  • Total: 45,492,081
  • Today: 20,070
  • Jan 21, 2021
  • 01:11 pm PST
bizzcb1100f
PostPosted: Fri Jun 29, 2018 1:45 pm Reply with quote Back to top
Has anyone here tried the ricks permanent magnet starter? If so how do you like it? My 1100f starter finally died after 65,000 miles and it is roached.
bizzcb1100f
PostPosted: Thu Aug 02, 2018 5:38 pm Reply with quote Back to top
Despite the lack of feedback i decided to try the Ricks starter anyway. Seems to be working great, turns the engine over alot better when hot. Its been a little sketchy since I installed the 1123 wiseco kit. We'll see how well it holds up in the long run but first impressions are good. Smile
PostPosted: Thu Aug 02, 2018 7:06 pm Reply with quote Back to top
Thanks for taking the plunge and reporting back!
When hot starts are difficult, have you tried pushing the starter button with the kill switch turned to off and then flipping the switch to on while cranking? Sometimes that helps and it’s much easier on the starter.
Nich
79 750f
PostPosted: Thu Aug 02, 2018 7:30 pm Reply with quote Back to top
Or add an Ignitech controller and delay the spark for a few rotations. Just one of the many benefits of using the the Ignitech box.
PostPosted: Fri Aug 03, 2018 11:18 am Reply with quote Back to top
For sure! There are better ways of dealing with hot start problems than my suggestion, but it is a simple crutch that anyone can do that may help save their starter.
79 750f
bizzcb1100f
PostPosted: Fri Aug 03, 2018 1:22 pm Reply with quote Back to top
Nich
Yes I have, Its the only way that it would start while hot after the engine rebuild with the higher compression pistons. I was going to have to rebuild or replace the starter anyway since It died anyway, and after seeing the guts of the starter after disassembly this seemed like the best option.
bizzcb1100f
PostPosted: Fri Aug 03, 2018 1:24 pm Reply with quote Back to top
I'm thinking about trying one of these, I need to stop spending all my money on RD400 parts Laughing
Page Generation: 0.26 Seconds
