  • Total: 123,137,305
  • Today: 133,721
  • 05:29 pm PST
SuperSportCB750F
PostPosted: Fri Jun 23, 2006 11:40 pm Reply with quote Back to top
what kind is good? I bought some 10.00 foam ones with "chrome' ends and they lasted about a year but now they are all ripped. So i have decided ti stay away from foam. Should one go with a metal type or rubber? I was looking at some rubber Progrips. i want them to be a little on the thick side i hate thin grips. Let me know what u guys think
SuperSportCB750F
PostPosted: Sat Jun 24, 2006 12:35 am Reply with quote Back to top
Progrip 725 EVO
zman
PostPosted: Sat Jun 24, 2006 12:43 am Reply with quote Back to top
Well..Ten bucks for a years use isnt bad. Wink
PostPosted: Sat Jun 24, 2006 1:09 am Reply with quote Back to top
I stuck with the factory Honda piece for the Canadian spec 1100F. These are fit to the factory clip-on bars on the Canuck F and allow for a bar end mirror install without cutting a hole in the grip,..the clip-ons have bar end weights doncha know. They fit all manner of F bikes. Note: there is a left and right grip,..they differ in size due to the throttle sleeve. My last grips lasted 23years,..not bad for factory stuff.
Second to grips is a good pair of riding gloves!
Tony "still holdin' on to Honda" Bagley
SuperSportCB750F
PostPosted: Sat Jun 24, 2006 1:11 am Reply with quote Back to top
yea.. i went back and looked at the price it was $19.99
Old Bike Barn Grips
Where as the Progrips are on sale at $9.99 and made of get and rubber. i think thats not bad.
zman
PostPosted: Sat Jun 24, 2006 2:01 am Reply with quote Back to top
I just bought the 6.99 black foam grips (put them on with hair spray as recomended) Havent used them yet but they fit well and should keep the vibrations down. For 6.99 you might give them a shot and see.
There is allot of hype with grips as with in allot of the accesory markets.
SuperSport
SuperSport
PostPosted: Sat Jun 24, 2006 2:13 am Reply with quote Back to top
Oury grips, anything else is for cripples, freaks or feebes.
Glenn
´83 CB1100F,´94 Wife
Catchy phrase not included.
PostPosted: Sat Jun 24, 2006 2:20 am Reply with quote Back to top
Archive info copy and paste below. Link to this prior post is here:
http://cb1100f.net/modules.php?name=Forums&file=viewtopic&t=19647
I've always like the factory Honda piece myself. Perfect fit. Long lasting, I've yet to have had to change a set of grips (of course this may be due to a rather protracted riding schedule and low kilometers per yer I guess). The Canadian spec 1100F grips are set up for bar end weights as used on the clip-on bars installed on this model, ergo there is a factory cut hole in the end of the grip which makes bar end mirrors and/or weights a very simple install job. Nice factory clean hole in the end of the grip. There is a RH and LH grip of course to make the throttle sleeve size isssue no problem also.
1100 CBF/1983 53165-422-000 Grip (handle bar) 9.16cnd
1100 CBF/1983 53166-422-000 Grip (handle bar) 9.16cnd
Tony
A rather poor photo, but it may give ya a bit of an idea what there like incase you forgot. CRG 2" Blindsite mirror installed here. (There kinda small hey Blaine )
edit: Also of note: The Sport Cable switch block allows for a rather nice install of the Vista Cruise Control unit. The locationg tab which would normally be between the cables on the standard switch block(at least I think that's where it would normally be?) is now of courser rotated up to the Sport Cable position with only a slight mod to the Vista Cruise unit. I shaved the locator tab down to fit between the Sport Cable switch block cables. This (IMHO) puts the Vista Cruise thumb lever in a much nicer position (down low) which both works extremely well and does not make the piece look like an after-thought sticking up on the bar.
