rear engine mount bolt too, check it out
Cutting more thread on the engine mount bolt
The difference between stock and modified swing arm pivot bolts
I also picked up the head for my 1123 motor as well the other day. I had left it with one of the local drag bike builders with instructions that I wanted to keep a “fat” torque curve more than top end so I so the flow job matches up alright with the FCRs and the 1123 slugs …
Exhaust porting
The head “face”
A couple of shots showing the inlet porting and the way the ports are matched to the inlet manifolds
Not to forget the wisco kit
So now the next thing is to drop this “work in progress” off on Saturday morning and turn my attention to the rest of the things on my list … (like the seat / instruments / headlight brackets / etc)
PostPosted: Wed Jun 22, 2005 7:36 pm Reply with quote Back to top
Nice work Andy - all that fabrication looks like fun.
jons
PostPosted: Wed Jun 22, 2005 11:34 pm Reply with quote Back to top
Wow! I am so happy you are sharing this process with us. Its obvious you are thinking about every part of your bike. Cool Idea
Andy
PostPosted: Thu Jun 30, 2005 2:26 pm Reply with quote Back to top
Now that the frame is off getting some TLC, I thought I’d better turn my attention to finishing off polishing some of the external motor parts – but first “the Dreaded Clutch Cover Bearings” Shocked
*** How to remove the bearings from a clutch cover in 15, painless minutes ***
I had given this some thought and read a few suggestions here on the board so here’s what I did. First I went and bought some threaded rod, then tapped up part of my cover to protect it.
I started on the outer bearing first by using a bolt with the same size head as the outside diameter of the bearing, then I poked it through the bearing and out the other side, and through a 22mm socket. I put a washer and nut on the end and just did the bolt up – very slowly …. And hey presto, the bearing slid out
Next I got the threaded rod and strategically placed some nuts and washers on it (shown here with the end washer and nut on it – naturally the rod has to be fed from the outside of the clutch cover, through to and past the inner bearing before actually putting the last nut and washer on).
Then it was just more of the same – slowly tightening up the nuts from the outside of the cover as shown below
The hardest part of the whole thing was finding the right sized washer for the inner bearing removal from the “pile o’ parts” that I’ve got sitting in the shed (as we all do I’m sure). Once this was found the whole operation took about 15 minutes from start to finish for both bearings!
If only I’d stopped to think of this before I had the bastard bead blasted I wouldn’t have stuffed the bearings either Rolling Eyes
Andy
PostPosted: Fri Aug 26, 2005 2:18 pm Reply with quote Back to top
Well, the old girl is still sitting at the frame guy’s workshop. I dropped it off at the start of July with one of those “ideally I’ll get it back from you mid August ...” conversations. I found out he only put the bastard in the jig on August 19th... Fu$#..... still, word around town is that his guy’s work is the best so better to wait abit longer and have the job done to a higher standard (so I keep telling myself). Heres some shots of the beast in the jig
Streblerm
PostPosted: Fri Aug 26, 2005 8:27 pm Reply with quote Back to top
Fpro
PostPosted: Fri Aug 26, 2005 10:22 pm Reply with quote Back to top
Andy...bike looks great. Whats the length of those shocks eye to eye? And are those off the GSX14?thanks
Andy
PostPosted: Sat Aug 27, 2005 2:28 pm Reply with quote Back to top
These shocks are indeed from a GSX1400, the measure 330mm eye to eye (note that’s not eye to fork). All I’ve done to them was disassemble them and paint the springs red.
I figured these were the way to go because they were cheap (from a wreckers) and as most of the trick after market stuff these days has a 330mm eye to eye measurement, I might as well start off with shocks that fit that spec, them if I happen to fall into a bucket of money and buy some $2000 Ohlins, they’ll still fit.
Incidentally, I believe these shock are for all purposes the same as those on a ZRX1100/1200 – the only difference I can see is that the GSX ones have a hydraulic adjuster whereas the ZRX ones use a stepped collar (7 positions I think) ..
maru
PostPosted: Thu Dec 01, 2005 6:44 pm Reply with quote Back to top
Any updates on your project? Very cool by the way. Who sells the tank and seat?
valveshim
PostPosted: Thu Dec 01, 2005 7:38 pm Reply with quote Back to top
Not sure about all the other dimensions on your front end geometry, but judging just from the pics with the comparison between the original and new triple clamps, you are basically eliminating the offset and thus increasing the trail. You better sign up with a good weight room to build some arm strength because you may need it to muscle the bike into the turns... Shocked
Andy
PostPosted: Tue Dec 06, 2005 3:01 am Reply with quote Back to top
There’s not been much news to report lately – things have been happening but so slowly
Anyway, here are a couple of shots of the new exhaust system. I wanted to get a complete system made up - to be topped off by the Yoshi RS3 can – so that the muffler sat where I wanted and that there would be no ground clearance problems.
Additionally, I had figured that a 4-2-1 would probably give a slight advantage over a 4-1 when it came to midrange torque. (after all, I don’t think the motor will be lacking in top end power).
So, these shots show what has been done so far. It has 1 7/8” headers that closely follow the down tubes of the frame in a fashion similar to the stock headers, with the pipe sweeping up on an angle much steeper than on any of the “out of the crate” pipes I’ve seen for sale.
