  • Total: 45,693,694
  • Today: 3,273
  • Jan 26, 2021
  • 01:46 am PST
RickP
PostPosted: Thu May 21, 2020 12:42 am Reply with quote Back to top
Hello All
i do have an dead VB56A carburator from a CB1100 mounted on my CB900F 1981...To many time up and down, changing this, trying this... yes air pod are mounted as well and they are a pain, but got to move forward and no more air box..
Either way, it is dead, so i decide to scrap it and replace it with either an CR or an Mikuni, i believe after reading both carb are good quality.
so now if anybody knows what size of CR carb i need for a CB900F is is an CR33 or the CR35? on the web site it is mention that it works for both model!!
and about a Mikuni RS, will it be the RS34-D21-K, the RS36-D3-K or the RS38-D19-K ?
i mean i measure the engine side carb inside measurement and it is 37 mm, but again they are from a CB1100 or else..
I welcome all feedback.
thank you all..
PostPosted: Thu May 21, 2020 2:13 am Reply with quote Back to top
On an otherwise stock 900 I'd recommend a CR31. Or CR33 if you're going to be hotrodding it. With flat slides you can go a size larger.
RickP
PostPosted: Thu May 21, 2020 3:35 am Reply with quote Back to top
Ok thanks for the info, so an CR 31 will fit my 1981 CB900F if not with Mikuni the RS 34 should do it, as long as the rack are adjustable correct?
PostPosted: Thu May 21, 2020 4:01 am Reply with quote Back to top
The CRs have adjustable spacing, the RSs don't, and they aren't spaced correctly for our motors, but these guys make a kit:
https://www.mikunioz.com/shop/re-spacing-kit-for-mikuni-rs-34-carb-honda-cb750-cb900-cb1100/?v=7516fd43adaa
AlaskaGriz
PostPosted: Thu May 21, 2020 4:23 am Reply with quote Back to top
I have CR31s on my Stock (other than 4:1 Pipe) CB900F.
They run rich (at crusing and eventually foul the plugs) even with correct jetting so, the fix is to add CBR Coils and a Coil Relay Mod. This way you can get a stronger spark. I even gapped my plugs according to CBR specs. Rich condition is gone.
They look really good too...
Dave
PostPosted: Thu May 21, 2020 4:57 am Reply with quote Back to top
Yep, still love that bike Dave Wink
And I agree, using better carbs necessitates upgrading the ignition system at least with coils and a relay.
Simonster
PostPosted: Thu May 21, 2020 8:07 am Reply with quote Back to top
I have an 1123 running CR33s, and it's awesome! On a stock 900, 31s. The ignition system will be the next weak point to change.
Happy spannering !
Simon
PostPosted: Thu May 21, 2020 8:53 am Reply with quote Back to top
RickP wrote:
Hello All
thank you all..
The stock carb size is measured near the needle in the venturi not where if fits to the engine
1982 CB1100RC Restoration project
1998 CBR900RRW
PostPosted: Thu May 21, 2020 10:17 am Reply with quote Back to top
Yup, Black Beauty in all it's splendor.
Dave, what boots and spacers are you using with the CRs.
AlaskaGriz
PostPosted: Thu May 21, 2020 3:50 pm Reply with quote Back to top
Thank you. I still love it too. LOL
Boots are stock and spacers came with the Carbs from Dynoman (carbs were already jetted and spaced for my bike right out of the box).
Dave
RickP
PostPosted: Thu May 21, 2020 6:47 pm Reply with quote Back to top
Beautiful bike Dave, wow..
question with the CR i guess you had to change as well the push/pull throttle assy no? so basically change the left command..
AlaskaGriz
PostPosted: Sat May 23, 2020 9:01 am Reply with quote Back to top
Rick,
I didn't have to change anything. These are Plug-n-Play. But....... need to improve the spark with the mods I mentioned.
Dave
Page Generation: 0.29 Seconds
