  • Total: 40,026,296
  • Today: 13,133
  • Sep 22, 2020
  • 01:18 pm PDT
Supervetteracer
PostPosted: Tue Nov 19, 2019 12:13 am Reply with quote Back to top
Got a blue one, all factory paint. Local shop has been working on this same bike since it was brand new. It's had a life. At one point a guy ran into something and had to replace the front forks. It now has a rebuilt title (From 20 years ago). Tires are good. It has a crack in the plastic cover of the speedometer. And the speedometer doesn't work. The shocks a very soft as are the front forks. They don't leak, just soft. It's a really neat bike and I am looking forward to riding it around.
The bike runs strong for an 83 1100f. The shop said the owner just had the entire motor rebuilt last year for $3800.00. Clutch is good. Brakes are good (for an 83).
The parts that I know I need are a new instrument cluster, and the black piece of plastic that rests in front of the speedometer. Considering buying replacement shocks, looking for recommendations. And I guess I'll go with aftermarket turn signals. I'm sure I'll have more questions once I take it out for a cruise.
PostPosted: Tue Nov 19, 2019 12:26 am Reply with quote Back to top
Might not be the speedometer, check that the sender or inner cable isn't broken. You can spin the end with a drill and a flat blade screwdriver bit to see if it works.
If it is the speedo I probably have a working spare, easy to replace on the 1100f. Compete sets also show up on eBay of someone here doesn't have one. Same with the fuse cover, they are notorious for the tabs braking and then being launched into the wind.
If the engine and brakes are good then you are starting out better than most - welcome to the forum. Pictures of what you have are always nice to help members see what you need to complete the bike.
PostPosted: Tue Nov 19, 2019 2:34 am Reply with quote Back to top
Welcome to the site, Vetter.
Congrats on the purchase of your F.
It's unfortunate that you didn't get the faster Red model but the Blue ones are still good bikes.
Supervetteracer
PostPosted: Tue Nov 19, 2019 3:30 pm Reply with quote Back to top
Ha. I've ridden both. Back in my Navy days a good friend built up a Red one. It was definitely faster than the Blue one that i had previously ridden.
I'm trying to upload pictures but my pictures are too large. Will work on making them smaller after work.
How much am I looking at for a working speed o and fuse panel cover?
Does anyone ever switch out the front forks to something newer? What fits? The one I have has a strong motor. What about aftermarket rear shocks? What is everyone using?
PostPosted: Tue Nov 19, 2019 4:05 pm Reply with quote Back to top
Seems that $75-$125 for the fuse cover depending on condition, one of the unicorn 1100f parts that the rest of the world was spared.
Sent you a PM on spare speedo but make sure it is actually bad, could be the inner cable is broken and I somehow managed to have the blade in the sender break off.
PostPosted: Tue Nov 19, 2019 6:18 pm Reply with quote Back to top
Irfanview is an excellent free image editor
www.irfanview.com
https://www.google.com/search?q=irfanview
Luckysox
PostPosted: Tue Nov 19, 2019 6:30 pm Reply with quote Back to top
Do you need the whole cluster or just the speedo ? I have a fuse cover .
Quickster2
PostPosted: Tue Nov 19, 2019 11:00 pm Reply with quote Back to top
I have a NOS cluster with some slight imperfections in the "plastic cover". Won't be free but would be a nice addition to most bikes.
1980 Black CBX-A
1983 Blue 1123F
2009 Blue BMW K1300GT
Supervetteracer
PostPosted: Sat Nov 23, 2019 6:50 pm Reply with quote Back to top
I found a guy in town that has a garage full of parts for this bike. Heading over to see what he has. If the deal is right I may end up buying everything and listing a bunch of stuff. So I'm holding off on buying anything until I do.
Ona different note, has anyone tried these shocks on your bike?
https://smile.amazon.com/gp/product/B07LCMXPJC?ref=em_1p_0_ti&ref_=pe_2313360_454391080
PostPosted: Sat Nov 23, 2019 11:25 pm Reply with quote Back to top
They work OK as is, but can be made better by a rebuild from Chris Livengood.
Read here: http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=84120&start=0&postdays=0&postorder=asc&highlight=chris+livengood
'79 CB750(810)F, '81 CB900(985)F, '82 CB900(Going to be 1100)F, '82 CBX, '06 WeeStrom, '06 Ninja 500
Luckysox
PostPosted: Sat Nov 23, 2019 11:38 pm Reply with quote Back to top
If you have a stock swingarm , you will need shocks with the clevis bottom end .
Page Generation: 0.38 Seconds
