  • Total: 73,599,021
  • Today: 54,188
  • May 01, 2024
  • 06:14 pm PDT
Straycat
PostPosted: Tue Aug 01, 2023 12:28 am Reply with quote Back to top
Vent time.
So getting ready to do my wheel bearings as part of the restoration and I find there are wheel bearing retainers on the front wheel, rear wheel and the Cush drive...OK thats fine....BUT, Why does it require 3 different tools to remove them !! What the heck was Honda thinking ?
I bought the tool listed in the manual (said it did all of them), but it only fits the rear wheel (4 holes). Front wheel has 4 slots, so got that one off with a drift/screw driver, now I need a different size tool fo the retainer on the Cush drive FFS because the holes are spaced further apart than the rear wheel.
Pure madness!
Here Endeth My Rant
kiwihonda004
PostPosted: Tue Aug 01, 2023 6:46 am Reply with quote Back to top
I'm with you.
I have used a spanner for removing grinding discs on elect tools.
Not perfect but has been successful and looks better after and not butchered.
P A Hyland
Straycat
PostPosted: Thu Aug 03, 2023 2:36 pm Reply with quote Back to top
Agreed, im not gonna use a drift on the ones with 4 round holes.
82 CB900 Super Sport & 19 other bikes
gamve
PostPosted: Fri Aug 04, 2023 1:57 pm Reply with quote Back to top
have a look on epay for adjustable pin spanner. they look like a divider measuring tool but have pins located 90 degrees on the end of the legs. Most have two pin sizes back to back. Being like a divider you simply spread the legs till the pins fit the pitch circle diameter.