I like the way things have come along with the system as a whole, but have asked the guy to extend the collector pipe by 50mm so as to move the muffler back a bit more, after that I think it’ll be about right.
As for the metal strap holding it on, that won’t last! It’s just there temporarily as once the final location of the pipe is sorted, the whole bike goes back to the guy who’s doing the welding on the frame bracing to have the rear footrest hangers mounted to the frame which will support/mount the muffler.
I also got the phone number of a shop that can mod some cams up to 1100R spec (i.e., not to wild but better than the stock “F”) so I’m going to send off some 900F cams I have here to get modded, then my 123 motor can have the “R” cams, and I’ll have my stock 1100F cams to put in my 900.
fasterspider
PostPosted: Tue Dec 06, 2005 3:16 am Reply with quote Back to top
That is starting to take shape nicely. When are you going to put that motor together and when are you gonna buy the Dyna?
I have been jonesing real bad for some of those 91 GSX-R1100 forks. Since I saw this CBX sporting the same suspension as your bike, I can't get it out of my mind and I am now looking to come up on some of the same for one of my builds.
For now I am going to satisfy my jones for a build with F-2 wheels, forks & Pro-Link suspension but that can change if the 91 GSX-R1100 forks appear. I have one of those swing arms and the three spoke Zuki wheels but, no rightously long upside down forks. Sad
Andy
PostPosted: Tue Dec 06, 2005 3:36 am Reply with quote Back to top
I hear ya Ray! Thing s have been getting tighter around here with my Deb now cutting back to part time work and all, and it seems everything I touch just costs more bucks – that exhaust will run to $1000 no problem - but there is light at the end of the tunnel!
My work is sending me OS and as a result there’s gunna be a cash bomb dropped on my house! So in a couple of weeks the Dyna purchase should cruise through – I’m going to be in touch about that real soon!
As for the USD front end, the GSX-R1100 ones seem to be the go for ease of installation, but if you could find some forks from a Kawasaki ZX9, and then use the clamps from whatever year model CBR919 / CBR945 that had those “gull” type top clamps, you’d have heaps of length from the front end – it’s actually a combination I didn’t think of until after I bought the Suzook front end, but I’m guessing it may just be an ideal combination of parts …
CB900RR
PostPosted: Tue Dec 06, 2005 6:05 am Reply with quote Back to top
Only respect Andy, it looks totaly awesome Cool Cool
fasterspider
PostPosted: Tue Dec 06, 2005 2:28 pm Reply with quote Back to top
maru
PostPosted: Wed Feb 01, 2006 12:59 am Reply with quote Back to top
I am really jazzed about this project, Andy. Usually I prefer the more conventional F bikes done up with periodish stuff and stock F bodywork ALA the OMT bike, but your project is really cool. Who made the bodywork? Steve
Andy
PostPosted: Tue Feb 28, 2006 4:09 pm Reply with quote Back to top
The tank is from a place in Sydney called Homebush Fibergalss
fasterspider
PostPosted: Tue Feb 28, 2006 4:22 pm Reply with quote Back to top
Suzuki Marauder forks are long enough and the look similar to the GSX-R1100 forks on your bike. The only thing is they only have the drilled holes for the caliper hanger on one side. One would need to drill out the other side for dual front brakes.
I found this by accident one day doing a motor swap with my buddy Edgar at the shop.
My thread on these forks.
gtom5152
PostPosted: Wed Mar 01, 2006 7:28 am Reply with quote Back to top
Andy you bloody champion, its looking good mate!
The fork conversion would not be to different for the 900 frame would it?
Your covers are going on the bike this weekend, I also found a place to build a replica Corbin seat for me, and a balance will be done to the carbs on Friday, sadly it will be done by my mechanic and not me.
Mate I realy envy you, once I finish Uni this year I can start building my dream F, I'm sure without the help of the board I would not have the confidence to embark on such a adventure.
Good Luck with the rest of the build mate, I'm sure with your skills any hiccups will be minor, once again Bloody Champion!
red750
PostPosted: Tue Jun 13, 2006 11:28 am Reply with quote Back to top
I gots to see more... bump Smile
Andy
PostPosted: Sun Jul 16, 2006 2:35 pm Reply with quote Back to top
This year has brought some ..
Chris41
PostPosted: Sun Jul 16, 2006 11:48 pm Reply with quote Back to top
Chin up Andy life does seem to to drop a bucket of shit all at once doesn't
it. We plan to do the titles at Mac Park in November any chance of you coming over and catching up?. We should have our SOHC side car my now CB900F and maybe the Kawi, its getting pretty close I may put an uncut litre sprintcar engine in it to get it going till I build a full race engine. My local bike shop will rebuild my CB1100 engine for me but thats when I can afford the parts.
Best Regards Chris.
fasterspider
PostPosted: Mon Jul 17, 2006 1:13 am Reply with quote Back to top
Wow Andy, you had some time of it this year but you are still here to kick ass and take names.
A Super F with a full fairing? That should be interesting. Hurry up man Wink
Page Generation: 0.17 Seconds
