  • Total: 40,027,715
  • Today: 14,552
  • Sep 22, 2020
  • 01:54 pm PDT
n8n8n8
PostPosted: Thu Oct 31, 2019 7:54 pm Reply with quote Back to top
I called a place local to me regarding renitriding a set of cb1100 cams. They quoated me 250.00. Does this seem high?
The cams are at the bottom of their specs, so I am debating whether it's worth it to recoat them anyways. Any opinions would be appreciated.
1981 900f
PostPosted: Thu Oct 31, 2019 9:36 pm Reply with quote Back to top
Without knowing much about it I can say my new Dynoman cams were several hundred dollars so 250.00 seems pretty good
PostPosted: Thu Oct 31, 2019 10:22 pm Reply with quote Back to top
Nitriding price seems expensive as they are around US $80.00 to do a set here in NZ
But price aside it is always worth doing as the process was done to a minimum on the OEM cams and IMO even lower on the 1100 cams.
The answer is always "more power" always was, always is and always will be.
PostPosted: Sat Nov 02, 2019 1:32 am Reply with quote Back to top
I had a set of 1100 cams dinner several years ago and I think I paid less than $100 for both. Be sure to ask them what nitriding they will be doing to them.
I've used Northeast coatings many times on crankshaft and on my cams and had a ton of valves coated when working in Nascar country.
Not sure if you have to be a dealer or not.
http://www.northeastcoating.com/
Page Generation: 0.25 Seconds
