Mon Feb 20, 2017 11:41 pm |
What I forgot to mention is that I have enough nail polish left to do everyone's nails at the NE Spring Ride.  |
_________________ 1983 CB1100F
1981 CB985F |
Mon Feb 20, 2017 11:50 pm |
It looks great, hope it survives the heat cycles! |
_________________ 1983 CB 1100F
1988 GL 1500
Papinbrew
Tue Feb 21, 2017 10:14 pm |
sillygoose wrote: |
Papinbrew wrote: |
Or barely seat the bearings, and pull them before PC? |
I think that would work, with no engine in the frame not much of a load. When done they should fall out with just some small taps to the outer races. |
I ended up fully disassembling the wheels and dropping them off for powdercoat yesterday. I figured I would just get that part done, then properly seat the new bearings in, new tires and valvestems on, and I wouldnt have to pull them apart a second time. Plus that will give me time to work on white lettering the tires, and finishing the airbox paint. Next up is ordering all gauges from DCC, and sourcing a Yoshimura RS3. Oh, and cleaning up my swingarm. I got some proper quotes for powdercoat, I am gonna skip the black frame and go fancy, like a deep candy metallic wine red frame, calipers, and have everything else a gloss black including the tank. That will make the frame aesthetically pop. |
TCS1100F
Tue Feb 21, 2017 11:15 pm |
New rear brake fluid in both 1100's today in UT. All the other bikes that needed it too. Sprint, Ducati, DR650 got the front done. |
Grumpy32
Tue Feb 21, 2017 11:30 pm |
[quote="TCS1100F"]New rear brake fluid in both 1100's today in UT. All the other bikes that needed it too. Sprint, Ducati, DR650 got the front done.[/quote
H-D Sprint? Tits little bike... I had an, I think, 72 350SS. What a thumper.  |
_________________ Terry
07 cb 900f hornet 919... the fastest Red one. |
TCS1100F
Wed Feb 22, 2017 2:08 pm |
Nope, Triumph Sprint ST 2003 Great bike. 3 Cyl 60 mpg. |
Wed Feb 22, 2017 3:47 pm |
Cleaned up the shed and wheeled my bikes around. |
CT110 Hyper Sport |
Grumpy32
Wed Feb 22, 2017 8:19 pm |
TCS1100F wrote: |
Ahh...there was more than one... |
TCS1100F
Wed Feb 22, 2017 9:32 pm |
But I did have a 1966 Sprint CRS! Good race bike and fun till the 2 strokes arrived.. Also had a 350 CRS but didn't work either! |
Papinbrew
Wed Feb 22, 2017 10:11 pm |
Ordering a heap of parts. Got my daymaker headlight, brackets, wheelbearing retainers, o rings, led signal strips, and license plate lights all set up and ordered. Im stuck on sprocket and chain ordering. Theres an ebay lonk with voltar and JT stuff, whats the stocker sprocker (lol) sizes?
Edit. NVM, I ended up ordering the eBay Voltar Nickel plated 520 chain with JT 18F and 46R. Should match my color scheme ok. Next up is exhaust. My custom shop guy wants to fabricate me a resonator to match the midpipe he will be making for me, basically a handmade muffler with large open end. I was planning on a Yoshimura RS3 simce I really like the tone and the look, we will see though. |
_________________ 1985 Honda Magna VF700C main whip
1972 Honda CL175k6 Scrambrat "Lil Espo"
1980 Honda CB750F Super Sport "Spectre" WIP |
Fri Feb 24, 2017 1:43 pm |
Started to hang the exhaust on CBX #9 then took the 1100 out for a short roll. Glenn won't recognize this bike when I'm done............. |
_________________ J.R.
Randakk Approved Carburetor Rebuilder
Dealer for KOSO Instruments |
huck731
Fri Feb 24, 2017 5:58 pm |
I swapped all of my gauge pod lights to LED, by the end of the season, all of the lights on the bike will be LED. |
_________________ 1981 cb750f
1969 cb77 superhawk
1984 vf700f |
Fri Feb 24, 2017 6:19 pm |
CBX-tras wrote: |
Nice polishing job on the Comstar rims J.R. Tell us how you did it. |
_________________ www.tomscyclerecycling.com
CB1100F's - multiple flavors |
djf18374
Fri Feb 24, 2017 6:33 pm |
Also what size tire is that on the CBX rim? Is it a 79/80 or is it a 81/82 Prolink? I'm trying to decide how big of a Shinko 230 I can put on my CBX.
