  • Total: 123,137,379
  • Today: 133,795
  • 05:29 pm PST
seventyss
PostPosted: Thu Feb 19, 2009 8:20 am Reply with quote Back to top
Looking for suggestions for a good set of grips. Have used cushion grips in the past on other bikes but don't see them around anymore.
Bandit65
PostPosted: Thu Feb 19, 2009 1:29 pm Reply with quote Back to top
You might give these a try:
Randakk's Amazing Grips
Image Image
Tacman
PostPosted: Thu Feb 19, 2009 5:54 pm Reply with quote Back to top
I just ordered a set. $22.00 Tax and delivery included to Toronto.
I will let you know what they are like,
Thanks for the lead.
TM
hondavt500
PostPosted: Thu Feb 19, 2009 7:13 pm Reply with quote Back to top
I'm running these right now, they work pretty good. The colored insert is a gel cushion.
Found 'em here.
Dennis Kirk grips
John M
Bandit65
PostPosted: Thu Feb 19, 2009 7:15 pm Reply with quote Back to top
Found 'em here.
Dennis Kirk grips
John M
I've had a set with the gray inserts on my 900 for several years now, they are holding up well. Can't say I can tell a differance with the gel over any others though.
PostPosted: Thu Feb 19, 2009 8:52 pm Reply with quote Back to top
An on site search under "grips" will turn up a number of related posts on the topic. I like the factory grips for both comfort/traction and wear. I back up these with a good pair of gloves and a throttle lock cruise control unit so you can relax your hand on those longer rides. If your one to use bar end mirrors, like the CRG and Motrax (Motrax is a clone CRG knockoff) the CB-11OOF stock grip is a good choice as it give a finished hole in the grip to allow bar end mirrors or bar end weight units to pass through. Good gloves regardless of the grip selected is a big part of the comfort issue in my mind.
Tony
TomStrasser
PostPosted: Thu Feb 19, 2009 10:12 pm Reply with quote Back to top
I got these form Parts and more, only cause I need to get a order up to the 35 buck range
But they work fine I've had them for 2 season already and even in the rain I've had no issues with them.
CB900SS
PostPosted: Thu Feb 19, 2009 11:06 pm Reply with quote Back to top
I am with Tony on this one. Stock grips all the way... But I had a really awesome Canadian member get mine, because they come with the holes in the ends for the Canadian bikes that came with bar end weights. In my case I used the holes for bar end mirrors.
spike
PostPosted: Thu Feb 19, 2009 11:11 pm Reply with quote Back to top
+1 on the stock grips
Three of a prefect pair
PostPosted: Thu Feb 19, 2009 11:22 pm Reply with quote Back to top
Part#'s for the Canadian spec factory 1100F grips are:
53165-422-000 RH
53166-422-000 LH
The need for two numbers is because the throttle tube is of a large diameter then the non-thtottle tube grip. I installed these to my 750 after the install 400F bars and CRG 'Blindsight" mirrors. My 1983 1100 still sports the stock grips after 20 + years (maybe I don't ride it enough, that may be the case for sure), and are still very much up to the task.
And I also need to correct my earlier post. (Bens reply has rung some bells). These grips were a Canadian and maybe Euro spec piece based on the clip-on style handle bar installs of these machines. The U.S. spec 1100 did not run this "through the grip bar end weight" system.
Thanks Ben,
Tony
natscape
PostPosted: Sat Feb 21, 2009 11:28 pm Reply with quote Back to top
Had a set of these on my 750 and there were very comfortable. This set is available if you are interested. Harris space age material...Image
PostPosted: Sat Feb 28, 2009 9:55 pm Reply with quote Back to top
Just got my Randakk's in today and mounted them up. Wow, They are very comfortable. Mr. Green
1981 CB900F = Sold 2024
Lowblues
PostPosted: Sat Feb 28, 2009 11:09 pm Reply with quote Back to top
Have the same set on my bike since 1983, still in good shape. What else can I say. (Except good gloves.)
http://www.grabongrips.com/motorcycle.php
Silver 1981 CB900F
rpgoerlich
PostPosted: Sun Mar 01, 2009 1:23 am Reply with quote Back to top
Put a set of Randakks Grips on the XS. They are way comfortable!
PostPosted: Sun Mar 01, 2009 2:41 am Reply with quote Back to top
Hey thats what I just took off - Grab-ons. They were probably vintage 1983 and getting a little long in the tooth. Wanting to try something different at this point and eeh Randakk's looked and sounded interesting from the desciption. I'll replace with grab-ons if these don't pan out. These Randakk's do feel much better though but I haven't ridden with them and won't get to until May.
chill
PostPosted: Sun Mar 01, 2009 3:17 am Reply with quote Back to top
The only grips to get are OURY
http://www.ourygrips.com/grips_menu.html#
Your welcome,
enjoy...
PostPosted: Sun Mar 01, 2009 5:52 am Reply with quote Back to top
Your welcome,
enjoy...
Why only OURY? No other manufacturers worth a darn? I don't like the way they look so its not the only grip for me.
jazzmans
PostPosted: Sun Mar 01, 2009 7:39 am Reply with quote Back to top
I use full waffles that look just like the first oury grips on the above link on all my bikes.
they're awesome. Only thing is, they're too short, so I cut the end off the throttle grip and gaff taped the difference on my cb.
breets50
PostPosted: Sun Mar 01, 2009 3:45 pm Reply with quote Back to top
Hey Richard, (bandit65) love the avatar!!! Very Happy
BRUCE
Lowblues
PostPosted: Sun Mar 01, 2009 6:12 pm Reply with quote Back to top
Come back Dave, come back from the dark side...
use the force Dave, and soap or a little air pressure so it will slide on nice and easy. Very Happy
Silver 1981 CB900F
Bandit65
PostPosted: Mon Mar 02, 2009 12:48 pm Reply with quote Back to top
Me too! Cool
Kevoz
PostPosted: Mon Mar 02, 2009 3:52 pm Reply with quote Back to top
I just installed a set of 'Driven Diamond' D6370 grips, black, www.drivenracing.com , like their feel and look, just a tad short it seems (120mm?), they replaced ProGrip 699's which I liked, they were grey and I couldnt keep them from looking like sh*t....
beerchug
PostPosted: Mon Mar 02, 2009 4:40 pm Reply with quote Back to top
beerchug
WOW! I like those.
Dav e
Page Generation: 0.11 Seconds
