| Author |
joew7139
Sat Jan 08, 2011 7:51 pm |
I need a stand to hold a CB750F motor while I take down top end. Does anyone know where I can find one reasonable or have plans to build one?
I tried to do a search but kept getting cannot display page message. I would appreciate any help I could get. |
silversurfer1050
Sat Jan 08, 2011 8:37 pm |
I was thinking of building one. I'd like a suggestion too if anyone has one.
Tx
Bill |
Sat Jan 08, 2011 9:39 pm |
Do you have an auto engine stand,like one of those cheapy Chinese ones?
It takes three pieces of metal to adapt one of these to hold a bike motor.
Use two angle pieces same size say 2" on each leg and 1" wide. Bolt hole in end of each leg.
Now the harder piece to find is a much larger angle piece say 4" wide by 4" on each leg.
The large angle piece bolts in the center of the engine stand mine uses 4 bolts into the engine stand slots and the two angle pieces on each side. A motor mount bolt goes through the two and the larger piece you use a piece of wood as a shim to flip it over to do transmission.
The top rear motor mounts are where it attaches and the shim piece lays on the top of the transmission area. |
Sat Jan 08, 2011 10:37 pm |
I found this thread and copied the theory behind it. Mine was a whole lot simpler, but also holds the motor upright for working on the head. Both allow you to "flip" the motor for access underneath.
Basically, 2 "L" brackets attached to a flat surface with a rod that goes through the rear motor mounts. These pics are worth a million words (thread and pic courtesy of Stoutblock):
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=40343&highlight=engine+table
This was my cheapo version. I could slide the mount with motor on it off the table, onto a hand truck and move it easily around (like outside to clean and paint it):
Steve |
_________________ ‘79 CB750(810)F, \'81 CB900(985)F, \'82 CB900(Going to be 1100)F, \'82 CBX, \'06 WeeStrom, ’18 Kawa Z900RS, \'22 CanAm Ryker Rally |
Pointdiver
Sun Jan 09, 2011 6:19 am |
I modded this $50 stand from harbor frieght.
Hondamax
Sun Jan 09, 2011 11:21 am |
Something like this? |
_________________ 1979 900Fz (from new) - NC30 Single-sided Swingarm, CBR1000F Forks, Tokico 4-Pot Callipers, Hindle 4:1, 985cc, to be recomissioned
1981 1100Rb - Rider (may sell)
1982 1100Rc/Rd Bitza - Started
1984 VF1000R - Started
1979 900Fz - Stored |
grimmace4
Sun Jan 09, 2011 12:32 pm |
I like my K&L engine stand that I bought from Old Bike Barn. It is a model MC25 and can be found here:
http://www.oldbikebarn.com/K-L-MC25-Metric-Engine-Stand
_________________ 1980 CB750K - Sold to San Ramon, CA
1980 CB750C - Sold to Grand Rapids, MI
1982 CB900F - Sold to Dorr, MI
1983 CB1000C - Sold to Ann Arbor, MI
1983 CB1100F Blue #1 - Sold to Honolulu, HI
1983 CB1100F Blue #2 - In Garage |
roosroast
Sun Jan 09, 2011 2:03 pm |
Thanks for those pics of the engine! Now I understand the whole shim business! The cam lobes actually push the valves directly! |
joew7139
Sun Jan 09, 2011 3:50 pm |
Thanks for all the great info!!! |
txscbf1100
Sun Jan 09, 2011 5:43 pm |
Heres mine. The engine is bolted down from underneath where the bolts that hold the exhaust normally go.
That cut out on the side allows a jack to roll underneath it to help get it out of the frame.
Good luck,
David |
Hondamax
Sun Jan 09, 2011 10:34 pm |
I like it! Anyone know whether these are available from any one in the UK or Europe? |
Sun Jan 09, 2011 11:27 pm |
If you have the engine stand all it takes is a couple of angle pieces and bolted to the motor stand face plate.
This mounts to only the top case so you can work on top and bottom of the engine.
Enterprising to use the all thread and spacer tubes to use all the mounts. |
Hondamax
Sun Apr 10, 2011 8:41 pm |
Bumping this thread because I've finally got an engine stand that works ...
The different holes allow me to use any combination of the engine mounting holes, so that every part of the motor is accessible. Plus, I can flip it over on its side or upside down.
It was fabricated by a guy in NI who advertises them on ebay for Ducatis. He modified the Sealey faceplate (OK, drilled 3 holes) to take his mounting plate.
The mounting bracket assembly fits on a Sealey 350Kg engine stand. |
Jeremyg1283
Sun Jul 19, 2015 4:47 pm |
Arw those K and L Standa available still? |
cbxdog
Sun Jul 19, 2015 6:28 pm |
| Jeremyg1283 wrote: |
http://www.amazon.com/Supply-Metric-Engine-Stand-37-9352/dp/B000GV3DSE |
_________________ 1979 CBX
1980 CBX
1980 CB1100RB Replica SC05 engine
1982 CB1100RC - basket case
1970 HD FLH
1976 HD FX
1983 HD FXRT
1988 FX 85th anniversary
1970 AMC Javelin
1982 AMC Spirit 360 5 speed |
Jeremyg1283
Sun Jul 19, 2015 7:45 pm |
I bought it! That mc25 rules! |
Erock
Mon Jul 20, 2015 12:31 pm |
Mon Jul 20, 2015 3:30 pm |
Nope. |
_________________ Cary |
Testr
Tue Jul 21, 2015 12:24 am |