Thanks! |
_________________ 79 CBX (silver)
81 CB900F (silver)
82 CB900F (black)
83 CB1100F (red)
2014 CB1100 DLX |
Sat Feb 25, 2017 1:17 pm |
tomk1960 wrote: |
CBX-tras wrote: |
That part was easy. We have a local polishing shop that did both wheels for me - $120, had them back in a week. BTW, this was another set of wheels I had. The ones that were on the bike, the fasteners that hold all the pieces together were too corroded to re-use. I may experiment on taking them apart (not recommended by Honda) and replacing the parts in question one at a time.
That REALLY puts a finishing touch on the bike. |
Sat Feb 25, 2017 1:27 pm |
djf18374 wrote: |
Thanks! |
ProLink '82. That's a 130 width that I don't believe you have the room for on a twin-shock without torque arm modification.
If you need your's done, I can slice it apart and TIG it for you. After re-paint you won't be able to tell the difference. |
basmn
Sat Feb 25, 2017 2:43 pm |
[quote="Grumpy32"][quote="TCS1100F"]New rear brake fluid in both 1100's today in UT. All the other bikes that needed it too. Sprint, Ducati, DR650 got the front done.[/quote
H-D Sprint? Tits little bike... I had an, I think, 72 350SS. What a thumper. [/quote
😆 my brother had a 68 HD 350 ss sprint when I was 12. That's the bike I learned to ride on. It would eat the 350 hell cat for breakfast if I remember correctly. It was fun to start... 😉 .we used to lean it up against the garage and try to kick it over.... went air born on several occasions. |
_________________ 81 750F stock
83 1100F stock
08 FZ1
03 YZF R6 track only
10 shadow rs.. brides ride
XR100 pit special
CRF 230F X2
80 CB750C...on the lift
YZ250FX dirt monster (: SOLD
2018 Polaris 570..for me.. |
Mon Feb 27, 2017 12:22 am |
Along with a bunch of customer parts I had to finish, I powder coated the swingarm for my son's 1100F and pressed in new bearings.
The adjusters were a totally disgusting mess, so I degreased them, media blasted with aluminum oxide, then finish blasted them with a super fine microblast media that leaves the aluminum looking new again. The before and after pics show a "slight" improvement.
I polished the end caps as well and will replace the nuts with new ones. Little details, but worth the extra time.
Mon Feb 27, 2017 12:36 am |
tomk1960 wrote: |
I polished the end caps as well and will replace the nuts with new ones. Little details, but worth the extra time. |
Amazing difference in the before and after pics. Always wondered about the washers on the chain adjusters, not shown on the 1100f parts fiche but seems like a good idea to keep the nut from digging in. |
1981 CB985F |
Mon Feb 27, 2017 9:38 pm |
sillygoose wrote: |
tomk1960 wrote: |
I agree that the washers are a good and very inexpensive improvement. I've actually seen them used on a number of 1100F swingarms and always assumed that they came that way from the factory. |
Papinbrew
Tue Feb 28, 2017 4:29 pm |
Those parts look great Tom.
Im finishing the last layers of engine paint on my airbox. I had a section run on me in the detail lines of the side covers, so i used my knife to peel out the truckbedliner out of the recessed lines, masked up and painted with the silver. Wasnt what I wanted originally, but its eye catching none the less. Among other progress, Ive ordered the final major bits for the bike. DCC gauge cluster, bracket, magnetic drain plug. Ive taken delivery of my NOS wheel bearing retainers, and my JT sprocket set with Voltar Nickel plated chain.
