  • Total: 73,649,087
  • Today: 31,995
  • May 02, 2024
  • 01:39 pm PDT
houredout401
PostPosted: Wed Jul 18, 2018 1:42 pm Reply with quote Back to top
Curious if anyone knows the engineering reason behind the double plate. If it was just a spacing thing, seems they could have just had a thinner overall clutch pack.
PostPosted: Wed Jul 18, 2018 2:20 pm Reply with quote Back to top
Good question and I have wondered the same thing. They used a double plate in the GL1000's too, and probably numerous other models as well.
PostPosted: Wed Jul 18, 2018 2:54 pm Reply with quote Back to top
To give it a more progressive feel.
The answer is always "more power" always was, always is and always will be.
Grumpy32
PostPosted: Wed Jul 18, 2018 3:30 pm Reply with quote Back to top
I thought it was meant to act as sort of a shock absorber and for anti chatter?
Terry
07 cb 900f hornet 919... the fastest Red one.
PostPosted: Wed Jul 18, 2018 3:56 pm Reply with quote Back to top
Also to keep the rear wheel from doing a burnout
houredout401
PostPosted: Wed Jul 18, 2018 6:22 pm Reply with quote Back to top
I'm not smart enough to understand. I could see if the two plates moved, but the one I have just appears to be two plates riveted together with a small spacer. Maybe they flex in some way I cant see.
Grumpy32
PostPosted: Wed Jul 18, 2018 6:51 pm Reply with quote Back to top
The small spacer is a spring. That's how it moves.
Terry
PostPosted: Wed Jul 18, 2018 7:01 pm Reply with quote Back to top
Yes, there should be a very small amount of spring tension that holds the two plates apart by a small amount. The plates can move a bit, they aren't tightly riveted together, the rivets allow a bit of separation. I don't have a real number, but it's like .002" maybe.
Grumpy32
PostPosted: Wed Jul 18, 2018 7:47 pm Reply with quote Back to top
The part I don't understand, is why they used "brass" rivets. Dumb move imho...
Terry
PostPosted: Thu Jul 19, 2018 9:06 am Reply with quote Back to top
unless there's a difference spline tooth difference
between one of the two plates, I don't see how the
rotational cushion could idea could work. possibly
its a anti heat transfer function device ?
houredout401
PostPosted: Thu Jul 19, 2018 1:03 pm Reply with quote Back to top
I see, kind of like a secondary clutch spring, that would explain Capitains "progressive" comment.
djf18374
PostPosted: Thu Jul 19, 2018 1:57 pm Reply with quote Back to top
Yes, that was my initial thought too. They're locked rotationally with the splines, so it only can function axially to dampen the clutch pressure spikes. Essentially it will lock up softer if the clutch is let out quickly
79 CBX (silver)
81 CB900F (silver)
83 CB1100F (red)
PostPosted: Thu Jul 19, 2018 2:39 pm Reply with quote Back to top
So Question Question as with so many things, as i get older, this one goes into the "just the way it is file". I was going to mention the " who gives a shit" file but thought it might be rude. That plate can be eliminated.
PostPosted: Thu Jul 19, 2018 3:39 pm Reply with quote Back to top
I kind of thought it was the cause of the big clunk going into 1st from neutral, as it kind of causes the plates to drag when the clutch is open, and keeps everything turning until 1st gear dogs engage. So it's the clunk generator.
djf18374
PostPosted: Thu Jul 19, 2018 4:31 pm Reply with quote Back to top
I like that! "the clunk generator" Smile
79 CBX (silver)
81 CB900F (silver)
83 CB1100F (red)
PostPosted: Thu Jul 19, 2018 4:44 pm Reply with quote Back to top
Kind of a signature Honda noise. Like clutch basket rattle. Laughing
Grumpy32
PostPosted: Thu Jul 19, 2018 6:10 pm Reply with quote Back to top
grump wrote:
So Question Question " who gives a shit" file but thought it might be rude. Laughing That plate can be eliminated.
Absolutely it can with two reg steels. I still don't understand why they used soft brass rivets. stupid idea Evil or Very Mad
Terry
houredout401
PostPosted: Thu Jul 19, 2018 7:09 pm Reply with quote Back to top
The purpose of the post was just intellectual curiosity, but if I have to explain that, then this thread is not really for you. If I don't care about a topic, I don't waste my time or karma peeing on others, but if it works for you, go for it.
PostPosted: Thu Jul 19, 2018 11:25 pm Reply with quote Back to top
welll I guess i been put in my place by miss manner alright.
Nunzio
PostPosted: Fri Jul 20, 2018 1:18 am Reply with quote Back to top
I have a GL1000 as well and am going to replace the clutch soon. I'm also converting to a 1894 GL1200 hydraulic clutch cover. (Only 1 year for a cover that will fit the GL1000).
The double plate is for damping and a more subtle engagement. I'm removing this from my GL and replacing with a solid plate, then using an extra plate at the end of the stack up. Documented here: http://www.wingovations.com/clutch-plate-b-problems/4579471089
Not sure if this will work on the CB's as well.
CB750F Super Sport
GL1000
CX500TC
muskrat
PostPosted: Fri Jul 20, 2018 10:39 am Reply with quote Back to top
G'day fellas.
So would this plate cause a violent shudder when launching off the traffic lights against an R1?
The CLUNK going into 1st can be embarrassing. Tin toppers can hear it over their boom box! LOL
Only young once but can be immature for life.
83 CB1100F,
51 BSA A7, 57 BSA A10, 78 XT500, 88 HD FXST
NYE Bush fire took these 81 CB900, 76 Yam XT500C, 77Ag175
