  • Total: 73,473,290
  • Today: 4,966
  • Apr 30, 2024
  • 01:55 am PDT
PostPosted: Sat Sep 21, 2019 5:33 pm Reply with quote Back to top
Anyplace to get Marving systems in or near the US? I found this on in the motherland but.........Full exhaust exhaust auspuff Racing Honda CB 900 F 1982 marving.
Does anyone have experience with Marving? tx. g
metu71
PostPosted: Sat Sep 21, 2019 10:18 pm Reply with quote Back to top
I have installed a 2-4 set on a 750 and 1100. The one on 750 was a no-brainer to install, no issues what so ever and quality was excellent.
The one on 1100 was not that easy. The bracket for the bolt that is screwed into the oil pan was roughly 5mm off and I had to move it to get it to sit right, but only on one side. Also the center stand rubber bracket was not on correct place and I had to build up an extension to prevent center stand from hitting the muffler. I complained to Marving with pictures and they still said that they have not had any issues with installation and between the lines message was that there is something wrong with my bike. Who knows whats the truth, but it is there now...
PostPosted: Sun Sep 22, 2019 11:13 am Reply with quote Back to top
I have fitted Marving 4-2 systems on 2 of my CB1100F's
They fit well and the bike performs well with them
When fitting you need to position the front pipes in the exhaust ports then, loosly fit the bolt up in to the sump, then fit the exhaust clamps to the head and tighten, then finally tighten the bolt in the sump
I bought both my systems from eBay in Italy, they were cheaper than both Wemeto in the UK and eBay Germany
1979 Honda CBX1000
PostPosted: Sun Sep 22, 2019 3:18 pm Reply with quote Back to top
Thanks for getting that info to me guys. They look like quality goods. I'm looking at the 4-2-1 to raise ground clearance on an upcoming build. mike
PostPosted: Sun Sep 22, 2019 4:53 pm Reply with quote Back to top
My results were like metu71, fit was poor and a year in the finish already looks like crap on a bike that is garaged and not ridden in the rain. The sump bolts are a pain but the left side exhaust hanger alignment was way off. Old thread on this here:
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&p=778565&highlight=marving#778565
The only choice if you want new stock looking pipes but if I had to do over I would pay up for nice stock exhaust.
PostPosted: Sun Sep 22, 2019 5:27 pm Reply with quote Back to top
Mike - I had a 4-1 Marving on my blue 1100F. Fit and finish were pretty decent and the flat collector was 'different';
PostPosted: Sun Sep 22, 2019 5:45 pm Reply with quote Back to top
Look into a Hindle 4x2x1 Mike. Most ground clearance available
PostPosted: Sun Sep 22, 2019 8:56 pm Reply with quote Back to top
pontiacstogo: how's that semi-gloss finish holding up?
PostPosted: Sun Sep 22, 2019 11:49 pm Reply with quote Back to top
That's the one I was looking at Peter. I will check out the hindle as well, Jim.
PostPosted: Mon Sep 23, 2019 1:17 am Reply with quote Back to top
No idea sorry - I sold both my 1100F's to the same person that bought my Katana.
metu71
PostPosted: Mon Sep 23, 2019 5:35 pm Reply with quote Back to top
That is exactly how I did it. First loosely and then tightening up while checking everything fit correctly...
PGSmick
PostPosted: Tue Sep 24, 2019 5:13 pm Reply with quote Back to top
I installed a 4 into 2 system in black. Fit was OK although not without some minor adjustment to pick up the oil sump bolt holes. But I am definitely NOT impressed with how the finish is holding up. I might have been happier getting the whole system powder coated or ceramic coated from the git-go. I would definitely have held off for a Hindle if they made a 4-into-2 system.
Peter.
1100 X 2 & 750
"Once you know how it's supposed to work, you can almost always figure out why it doesn't."
Gadgets: Fixed By Smicks