My buddies told me I should save myself the effort and take my tank to a radiator shop, they say its $150 to have it fully treated, rust removed and lined, and then I wont have to spend so long shaking screws and bbs in my tank. What you guys think? I picked up the POR15 starter kit on Amazon just to seal the tank. Since ive picked up the tank over a year ago it was furry with rust internally, ive ran a few rounds of CLR through with BBs, then a quick round of Evapo-Rust, and now its just sitting in my basement till its the center of attention again. Evapo-Rust with water soak? Or full strength and shake techniques? |
Fri Mar 03, 2017 11:57 pm |
Mixed up and sprayed a custom tri-coat for CBX #9, shown here before the clear. Monday, I'll block and add the 2 tone to the tank and tail piece and place the stickers before waiting a couple of days to re-clear, allowing the stickers to off-gas and cook under the radiant heat.
It might look dark here but, in the sun it just dazzles! |
Papinbrew
Wed Mar 08, 2017 6:31 pm |
I got my rims back from powdercoat. I was initially worried that a single color without a twotone trim would look bland, boy was I wrong. Gloss black all over really highlights the rim details. Packed my swingarm in the jeep today, will stop by a carwash to pressure wash it down, then start bringing parts back to the custom shop to build the roller.
1980 cb750F rims back from powdercoat https://imgur.com/gallery/93A6f |
Thu Mar 09, 2017 1:27 am |
If you don't mind, how much did the powder-coating cost?
Did they do all the prep? |
Papinbrew
Thu Mar 09, 2017 5:02 pm |
smurdoch wrote: |
They charged $90 per rim, and did all the prep. I did pull the bearings and discs off first though. The place is called Armorcoatings out of Salt Lake City UT: @Armorcoatings instagram.
Today I took off from work so I could focus on really getting progress done on the CB. Gonna pick up my frame, get bearings seated into the rims, reassemble the retainers and rubbers, install my 90 degree valvestems, and then get the tires on. Hopefully the rest is pretty straight forward. Im a little intimidated by my giant basketcase full of parts |
Thu Mar 09, 2017 5:21 pm |
Prepped my fork damping rods for RaceTech's Gold Valve Emulator kit.
_________________ Cary |
Papinbrew
Fri Mar 10, 2017 2:56 am |
Had a talk with my motorcycle custom shop guys, theyre cutting out all projects that are friends based. I picked up my frame from them and brought all my parts home. Spent about 6 hours today scrubbing every single part, ultrasonic cleaning anything that would fit, wire wheel on all the bolts, screws, and little parts that had corrosion or rust, and then staging it all in my dining room. I officially am building a motorcycle in the house haha. Im just making sure everything is in a section where I can easily build the bike. Lesson learned with projects, having the proper space makes a huge difference, and cleaning parts as I go is paramount. Im never getting drunk and just tossing parts in a box ever again. Im probably never going to buy such a decrepit pile of pure labor ever again either. Ive got my bearings in the freezer overnight, and will try to seat them tomorrow. Also, the first stages of building a roller will begin. Anyways, enjoy these pics of my pile o parts.
Building a motorcycle in my dining room https://imgur.com/gallery/ry4Qg
I also noticed my hand switches are toast. Any suggestions for good replacements? |
Fri Mar 10, 2017 4:27 am |
If you wire wheel the zinc off the bolts (comes off easy), they will soon rust... that is, soon like next year of so. They should be re-plated with zinc to look right and not rust. |
We don't see things as they are
we see things as we are
Viton Valve Stem Seals
12.9 Cam Holder Bolts
Papinbrew
Fri Mar 10, 2017 4:23 pm |
genesound wrote: |
Most of them were already coated with rust and corrosion. Now theyre clean but pitted. As of now I am only focusing on getting the frame to roll, then when it all comes apart again for powdercoat I was going to visit Home Depot and see about replacing as many of the bolts that I can with stainless. |
Sat Mar 11, 2017 5:19 am |
The only component I never opened up when I built my bike were the calipers. With an unknown history and 11,000kms later their performance had gradually degraded in a manner that pointed to sticky pistons and seals. So out they came and after a thorough clean and new seals they're as good as new.
Goto page Previous 1, 2, 3 ... 29, 30, 31 ... 44, 45, 46 Next