Tony "Oury who?" Bagley
SuperSport
SuperSport
PostPosted: Sat Jun 24, 2006 2:54 am Reply with quote Back to top
Very Happy
Glenn
Jaime
PostPosted: Sat Jun 24, 2006 5:30 am Reply with quote Back to top
those are the coolest rear view mirrors I ever saw....any info on those??? Smile
PostPosted: Sat Jun 24, 2006 1:09 pm Reply with quote Back to top
Mirrors: CRG (Constructors Race Group) 2" Blind Sight . You can purchase straight from CRG or get a small price break from the guys at "Bevel Heavean" a Ducati outfit. (both have web sites that should turn up via a search)
The 3" mirror may be a better choice, as these are quite small but of course are less noticeable also. Don't forget your shoulder checks!
Tony "watz a behind me a'no matter" Bagley
motnick
PostPosted: Sat Jun 24, 2006 1:24 pm Reply with quote Back to top
Tony as I move toward GSXR clutch and brake parts I am going to lose my mirror mounts. No big deal I will just have to get some of those sweet mirrors like you! Cool Those EURO grips sure would make the install very easy. Any chance I can get those in the states? If not maybe I can talk one of my Canadian brothern into picking me up a set and passing them my way during the Rat ride.
Back on topic, I agree with Tony the stock grips are the way to go. They feel great and last a long time. Like 20-30 years! Shocked
PostPosted: Sat Jun 24, 2006 6:02 pm Reply with quote Back to top
motnick wrote:
Tony as I move toward GSXR clutch and brake parts I am going to lose my mirror mounts. No big deal I will just have to get some of those sweet mirrors like you! Cool Those EURO grips sure would make the install very easy. Any chance I can get those in the states? If not maybe I can talk one of my Canadian brothern into picking me up a set and passing them my way during the Rat Ride.
Done!
billswheels
PostPosted: Sun Jun 25, 2006 11:56 pm Reply with quote Back to top
this is something i just went threw!! replacing grips. now, i first bought the progrips, and installed, and tested, and found they felt no different than my original ones!!
so i proceded to blow them back off, pack back up, and return.
what i ended up with were the foam over rubber grips, with the metal end caps, and they are the ticket!! Wink
they are much thicker, and took a few miles to get used to, but i love them. payed 16.99 for the set. if they go bad after 1 season, im sure i can sacrifice 16.99 again next season. did not even glue them. they were tight in fitting, used a bit extra hairspray, slide right on, and i let dry overnight. the progrips in my opinion are a ok replacement, but for comfort, and not bad looking at all, these grips made the ride alot less vibrating!!!! Shocked
CB900SS
PostPosted: Mon Jun 26, 2006 12:03 am Reply with quote Back to top
Alright I am having a hard time finding grips also. I went to my Honda dealer and they where no help. I have been browsing online for a few months and havnt found anything that I like. My main question is whats the deal with the different length grips, what length do our bikes take?
billswheels
PostPosted: Mon Jun 26, 2006 12:08 am Reply with quote Back to top
5 1/8 i believe...yes, they are it.
bill
CB900SS
PostPosted: Mon Jun 26, 2006 12:09 am Reply with quote Back to top
bill
Funny because every grip I have looked at was measured in mm. 110,120,130 I beileve.
billswheels
PostPosted: Mon Jun 26, 2006 12:11 am Reply with quote Back to top
try this link...
http://cgi.ebay.com/ebaymotors/GEL-GRIPS-HONDA-CB750-VFR-GL1000-Rebel-CBR-K8_W0QQcmdZViewItemQQcategoryZ34284QQihZ002QQitemZ120001789486QQrdZ1QQsspagenameZWDVW
CB900SS
PostPosted: Mon Jun 26, 2006 12:16 am Reply with quote Back to top
Thanks man, you know all the time I looked for grips I never even thought about ebay. I will see if I can find something now.
billswheels
PostPosted: Mon Jun 26, 2006 12:22 am Reply with quote Back to top
not a problem! i think the search i tried was 7/8 grips if i recall..it was a few weeks ago that i was looking for them.
bill
CB900SS
PostPosted: Mon Jun 26, 2006 12:43 am Reply with quote Back to top
These are pretty cool, but I think I want something different.
