TCRacing
Fri Sep 22, 2017 2:26 pm |
I decided to go with a set of 1994 Honda CB1000SF Forks based on the design, length, and size - 815mm [32.09”] – [43mm dia.] – [20mm dia. axel]. It gives it that little extra detail to the build. |
_________________ Back into the 80's
1981 CB750F
AFM # 919
AMA # 454
Current TCR Projects:
1982 CB750F
1983 CB1100F X SOLD
TCRacing
Wed Oct 25, 2017 3:49 am |
TCRacing
Sun Feb 04, 2018 3:32 am |
Slowly getting a few of the details handled. Parts in silver and clear coat. Just have to install decals and clear coat again. Work currently being done by Craig @ Paintworks |
1981 CB750F
AFM # 919
AMA # 454
1982 CB750F
1983 CB1100F X SOLD |
Sun Feb 04, 2018 3:44 am |
Craig does great work. Color matched the blue 1100 perfect . |
TCRacing
Tue Jun 12, 2018 11:39 pm |
I recently sent my frame out to have it straightened (back in the day, OEM frames were rarely straight to begin with). Now I have a decent baseline to work with prior to these frame modifications being completed.
Another phase completed.  |
1981 CB750F
AFM # 919
AMA # 454
1982 CB750F
TCRacing
Tue Jul 31, 2018 11:04 pm |
Wed Aug 01, 2018 3:41 am |
Wed Aug 01, 2018 12:32 pm |
What was your reasoning on moving the upper shock mount?
Certainly i have seen aftermarket swingarms with multiple mounting points to change the angle. |
TCRacing
Wed Aug 01, 2018 2:43 pm |
smurdoch wrote: |
What was your reasoning on moving the upper shock mount? |
Laying the shock down by moving the top mounts forward allows increased wheel travel (for the same length shock) and makes shock compression more progressive so you can run a stiffer shock while retaining a softer initial feel. |
1981 CB750F
AFM # 919
AMA # 454
1982 CB750F
djf18374
Wed Aug 01, 2018 3:36 pm |
I have a set of these CB1000SF forks and a blackbird swingarm. I'm thinking of taking on a project restomod...Could you tell me what was done to the triples and front end to make the Forks work? Wheel choice and spacers/Adaptation?
Similar question of the rear end if I wanted to use the Blackbird rear if not too far off topic on this thread? |
_________________ 79 CBX (silver)
81 CB900F (silver)
82 CB900F (black)
83 CB1100F (red)
2014 CB1100 DLX |
TCRacing
Thu Aug 02, 2018 12:17 am |
djf18374 wrote: |
I'll do my best to address at least the CB1000SF forks that lead me to go in a different direction based on the wheels I have chosen for this build. I decided to go with the Suzuki GSX-R600/R750 OEM Straight Spoke Wheel Set [2006-07]. These wheels have a similar look to the DYMAG's and the axle size for this front wheel is 25mm dia. which is 5mm larger than the CB1000SF axel [20mm]. That in itself was not too much of an issue if you went with something like a front wheel from a Honda CBR600 F2 [1994] which has a 20mm front axle as well.
The other issue I came across is if I were to use the CB1000SF triple clamps which happen to have a Fork Spacing/Pitch of a 192mm. This amount of spacing would not accommodate the wheels I selected.
If you are planning to use these forks, you will also need to consider the rebuilding them by a professional who can do the re-valving and the correct springs for the bike and riders weight.
As for the Blackbird Swingarm: There are other members here that have the knowledge as to what is involved in the fabrications and/or modifications of this swingarm. I do have some notes if you need some information to go off of. |
1981 CB750F
AFM # 919
AMA # 454
1982 CB750F
djf18374
Thu Aug 02, 2018 1:12 pm |
Thanks, will keep all that in mind for a later date Please send along a PM and I'll give you my email to send notes at your earliest convenience. |
81 CB900F (silver)
82 CB900F (black)
83 CB1100F (red)
2014 CB1100 DLX |
Mon Aug 06, 2018 3:10 pm |
TCRacing wrote: |
First Item.... Check!
"There might be a little dust on the bottle / It's one of those things that gets sweeter with time…" |
Extremely belated post here regarding your AHM exhaust system pictured above. Is this a street pipe version or the true full on race pipe? Why do I ask? Well I had a race version back in the day and I found out after many attempts to mount it to my street bike that a dry sump oil system was required to allow it to fit (oil pan delete doncha know). Without the dry sump system the head pipes will not clear the stock oil pan. Just wondering in.
Re: Blackbird swing arms. Darren aka. Petrat did a Bird arm install on his world famous "Super F " build. Here's a link:
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=41388
T. |
TCRacing
Mon Aug 06, 2018 3:53 pm |
Hey T,
The AHM Exhaust that is posted is designed for the dry sump oil system. It was verified by having it mounting to a motor that had dry sump oil system installed. Hopefully, I'll be able to use this one as a template to create the street version [once I find the talent and the time].
Thanks for sharing the link  |
1981 CB750F
AFM # 919
AMA # 454
1982 CB750F
TCRacing
Sat Jun 22, 2019 2:53 pm |
In an unknown secret location. I am finally getting the last detail completed on the frame. Things should be progressing a long nicely once this modification has been completed. |
1981 CB750F
AFM # 919
AMA # 454
1982 CB750F
TCRacing
Wed Jun 26, 2019 2:41 am |
In an unknown secret location. The final details have been completed with attention to details. The steering neck modification will be one of the most beneficial changes to this chassis. |
1981 CB750F
AFM # 919
AMA # 454
1982 CB750F
Junwa
Mon Jul 01, 2019 2:05 am |
How significant is the steering angle change and what is the impact to wheelbase and handling?
Is the frame bracing kit still available still available?
Jun |
DirtyT
Mon Jul 01, 2019 6:25 pm |
TCRacing
Mon Sep 28, 2020 2:47 pm |
hondaron
Mon Sep 28, 2020 4:54 pm |
Bryce960
Mon Sep 28, 2020 11:42 pm |
So cool man! And supper inspiring being able to see this in person. |
_________________ 1980 CB750F |
Tue Sep 29, 2020 1:43 am |
Beautiful!
Just curious, it looks like the upper shock mount is about 3" forward? What length shocks are you using? |
Tue Sep 29, 2020 2:06 am |
Looks great..keep going!! |
_________________ Greg |
TCRacing
Tue Sep 29, 2020 8:43 pm |
smurdoch wrote: |
Beautiful!
Just curious, What length shocks are you using? |
I figured the shock length to be 330 mm + 5 mm adjustable length. [325 mm @ 11.5 deg.] |
1981 CB750F
AFM # 919
AMA # 454
1982 CB750F
Tue Sep 29, 2020 9:18 pm |
