  • Total: 30,494,099
  • Today: 16,301
  • Feb 24, 2020
  • 09:21 am PST
Wayne750F
PostPosted: Sat Apr 04, 2015 11:51 pm Reply with quote Back to top
Dang....had some brake fluid drip onto the tank and decal....of course in the hot sun. I wiped it off with a shop towel but it left visible signs....any ideas how to buff this out????
1981 Black CB750F 887 Project Sleeper 750
1983 Red CB1100F
1991 Suzuki GSXR1100
1993 Yamaha FZR1000
PostPosted: Sun Apr 05, 2015 2:13 am Reply with quote Back to top
Just try the regular ways. I use fine 3M rubbing compound for finishing, it might be too weak or not aggressive enough to get through depending on how deep it went. If it went through the clear no bets...
Always keep water handy when working with brake fluid. It dilutes it right away, and renders it harmless. I use a spray bottle and a towel whenever I'm on brakes.
links
Image Image
7fiddy
PostPosted: Sun Apr 05, 2015 2:58 pm Reply with quote Back to top
+1, but if you use any rubbing compound you'll want to use a scratch and swirl remover, I like turtle wax scratch and swirl remover, stuff works wonders for me.
All giddy on my 7fiddy
1980 CB750F Super Sport
1966 Ford Fairlane (Project)
2004 GMC Sierra
“Don't cry because it's over, smile because it happened.”
Wayne750F
PostPosted: Sun Apr 05, 2015 7:46 pm Reply with quote Back to top
Thanks guys....I appreciate the knowledge and advice....This bike arrived from Ohio last Monday but already had 14 coats of wax on it Smile))) (I'm an engineer! Super anal about detail) so I'm working on it and it's improving. I'll try the turtle wax....I've already used Turtle Wax Color Magic black on the side covers and that worked real well....
1983 Red CB1100F
1993 Yamaha FZR1000
PostPosted: Sun Apr 05, 2015 9:36 pm Reply with quote Back to top
If worse comes to worse and it won't come out you can always wet sand with 2000 grit and try to buff it out. If that doesn't work you can reshoot a couple coats of clear over the top after lightly wet sanding. It will look like new or better. Don't go through the old clear though when wet sanding. Just enough to scuff it.
Page Generation: 0.16 Seconds