Honda "LIKE" grips
SuperSportCB750F
PostPosted: Mon Jun 26, 2006 2:21 am Reply with quote Back to top
billswheels~ Its funnt becasue the girps you chose (foasm) look exactly like the set i have currently. they are nice and absorb alot of vibration but they retain moisture and if you ever have to ride int he rain they will rip. Where did you purchase them from?
I just bought the 725 Evo progrips in red and black. With the set I orginally bought i didn't have to use glue or hairspray. Do most grips need some type of adhesion? I just anted someything sporty, thick, and would absorb some vibration
billswheels
PostPosted: Tue Jun 27, 2006 12:09 am Reply with quote Back to top
i got my grips locally at montgomeryville cycle. as far as moisture, me and my better half ride only when the weather radar looks clear, so really no fear of them getting wet.
i have put 2 sets of grips on, with neither needing glue. a friend of mine said his fit so loose, he had to glue them.
bill
CoolCat
PostPosted: Thu Jul 06, 2006 2:50 am Reply with quote Back to top
I think my F has the original Honda grips on it and they're all loose and twisty at the ends, and a former owner installed a throttle lock cruise control and the right grip is hanging off the end of the bar. I've used the larger foam & chrome grips on other bikes in the past (Gold Wing) and they were ok for that application, but I definitely want to be able to hold onto the F so I'd be worried that they are a little too big.
SuperSportCB750F
PostPosted: Mon Jul 10, 2006 12:25 am Reply with quote Back to top
I go tthem. They are cool but my throttle grop seems to be a little too short. there is section of the white throttle part you can see. Is there anyway to fix this?
billswheels
PostPosted: Mon Jul 10, 2006 1:38 am Reply with quote Back to top
did you order the 5 1/8" long ones?? if not, you will have a section of your throttle side showing.
i dont believe you can fix that on the throttle side, but the clutch side you can by moving the controls over.
bill
Ratfink
PostPosted: Mon Jul 10, 2006 2:58 am Reply with quote Back to top
Must be a freak. Because I am not a cripple and I love my yellow bike matching Pro Grips. They have lasted great, still look new when I cleant them, and they add a little to the bike.
But hey are just quality rubber grips. Not foam. Keep the foam on your harley. My F does not vibrate enough to cause me any issues after 4 hour trips. Not sure what all the comlaint is always about. Cool
I have an older pair of the Pro Grips though. And if I remember they had differnt types of rubber and designs. Mine are pretty soft and sticky. Used to have grips like them on my mountain bike and I like sticky grips especially when wearing gloves. And teh sticky makes it easier to twist the throttle. Cause you will naturally grip tighter if you have less traction on the grip. Not a problem when they are sticky and you right hand thanks you.
That was my problem with the old stock grips. But they were also dried out.
Wanted to add. Hairspray works fine in the winter here. But mine melted and my grips started sliding off half way down to Tucson. Sucked. But then again it was 117 outside. Shocked
7Eleven
PostPosted: Mon Jul 10, 2006 3:03 am Reply with quote Back to top
Right on!!!! Seems that Matt had them also. Best improvement after a good set of tires.
Squatch71
PostPosted: Mon Jul 10, 2006 3:15 am Reply with quote Back to top
Progrip 725 EVO
How are these for vibration?? I just got back from a little tour of the area and my grips need to be changed, don't want foam cause they will rip but might just have to get some..how are these SuperSport??
Ratfink
PostPosted: Mon Jul 10, 2006 3:27 am Reply with quote Back to top
Already talked about my personal experience with Pro Grips. I like them. Not sure how they can get much better, but I will have to say I have not tried out Oury. I'll do that when these wear out some years down the road.
